    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 205.4k Views 88 Watching
      Click Draw
      Again.....Thanks very much. This is just amazing....great update! And if your ever in Vancouver, I'll buy you a jug of beer! 😍
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • JClementsJ Offline
        JClements
        Very impressive.
        Be neat if you could add in something like Joseph Lieblinger's Soap Skin method to flex the triangulated surface.
        Regards, John
          No possibility to automate the clicks of curves? 😉
          the 10 curves are made with the Grow plug by Tig
          • EscapeArtistE Offline
            EscapeArtist
            Fantastic plugin.
            Thank you very much for your hard work!
              AcesHigh
              damn Chris, you are a genius...
              can you please tackle the problems of cold nuclear fusion and faster than light travel, after you finish this plugin? 😄
              just a question... what if I WANT straight lines connecting faces? You know... for something that doesnt look organic... dunno... like a ship hull or something... maybe you can add, in the final version, option for connecting with splines or lines?
              • mitcorbM Offline
                mitcorb
                @Chris:
                Thanks for another excellent effort in this Loft Tool.
                This is to confirm proof of concept in the wild. I remodeled my guitar neck/body heel transition, and it worked very well.
                  dtrarch
                  Hi Chris
                  Heads up on alpha 0.1b
                  BugSplat on V6 latest (3 times) 😞
                  OK on V7 free latest 😄
                  Using 3 equal arcs.
                  dtr
                    sepo
                    Hmmm... I am getting Bugsplat on anything with loft tool... To be precise I draw arc (12 segments) I draw second arc (12 segments) I press loft select both arcs, hit enter choose 5 grom GUI. press OK ....bugsplat. SU7...will try now on SU6.
                      sepo
                      Interesting...it works no problem on SU6 with 2 or more arcs.
                        sepo
                        If you are refering to my case ....they had only same number of segments but not same curves.
                        • Chris FullmerC Offline
                          Bummer Sepo, your getting splats on any loft in v7?
                          Could you attach a file with shapes that splat? I'm not sure if this is a script conflict splat or if you guys are using it in ways that never crossed my mind (like with shape bender, I'm amazed at what people make that script do!).
                          So perhaps attach some example models and I'll take a look. Thanks!
                          EDIT: Sorry, in that previous post I was answering dtrarch - I'll edit it to make it more clear.
                            @dtrarch - Lofting 3 equal arcs in SUv6 gives bug splats? But 2 equal arcs do not, correct? Could you post a model that splats?
                            I'll look into it and I have a pretty good idea where in the code to start looking. I can't think of anything I've done that should splat though. Oh well, I'll try to check it out.
                            • W Offline
                              watkins
                              Dear Chris,
                              I cannot seem to get your plugin to work. The loft icon appears in my toolbar, and seems to work: it changes when selected and allows the selection of the two curves (simple arcs with the same number of segments), but then nothing. I even tried exploding the arcs, but still nothing.
                              As usual, I put the simple_loft folder and loader in my plugin folder. Is it possible that one of my other plugins is causing a problem? I have tried your plugin on two different computers (home laptop and office desktop), but with the same result. Both have the same plugins. Curious.
                              Kind regards,
                              Bob
                                sepo
                                This is console . I start loft and have this
                                --> New Definition Added:
                                --> 0
                                --> nil
                                I select arcs,press ok in GUI have this for 1 second
                                --> 0
                                --> nil
                                and than bugsplat....now this happens in SU7 even with simple curves.
                                • W Offline
                                  watkins
                                  Dear Chris,
                                  I do apolgise. I had a senior moment, or to be more precise, I failed to read your instructions to the end. Hit ENTER was the missing step. Seems to work just fine now.
                                  Kind regards,
                                  Bob
                                    Click Draw
                                    Hey Chris,
                                    Been playin' a bit...so far no probs. I'm on SU7 Pro, Vista if that helps.
                                    Jeff
                                      dtrarch
                                      I checked V6 with only loft installed.
                                      It is bumping into another script or ?
                                      The same script set is on V7 and loft is OK there.??
                                      BTW the number of arcs 2-whatever still bombed.
                                      Dave
                                      • W Offline
                                        watkins
                                        Made using simple_loft
                                          kwistenbiebel
                                          Hi Chris,
                                          You and Fredo can have the Nobel Prize, whatever the category.
                                          Marvelous in all ways !!! 👍
                                          Google, eat your heart out (again)!
                                            sepo
                                            Quite bizzare. On Vista comp SU7 works fine but not on XP SU7, However on same XP SU6 it works. I will now try on my XP laptop.
                                            • 12
                                            • 13
                                            • 2 / 13
