[Plugin Library] LibFredo6
Good evening, I recently upgraded to SKP 2025 and have migrated all the plugins; I am trying to use them but while they are on the ribbon, they do not open or function; I have licences for them; please assist
Could you open the Ruby Console before launching the tools, in order to track possible errors.
Good day, I have upgraded to SKP 25 and migrated the plugins; as indicated I also downloaded the bugfix, but am struggling to get the plugins to function at all. I keep getting warning messages and while the window loads for the function, it doesn't work.
I use predominantly Curviloft / Joint push pull / FredoCorner -
When you say you 'migrated' the plugins, did you install them from scratch using the ExtensionStore³ dialog, or from RBZs downloaded from the PluginStore ?
What are the 'warning messages' ? Knowing these would be most helpful...PS: Don't give your email address in a public forum, some spam-bot may have already scraped it up. I've obfuscated it a bit, but you might want to do it yourself.
Conversations through forum posts are the most effective, Chats [PMs] can be used if you are providing confidential stuff, emails are a last resort - for licensing problems etc... -
It would be good that you show the warning messages.
Anyway, could you invoke the menu Window > LibFredo6 Settings... > Fredo6 Plugins information for Sketchucation Support.
This will list my plugins installed and their status. Just copy / paste the text and post it here.
@fredo6 said in [Plugin Library] LibFredo6 - v15.2a - 12 Mar 25:
IMPORTANT: from now on, LibFredo6 and all my plugins are ONLY maintained for SU2017 and above. If you run a legacy version of Sketchup (up to SU2016), you can find the frozen legacy versions of LibFredo6 and my plugins here.
The information on LibFredo6 is maintained on the Plugin Home Page of LibFredo6. This is also where you can download the RBZ file.
- Sketchup version: SU2017 and above (for Mac M1, SU2021 and above)
- Platform: Windows and Mac OSX
- Usage: Free
If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video:
LibFredo6 is a shared plugin library used by most of my plugins. LibFredo6 takes care, among others, of enriching my plugins with a few capabilities such as default parameters, language translation, Check Plugins for Update, Trace logging, etc.
It is NOT a standalone plugin. It must be installed once and updated as needed when new versions are published.
I have Sketchup 2025 and the plugin cannot be installed whatever I do.
@gkont1983
How have you tried to install Libredo6 ?
The two ways are:
Download its RBZ from the PluginStore, then use the Extension manager to Install it. After that restart SketchUp to sync everything.
Or use the SketchUcation toolset ExtensionStore dialog to find it, click to auto-install it - sidestepping the RBZ download. After that restart SketchUp to sync everything.
You need the SketchUcation toolset installed for the SCF licensing etc - especially of many of Fredo's extensions.
So I recommend you download its RBZ from the PluginStore, then use the Extension manager to Install it. After that restart SketchUp to sync everything.
After that always use the ExtensionStore dialog to install future extensions - it's vital for licensing, but it offers lots of other perks too... -
I just downloaded LibFredo6 rbz file then went to extension warehouse in Sketch Up to install and enable it, then restarted Sketch Up, but I don't see the extension in my tools palette where all the other extensions are? What am I doing wrong?
Libfredo is a library that is used by Fredo's other extensions. On its own it serves no purpose.
It resides under Window > Libfredo Settings
NEW RELEASE: LibFredo6 v15.3a - 02 Apr 25
LibFredo6 15.3a is a major release. It includes changes related to:
- JointPushPull v4.9a
- Bug Fixing and technical adjustments
Requirements: SU2017 and above
See plugin home page of LibFredo6 for Download of LibFredo6.
@Rich-O-Brien So I need to download the entire Fredo library?
Libfredo is the engine his other extensions require to function.
You can download whatever other of Fredo’s extensions you want.
NEW RELEASE: LibFredo6 v15.3c - 17 Apr 25
LibFredo6 15.3c is a minor release. It includes changes related to:
- ROB Axyz
I'm having a problem after a crash. all of a sudden SketchUp keeps crashing when loading my plugins. I've deleted LibFredo6 and it will open. Then ill re install it and it will crash. do you have any advice? -
@TeKnoel I've been working on a fresh install of all my plugins it seems the conflict might be s4u frame and scene exporter. i just deleted that one and it seems to be loading most of my stuff again
This is the first time i uploades plug-ins.
The download and installation went well (even though normally i have to ask the administrator).
I can see the LibFredo6 settings under tab Windows
But how do i get the toolbar on my workspace? I don't see it... in the video it shows the LibFredo6 toolbar.
LibFredo is a helper library. On its own it does very little and does not need a toolbar.
You need to install Fredo extensions that use it.
NEW RELEASE: LibFredo6 v15.4a - 13 May 25
LibFredo6 15.4a is a minor release. It includes changes related to:
- LayOps v1.1 (dual Dimensions in Layout)
Every time use Roundcorner 3.4a after select conner then press enter ,theSketchup2025 always turn off
XXX note i already update to LibFredo 15.4a
Which platform?
Do you get a bugsplat?
Does it happen with any model?
Register LoginAdvertisement
