    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
    • fredo6F Offline
      fredo6
      @massimo said:
      Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
      Strange. Are you sure?
      I checked that the Zip file does not have any reference to LibFredo6_Dir_32. So, could it come from your installation ?
      Thanks to advise
      Fredo
      • massimoM Offline
        massimo Moderator
        Not installed yet. The downloaded zip file contains a LibFredo6_Dir_33 folder, a LibFredo6 file plus another LibFredo6_Dir_32 folder with an empty IMAGES_Standard sub-folder. At least in my download. ๐Ÿ˜„
        But i believe i have simply to remove it.
        • fredo6F Offline
          fredo6
          Can you then install it (Open Zip file, Select All, Extract in Plugins folder) and check whether you have any trace of the LibFredo6_Dir_32 in the folder created.
          I did it on several machines, and no trace of the old folder.
          • massimoM Offline
            massimo Moderator
            Hmmm really strange. I overwrote the Libfredo_32 empty folder on the existing folder and now it's no more empty ...
            This is what i have after the download.
            • massimoM Offline
              massimo Moderator
              And this is the contents of the Libfredo_32 folder. And the IMAGES folder is empty. But i imagine i can delete any previous LibFredo.
              • fredo6F Offline
                fredo6
                If you have a LibFredo6_Dir_33 folder in good shape, you can indeed remove the folder of the previous version LibFredo6_Dir_32.
                By the way, are you able to run the scripts like RoundCorner 2.1 and my other scripts after your installation ?
                • massimoM Offline
                  massimo Moderator
                  I have deleted LibFredo6_Dir_32 and, after a quick test, RoundCorner and FredoScale seem to work fine. Thanks. ๐Ÿ˜„
                  • I Offline
                    iamarchitecture
                    Thanks Fredo
                    • O Offline
                      oblin77
                      Hello again
                      Where can I find this group of plugin : RoundCorner 2.1, GhostComp 1.0 and ToolsOnSurface 1.5
                      I would like to change my soft and I've seen your plugin
                      wonderfull
                      Thank
                      Olivier
                      • Jean-FrancoJ Offline
                        Jean-Franco
                        Dear Olivier,
                        you can find a collection of plugins here: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
                        They are sorted in a way you should understand easily.
                        And you can also have a look at there: http://www.sketchucation.com/extensions-index/
                        Jean-Franco
                        • fredo6F Offline
                          fredo6
                          Escargot,
                          Pas d'affichage. C'est juste une librairie de code Ruby commune a certains de mes scripts, le premier de cette famille etant FreeScale.
                          Fredo
                          • fredo6F Offline
                            fredo6
                            NEW VERSION 3.3a - 27 Aug 09
                            Needed for for RoundCorner 2.1, GhostComp 1.0 (and compatible for FredoScale and HoverSelect).
                            Small evolutions (some for Palettes), bug fixing, ...
                            see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                            • fredo6F Offline
                              fredo6
                              NEW VERSION 3.4a - 17 Sep 09
                              Needed for Tools On Surface v1.5 (and compatible for FredoScale, RoundCorner 2.1, GhostComp 1.0 and HoverSelect).
                              Small evolutions (mainly for Palettes), bug fixing, ...
                              • N Offline
                                notareal
                                • Bob JamesB Offline
                                  Bob James
                                  Fredo Tools alive and well on MacPro/Leopard (Tools on Surface, Round Corner, Joint Push-Pull)
                                  • fredo6F Offline
                                    fredo6
                                    [Upgrade 08 Oct 09] LibFredo6 3.4b
                                    Complement of Plugin translation to Spanish by Gaonirico (previous was done by Pichuneke).
                                    See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                                      SimonSTJ
                                      whwrw can I find (download libfredo6 3.3a or higher..?
                                        SimonSTJ
                                        Hi.. Can you tell me where can I find libfredo6 3.3a or higher..?
                                        • massimoM Offline
                                          massimo Moderator
                                          Hi Simon, go to the bottom of the very first post of this thread. You will find something like this...(see below)
                                            SimonSTJ
                                            Thanks.. I've been doing that for the las 2 days hoping that I'll find something like that.
                                            Thank you again..I'll try to install it right now and if I have any problems I'll wright to you again.. ๐Ÿ˜„
                                            • 6
                                            • 112
                                            • 113
                                            • 4 / 113
