    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • fredo6F
      It seems to be because LibFredo6 is not loaded. Do you have a file LibFredo6.rb in the Sketchup Plugins directory?
        mfseeker
        Yes.
        The file "LibFredo6.rb" is here "C:\Program Files\Google\Google SketchUp 7\Plugins"
        The size is "3.03 KB (3,108 bytes)"
        The modification date is "Tuesday, February 10, 2009, 9:29:56 PM"
        • fredo6F
          Then, I would suggest you resinstall with the Zip files, because your current settup is missing something, or files may not be in the right place.
          For FreeScale, the footprint at the Sketchup Plugin Directory level should be
          Although you don't really have to care, here is the inside. But the rule is not to modify or rename any of the files.
          I hope this helps.
            mfseeker
            You were right, of course. I was missing files. Once, I found the latest I was able to install and run FreeScale. Thanks so much for your help.
            The reason I found your wonderful plugin in the first place was that I was looking for a way to model bending 1 1/2" x 1 1/2" x 78" vertical wooden elements so that their tops would be offset in both the x and y directions by perhaps 4", creating a gentle bow.
            When I try the Radial bending tool, what I get is not a curved bend (similar to the one shown in the tool's icon) but a skewing. The documentation didn't help me. What am I missing?
              mfseeker
              Ah, I found the video. Bend works with embedded slice F4. Thanks.
                mpowell1234567890
                Wow! This plugin is amazing. Love it a lot - very easy to use too. When is the next update?
                [Edit - 04 May 09 - 23:00 CET-> LibFredo6 3.1f]
                bug fixing for Mac compatibility and updated Italian translation. Required by FreeScale 2.0f. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
                [Edit - 28 Apr 09 - 22:20 CET-> LibFredo6 3.1e]
                bug fixing required by FreeScale 2.0e. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
                [Edit - 17 Apr 09 - 06:05 CET-> LibFredo6 3.1d]
                bug fixing required by FreeScale 2.0d. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
                [Edit - 11 Apr 09 - 16:25 CET-> LibFredo6 3.1c]
                various bugs fixed and some small evolutions required by FreeScale 2.0c.
                NOTE: again, download the zip file, Open it, then Select All, then Extract in the Sketchup Plugins folder, answering YES to any request for replacing files. This way you are sure to recreate the proper folder hierarchy.
                [Edit - 01 Apr 09 - 08:30 CET-> LibFredo6 3.1b] various bugs fixed and some small evolutions required by FreeScale 2.0b. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
                LibFredo6 is a Shared Library which is used by some of my scripts. The first one to use it is FreeScale. It used to be called LibTraductor in previous times.
                Version 3.1 or higher is necessary to run FreeScale 2.0
                As a user, you should not bother too much, except to install it and respect the versions required by the Plugins. The current version of LibFredo6 is 3.1 (so 31 in integer form). I maintain backward compatibility so plugins using an older version of LibFredo6 should work with a new version.
                LibFredo6 takes care, among others, of enriching the plugin with a few capabilities:
                • Default parameters
                • Language translation via external files (please, read the doc if you wish to contribute)
                • Extra information and external links available in the “About…” box and menus
                LibFredo6 installs a submenu “LibFredo6 Settings…” in the Sketchup Windows menu. It contains a command to set the language preferences, to set a few default parameters (inference colors) and to access the documentation (as a PDF).
                • fredo6F
                  NEW VERSION 3.2a
                  Needed for for RoundCorner 2.0 (and compatible for FredoScale and HoverSelect).
                  see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                    matteo
                    Thank you very much for this essential tool.
                    hire me: http://www.nonsolo3d.it/ !
                    • Bob JamesB
                      Bob James
                      I can find no place to download 3.2a
                      • B
                        BTM
                        … Bottom of first post of this thread.
                        • Bob JamesB
                          Bob James
                          Clicking on that just takes me back the same page ❓
                          • B
                            BTM
                            The attachment at the bottom of the first post.
                            • Bob JamesB
                              Bob James
                              Maybe I should change my user name to "Dumb and Dumber".
                              The only thing at the bottom of the first post "[Plugin RoundCorner 2.0a - 9 Jul 09]" was
                              RoundCorner 2.0a and Quickcard RoundCorner - English - v2.0.pdf.
                              At the top of that post was:
                              "RoundCorner .......requires you also upgrade to LibFredo6 3.2a or higher. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178".
                              That took me to this post where there is no LibFredo6 3.2a download ❓
                              • COSEDIMARCOC
                                COSEDIMARCO
                                Hi Bob
                                at then end of the first post in this 3D there's the attachment with the new Libraries 😄
                                [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                • free agentF
                                  free agent
                                  through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
                                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                  • fredo6F
                                    I answered your question in the main thread related to RoundCorner.
                                    See http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=172147#p172147
                                    LibFredo6 is just a shared library, common to my scripts (and used by FredoScale and HoverSelect). It does not contain anything specific to RoundCorner.
                                    • Bob JamesB
                                      Bob James
                                      @cosedimarco said:
                                      Hi Bob
                                      Egads!! Was that there all the time. Arrrggghhh.
                                      • Z
                                        Zante
                                        The bend modifier seems to add a load of geometry to things. : [
                                        • szaniniS
                                          szanini
                                          You're the man!!!
                                          • P
                                            pierrearchi
                                            Fredo,
                                            I work on Macintel + macOSX and nothing work (nothing appear) on SKP7 pro !! 😒 😒 😒
                                            I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b.
                                            I have put them in the right folder : Both in plugins file inside Application support file path.
                                            Merci Fredo pour ta reponse et (pour l'ensemble de ton oeuvre) car il me tarde d'utiliser tes plugins sous Mac !!.
                                            Bye,
                                            Pierre.
                                            • 113
                                            • 114
                                            • 3 / 114
