    How to get land in Vray scene
    renderpluginsextensions
    14 Posts 7 Posters 4.2k Views 7 Watching
    • Z
      zeeshan
      in a tutorial i found on line :
      http://my.opera.com/explainking/blog/lighting-in-v-ray-for-sketchup
      the image that i gets after the setting he tells is below and is without a land and a sky !
      whereas the tutor gets a perfect land and sky in his image.
      What am i doing wrong. ?
      • jeff hammondJ
        jeff hammond
        if you're asking what i think you're asking then in the menu bar go Window->Style..
        you'll see a dialog like this (this is on a mac but i assume windows is similar):
        first click on the edit button then the middle box... from there, you'll be able to set up your ground,background and sky..
        dotdotdot
        • Z
          zeeshan
          Thanks Jeff,
          But i still don't see a ground or a sky in my Vray image, it is still the same.
          • jeff hammondJ
            jeff hammond
            @zeeshan said:
            Thanks Jeff,
            and that's what i was worried about.. you were talking about vray in which case my answer is:
            i have no idea! 😄
            dotdotdot
            • GaieusG
              OK, I see now, too.
              Edited subject and moved to extensions.
              • soloS
                solo
                You need to insert an infinate plane (last icon on the vray toolbar) or add a ground plane in SU.
                http://www.solos-art.com
                • Z
                  zeeshan
                  THANKSSS solo!!!!
                  finally the mystery solved 😄
                  • A
                    AcesHigh
                    @zeeshan said:
                    THANKSSS solo!!!!
                    and to add a sky, set the camera to PHYSICAL (at camera tab)...
                    then go into ENVIRONMENT TAB and click the M on the side of GI. Set it to SKY on the dropdown list. Now click the M on the side of Background. On the dropdown list select BITMAP. Set it to ENVIROMENT (in UVW), click the M below to select a bitmap and at the side of UVW choose the type of sky that matches the bitmap you selected (if its a cross, select cubic, if its a panoramic, choose spherical)
                    • Z
                      zeeshan
                      AcesHigh thanks !!!!
                      Another mystery solve 😄
                      • S
                        sambort
                        hey aceshigh
                        sorry, but the enviromental, background, bitmap pointed doesn´t work for me (i only get a blak sky)
                        could you show a example? or perhaps you have another version?
                        • thomthomT
                          Turn up the multipler. Depending on what version of V-Ray you have and if you use an HDRI the values might range from 20 - 20000.
                          • A
                            AcesHigh
                            @sambort said:
                            hey aceshigh
                            do what ThomThom said... i really forgot to tell it. The physical camera is much less sensitive to light than the "normal" camera... thus, you need to turn up the multiplier inside the M tab for the sky image to show up.
                            • S
                              sambort
                              you guys are right!http://www.sketchucation.com/forums/scf/posting.php?mode=reply&f=80&t=18000#
                              20000 was needed for the multiplier and it works!
                              now i get beatiful skies inside VR
                              thanks again!
                              • thomthomT
                                Then it sounds like you have the original V-Ray for Sketchup. There's an update available over at ASGVis for download.
