    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.0m Views 585 Watching
    • Bob JamesB
      Bob James
      The attachment at the bottom of the first post.
      Maybe I should change my user name to "Dumb and Dumber".
      The only thing at the bottom of the first post "[Plugin RoundCorner 2.0a - 9 Jul 09]" was
      RoundCorner 2.0a and Quickcard RoundCorner - English - v2.0.pdf.
      At the top of that post was:
      "RoundCorner .......requires you also upgrade to LibFredo6 3.2a or higher. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178".
      That took me to this post where there is no LibFredo6 3.2a download ❓
      • COSEDIMARCOC
        COSEDIMARCO
        Hi Bob
        at then end of the first post in this 3D there's the attachment with the new Libraries πŸ˜„
        [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
        • free agentF
          free agent
          through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          • fredo6F
            I answered your question in the main thread related to RoundCorner.
            See http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=172147#p172147
            LibFredo6 is just a shared library, common to my scripts (and used by FredoScale and HoverSelect). It does not contain anything specific to RoundCorner.
            • Bob JamesB
              Bob James
              @cosedimarco said:
              Hi Bob
              Egads!! Was that there all the time. Arrrggghhh.
              • Z
                Zante
                The bend modifier seems to add a load of geometry to things. : [
                • szaniniS
                  szanini
                  You're the man!!!
                  • P
                    pierrearchi
                    Fredo,
                    I work on Macintel + macOSX and nothing work (nothing appear) on SKP7 pro !! πŸ˜’ πŸ˜’ πŸ˜’
                    I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b.
                    I have put them in the right folder : Both in plugins file inside Application support file path.
                    Merci Fredo pour ta reponse et (pour l'ensemble de ton oeuvre) car il me tarde d'utiliser tes plugins sous Mac !!.
                    Bye,
                    Pierre.
                    • mariochaM
                      mariocha
                      Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in /user/Librairy /Application support/ etc...
                      Ce que j'ai fait, et tout baigne nickel (comme disent les franΓ§ais). πŸ‘
                      Fredo must be complimented .... again.
                      %(#008000)[Mario C.
                      • Bob JamesB
                        Bob James
                        That certainly is true of Profile Builder and Podium, but LibFredo6.rb works just fine in the usual place (Mac/Library/Applications Support/Google SketchUp 7/plugins).
                        • COSEDIMARCOC
                          COSEDIMARCO
                          Hi Fredo. Where can I find new version of Tools on surface?
                          • fredo6F
                            Not yet ready. It will be a refresh, with a palette for better visualizing the options, some improvements to the Freehand tool and a few other evolutions.
                            • massimoM
                              massimo Moderator
                              Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
                                Sorry what is "GhostComp 1.0"? 😳
                                • Jean-FrancoJ
                                  Jean-Franco
                                  Dear Pilou, have a look here πŸ˜‰
                                  http://forums.sketchucation.com/viewtopic.php?f=180&t=21469
                                  Jean-Franco
                                    Ah bouffre! πŸ’š 😎 β˜€
                                    • fredo6F
                                      Strange. Are you sure?
                                      I checked that the Zip file does not have any reference to LibFredo6_Dir_32. So, could it come from your installation ?
                                      Thanks to advise
                                      • massimoM
                                        massimo Moderator
                                        Not installed yet. The downloaded zip file contains a LibFredo6_Dir_33 folder, a LibFredo6 file plus another LibFredo6_Dir_32 folder with an empty IMAGES_Standard sub-folder. At least in my download. πŸ˜„
                                        But i believe i have simply to remove it.
                                        • fredo6F
                                          Can you then install it (Open Zip file, Select All, Extract in Plugins folder) and check whether you have any trace of the LibFredo6_Dir_32 in the folder created.
                                          I did it on several machines, and no trace of the old folder.
                                          • massimoM
                                            massimo Moderator
                                            Hmmm really strange. I overwrote the Libfredo_32 empty folder on the existing folder and now it's no more empty ...
                                            This is what i have after the download.
                                            • 112
                                            • 113
                                            • 3 / 113
