[Plugin Library] LibFredo6 - v16.1g - 11 Sep 26
The subfolder is created if it does not exist in ../local. Is this the case, or do you have permissions set that prevents it?
Fredo
Hi I´v been trying to get the plugin on sketch up whole week and I still don´t get it it has driven me crazy! I downloaded the plugin and extracted it to plugin folder also as i installed it from the warehouse. Still I don't get it in my toolbar. What have I missed?
From the first post of the thread.
LibFredo6 is a shared library used by some of my plugins. It is NOT a standalone plugin. Plugins currently using LibFredo6 are:
FredoScale Tools on Surface RoundCorner Curviloft HoverSelect GhostComp SUClock FredoTools Curvizard TopoShaper JointPushPull InteractiveWhich means there is nothing to appear in any toolbars, it is a helper file that works with other plugins.
You need to install the other plugins for it to have any purpose. -
I am getting this error loading issue with Fredo6 on 2014 installing the plugin from Sketchucation. Anything that can be done?
Paul,
It just menas that on your installation, one or several of my plugins have not been upgraded to latest version compatible with SU 14.
Please checkFredo
Have reinstalled all the Fredo plugins from Sketchucation and from Extension warehouse, same result. Have disabled all other plugins, same result. Installed Libfredo on its own. no problem, installed any of the other plugins in any order same results. They all give similar error messages. Ran Sketchup as administrator, same result (using windows 7 64bit). Disabled all the virus protection, same result. Don't know where else to go.
Paul,
You have a wrong file somewhere among my plugins (i.e. not encoded for UTF8), and it is most likely a file with extension .plugin.
It may be a files remaining from an old installation.
I suggest you clean up the folders and subfolders of my plugins, and then reinstall from with the PluginStore tool.
Fredo
Try the following...
In SketchUp 2014 > Ruby Console:$:result?
Sketchup.find_support_file('Plugins')result?
It should be something like:
C:/Users/PaulB/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/PluginsSketchup.find_support_file('Plugins').encodingresult?
With admin powers, open the Plugins folder returned by this.
Back up one step and select its icon...
Right-click > Context-menu > Properties > Security > Edit...
Should be preset to the default FULL - if not change it...Find the
Sketchup.exefile in the mainC:/Programs Files/SketchUp/SketchUp 2014/folder...
Right-click > Context-menu > Properties > Compatibility > Privilege Level pane > tick the 'Run this program as an administrator' optionFind the Lib Fredo .rb and subfolder and physically remove it from Plugins.
This ensures a fresh install with no incompatible files left around...
Install the latest version of it either from the RBZ using Preferences > Extensions > Install... button, or using the SketchUcation PluginStore dialog within SketchUp...
Restart SketchUp...
Report results...
NEVER install older versions from say v2013 Plugins or an older RBZ - get the latest versions, which are specifically updated to be v2014 compatible.
Try the equivalent manual removal for any Fredo plugins, and reinstall then one at a time from their latest RBZs until you get an issue - then report back...
My installations are all the latest versions. I have deleted ALL my plugins all fredo directories and files and reinstalled just LibFredo and Fredo Scale from the extension warehouse, same result. Have enabled Sketchup to run as administrator, the default in the folder is set to full. I'll do a clean install of Sketchup 2014.
Those results are expected.
No issues.
Are you sure you have deleted all of the Plugins from the 2104 Plugins folder
Delete ALL of the Fredo folders/files [again!].
Restart SketchUp 2014.
You should now only get the basic su_ files loading...Download the SketchUcation Plugin Store toolset...
http://sketchucation.com/resources/plugin-store-download
Install it using the Preferences > Extensions > Install... button...
Restart SketchUp to make sure it completes the installation...Use the SketchUcation PluginStore [within SketchUp] to AutoInstall the 'Lib Fredo'...
Tip: use the disalog's filters/search tools to find its AutoInstall entry.
Next do the same to AutoInstall one of Fredo's plugins [like Fredo Scale].
Restart SketchUp to make sure it completes the installation...Now what happens ?
NEW RELEASE: LibFredo6 v5.8c - 17 Apr 14
LibFredo6 5.8c is a release for MoveAlong 1.0, which is just published as part of FredTools 1.8c.
See main post of this thread for Download.
Fredo
Hello Fredo,
Love your Plugins, thank you!
I keep getting this message..."libfredo6 will be updated at next startup of sketchup.I have tried reloading, deleting obsolete files etc etc.
Can you help me figure out what is going on?
Best BPplus the following:(after I get the initial libfredo update warning.
Error Loading File C:/Users/Bob/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DBUR_UcsManager/dbur_ucs
Could not find included file 'C:/Users/Bob/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DBUR_UcsManager/dbur_ucs'
Error Loading File C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager/DBUR_UcsManager.rb
Error: #<NameError: uninitialized constant DBUR_Ucs>
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager/DBUR_UcsManager.rb:10:in<top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inrequire'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inload' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager.rb:12:inregister_extension'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager.rb:12:in<top (required)>' Error: c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: invalid multibyte char (UTF-8) c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: invalid multibyte char (UTF-8) c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: syntax error, unexpected end-of-input, expecting keyword_end data="90¡M5lªÙ[:}¶ä^-Ú¢ßÓjt@+¡©tp}x±" #just garbage ^ C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:ineval'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:inload' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:inmodule:Artisan'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:3:in<module:DM>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:1:in<top (required)>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inrequire' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inload'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:18:inregister_extension' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:18:inmodule:Artisan'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:5:in<module:DM>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:4:in<top (required)>'
Error Loading File Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:368:inmatch' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:368:inblock (2 levels) in load_from_config'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:367:ineach' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:367:inblock in load_from_config'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:366:inforeach' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:366:inload_from_config'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:726:inblock in load_all_plugins' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:726:ineach'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:726:inload_all_plugins' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:438:inload_from_config'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6.rb:181:instartup' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6.rb:299:inmodule:LibFredo6'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6.rb:31:in<top (required)>' Error Loading File C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx/landfx_loader.rb Error: #<TypeError: no implicit conversion of nil into String> C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx/landfx_loader.rb:1:inload'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx/landfx_loader.rb:1:in<top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inrequire'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inload' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx.rb:9:inregister_extension'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx.rb:9:in<top (required)>' Error: #<NoMethodError: undefined methoddowncase' for nil:NilClass>
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Sketchup.rb:36:infile_loaded?' c:/program files (x86)/sketchup/sketchup 2014/tools/piga_richsection/richsection.rbs:997:inmodule:RSection'
c:/program files (x86)/sketchup/sketchup 2014/tools/piga_richsection/richsection.rbs:65:in<module:PiGa>' c:/program files (x86)/sketchup/sketchup 2014/tools/piga_richsection/richsection.rbs:64:in<main>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:ineval' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inrequire'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inload' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/PiGa_RichSection.rb:37:inregister_extension'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/PiGa_RichSection.rb:37:in<module:RSection>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/PiGa_RichSection.rb:26:inmodule:PiGa'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/PiGa_RichSection.rb:25:in<top (required)>' Error: #<Errno::ENOENT: No such file or directory - C:/Users/Bob/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Oscar/OSC_Language.lag> c:/program files (x86)/sketchup/sketchup 2014/tools/oscoolean.rbs:790:inreadlines'
c:/program files (x86)/sketchup/sketchup 2014/tools/oscoolean.rbs:790:infilter_texts' c:/program files (x86)/sketchup/sketchup 2014/tools/oscoolean.rbs:806:inclass:OSCtb'
c:/program files (x86)/sketchup/sketchup 2014/tools/oscoolean.rbs:780:in<main>' -e:1:ineval' -
Hi Bob, you've got a lot of errors there and not all are related to Fredo's work. Is it possible you copied plugins from an older SketchUp version? I've got many of those same plugins installed on my PC and I don't get those errors.
Make sure you have the most current versions installed.
New Spanish Language (Spain) file to LibFredo6 - v5.8c - 17 Apr 14
Hi Fredo,
I love all your plugins but I'm having some problems with sketchup 2014, I tried installing LibFredo6 5.8c and keep getting this error
Error: #<LoadError: cannot load such file -- LibTraductor.rb>
C:/Users/Architect34/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:inrequire' C:/Users/Architect34/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in<top (required)>'I also tried deleting everything and clean install from .rbz, also copy and paste but keep getting same error. I also tried installing from sketchucation autoinstall and same problem.
I also copied to Sketchup 2014> Tools folder, and Plugins folder but same problem.
I hope you can help me.
Hopefully you have installed fresh newest versions and not copied old versions across from an earlier SketchUp's Plugins folder !
How have you installed the latest RBZ's ?
Preferences > Extensions > Install... button ? or perhaps AutoInstall with the PluginStore dialog ?
Either way you should end up with a Lib subfolder with many files in it, including something like the one that is reported missing 'Lib6Traductor.rb' [see screenshot] - although your error says 'LibTraductor.rb' with NO '6'! See next...
The lines inFredo6_!LibFredo6.rbto which it refers say:
require 'LibTraductor.rb' if Sketchup.find_support_file('LibTraductor.rb', "Plugins") #Compatibility require 'TOS_Dir_13/LibTraductor_20.rb' if Sketchup.find_support_file('TOS_Dir_13/LibTraductor_20.rb', "Plugins") #Compatibility
So the 'require' should only be called if the 'LibTraductor.rb' file is in the main Plugins folder [or alternatively the old TOS directory].
It should not run with a clean install because the newest versions of Fredo's tools use the alternative translator file in the Lib folder.There should be no such files to cause the 'if' test to be positive ?
Using this in the Ruby Console should returnnil:
If not, then find that rogue file and delete it and retry/restart...I have v2014 and it loads the Lib and all Fredo's tools just fine.
There are neither of these older 'LibTraductor' rb files in the Plugins or an obsolete TOS subfolder.
The 'Lib6Traductor.rb' in the Lib folder does what's needed...
NEW RELEASE: LibFredo6 v5.9a - 15 May 14
LibFredo6 5.9a is a release for:
- DrawAlong 1.0,
- MoveAlong 1.1,
which are just published as part of FredTools 1.9a.
See main post of this thread for Download of LibFredo6.
Fredo
New Spanish Language File for LibFredo6 - v5.9a - 15 May 14
P.S: If you have like preference Spanish Language (Spain) simply change the ES in filename to --> SP
NEW RELEASE: LibFredo6 v5.9b - 17 May 14
LibFredo6 5.9b is a release for:
- DrawAlong 1.0b,
- MoveAlong 1.1b,
which are published as part of FredTools 1.9b.
This small updates
- fixes a problem for VCB input with architectural units (like 5'2 1/4) for DrawAlong, MoveAlong and JointPushPull
- includes an updated translation in Spanish-Spain (ES) by Oxer
Fredo
If I open a new clean copy of SketchUp, everything loads fine. If I open a file directly from Windows Explorer, I get this error, which in turn prevents all Fredo plugins from opening.
Register LoginAdvertisement
