[Plugin Library] LibFredo6
I can find no place to download 3.2a
… Bottom of first post of this thread.
Clicking on that just takes me back the same page
The attachment at the bottom of the first post.
Maybe I should change my user name to "Dumb and Dumber".
The only thing at the bottom of the first post "[Plugin RoundCorner 2.0a - 9 Jul 09]" was
RoundCorner 2.0a and Quickcard RoundCorner - English - v2.0.pdf.At the top of that post was:
"RoundCorner .......requires you also upgrade to LibFredo6 3.2a or higher. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178".That took me to this post where there is no LibFredo6 3.2a download
Hi Bob
at then end of the first post in this 3D there's the attachment with the new Libraries
through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
I answered your question in the main thread related to RoundCorner.
See http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=172147#p172147LibFredo6 is just a shared library, common to my scripts (and used by FredoScale and HoverSelect). It does not contain anything specific to RoundCorner.
@cosedimarco said:
Hi Bob
Egads!! Was that there all the time. Arrrggghhh.
The bend modifier seems to add a load of geometry to things. : [
You're the man!!!
Fredo,
I work on Macintel + macOSX and nothing work (nothing appear) on SKP7 pro !!
I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b.
I have put them in the right folder : Both in plugins file inside Application support file path.Merci Fredo pour ta reponse et (pour l'ensemble de ton oeuvre) car il me tarde d'utiliser tes plugins sous Mac !!.
Bye,
Pierre.
I have put them in the right folder : Both in plugins file inside Application support file path.Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in /user/Librairy /Application support/ etc...
Ce que j'ai fait, et tout baigne nickel (comme disent les français).
Fredo must be complimented .... again. -
That certainly is true of Profile Builder and Podium, but LibFredo6.rb works just fine in the usual place (Mac/Library/Applications Support/Google SketchUp 7/plugins).
Hi Fredo. Where can I find new version of Tools on surface?
Not yet ready. It will be a refresh, with a palette for better visualizing the options, some improvements to the Freehand tool and a few other evolutions.
Fredo
Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
Sorry what is "GhostComp 1.0"?
Dear Pilou, have a look here
http://forums.sketchucation.com/viewtopic.php?f=180&t=21469 -
Ah bouffre!
Register LoginAdvertisement
