    How to get land in Vray scene
    renderpluginsextensions
    14 Posts 7 Posters 4.1k Views 7 Watching
    • jeff hammondJ
      @zeeshan said:
      Thanks Jeff,
      But i still don't see a ground or a sky in my Vray image, it is still the same.
      and that's what i was worried about.. you were talking about vray in which case my answer is:
      i have no idea! 😄
      • GaieusG
        OK, I see now, too.
        Edited subject and moved to extensions.
        • soloS
          You need to insert an infinate plane (last icon on the vray toolbar) or add a ground plane in SU.
          • Z
            zeeshan
            THANKSSS solo!!!!
            finally the mystery solved 😄
              AcesHigh
              @zeeshan said:
              THANKSSS solo!!!!
              and to add a sky, set the camera to PHYSICAL (at camera tab)...
              then go into ENVIRONMENT TAB and click the M on the side of GI. Set it to SKY on the dropdown list. Now click the M on the side of Background. On the dropdown list select BITMAP. Set it to ENVIROMENT (in UVW), click the M below to select a bitmap and at the side of UVW choose the type of sky that matches the bitmap you selected (if its a cross, select cubic, if its a panoramic, choose spherical)
              • Z
                zeeshan
                AcesHigh thanks !!!!
                Another mystery solve 😄
                  sambort
                  hey aceshigh
                  sorry, but the enviromental, background, bitmap pointed doesn´t work for me (i only get a blak sky)
                  could you show a example? or perhaps you have another version?
                    Turn up the multipler. Depending on what version of V-Ray you have and if you use an HDRI the values might range from 20 - 20000.
                      AcesHigh
                      @sambort said:
                      hey aceshigh
                      do what ThomThom said... i really forgot to tell it. The physical camera is much less sensitive to light than the "normal" camera... thus, you need to turn up the multiplier inside the M tab for the sky image to show up.
                        sambort
                        you guys are right!http://www.sketchucation.com/forums/scf/posting.php?mode=reply&f=80&t=18000#
                        20000 was needed for the multiplier and it works!
                        now i get beatiful skies inside VR
                        thanks again!
                          Then it sounds like you have the original V-Ray for Sketchup. There's an update available over at ASGVis for download.
