    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • B
      BTM
      @bob james said:
      I can find no place to download 3.2a
      … Bottom of first post of this thread.
      • Bob JamesB
        Bob James
        Clicking on that just takes me back the same page ❓
        • B
          BTM
          The attachment at the bottom of the first post.
          • Bob JamesB
            Bob James
            Maybe I should change my user name to "Dumb and Dumber".
            The only thing at the bottom of the first post "[Plugin RoundCorner 2.0a - 9 Jul 09]" was
            RoundCorner 2.0a and Quickcard RoundCorner - English - v2.0.pdf.
            At the top of that post was:
            "RoundCorner .......requires you also upgrade to LibFredo6 3.2a or higher. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178".
            That took me to this post where there is no LibFredo6 3.2a download ❓
            • COSEDIMARCOC
              COSEDIMARCO
              Hi Bob
              at then end of the first post in this 3D there's the attachment with the new Libraries 😄
              [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
              • free agentF
                free agent
                through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
                http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                • fredo6F
                  I answered your question in the main thread related to RoundCorner.
                  See http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=172147#p172147
                  LibFredo6 is just a shared library, common to my scripts (and used by FredoScale and HoverSelect). It does not contain anything specific to RoundCorner.
                  • Bob JamesB
                    Bob James
                    @cosedimarco said:
                    Hi Bob
                    Egads!! Was that there all the time. Arrrggghhh.
                    • Z
                      Zante
                      The bend modifier seems to add a load of geometry to things. : [
                      • szaniniS
                        szanini
                        You're the man!!!
                        • P
                          pierrearchi
                          Fredo,
                          I work on Macintel + macOSX and nothing work (nothing appear) on SKP7 pro !! 😒 😒 😒
                          I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b.
                          I have put them in the right folder : Both in plugins file inside Application support file path.
                          Merci Fredo pour ta reponse et (pour l'ensemble de ton oeuvre) car il me tarde d'utiliser tes plugins sous Mac !!.
                          Bye,
                          Pierre.
                          • mariochaM
                            mariocha
                            Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in /user/Librairy /Application support/ etc...
                            Ce que j'ai fait, et tout baigne nickel (comme disent les français). 👍
                            Fredo must be complimented .... again.
                            %(#008000)[Mario C.
                            • Bob JamesB
                              Bob James
                              That certainly is true of Profile Builder and Podium, but LibFredo6.rb works just fine in the usual place (Mac/Library/Applications Support/Google SketchUp 7/plugins).
                              • COSEDIMARCOC
                                COSEDIMARCO
                                Hi Fredo. Where can I find new version of Tools on surface?
                                • fredo6F
                                  Not yet ready. It will be a refresh, with a palette for better visualizing the options, some improvements to the Freehand tool and a few other evolutions.
                                  • massimoM
                                    massimo Moderator
                                    Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
                                      Sorry what is "GhostComp 1.0"? 😳
                                      • Jean-FrancoJ
                                        Jean-Franco
                                        Dear Pilou, have a look here 😉
                                        http://forums.sketchucation.com/viewtopic.php?f=180&t=21469
                                        Jean-Franco
                                          Ah bouffre! 💚 😎 ☀
                                          • fredo6F
                                            Strange. Are you sure?
                                            I checked that the Zip file does not have any reference to LibFredo6_Dir_32. So, could it come from your installation ?
                                            Thanks to advise
                                            • 113
                                            • 114
                                            • 3 / 114
