    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
      @maxosmedia said:
      Hm... where is "download" button?
      Hm...It helps to look at the first post of the thread to which Fredo linked.
      • M
        maxosmedia
        Thanks Dave R! But, you links is for LibFredo6_v6.8
          The current version is available in the SCF Plugin Store as described in the first post of this thread. Use the SCF Plugin Store to automatically install it.
          • M
            maxosmedia
            What am I doing wrong?
              Not sure. I just tried it and it worked fine for me. Is it a file association problem? Maybe try clearing the IE caches/temporary internet files and give it another try.
              • M
                maxosmedia
                IE? MacOSX. No file associations problem on OS level
                  Sorry. Clear the Safari caches.
                  • M
                    maxosmedia
                    Safari caches? This screenshot is from SU plugin "Sketcucation plugin store"
                    • TIGT
                      On a PC all of SketchUp's dialogs use Internet-Explorer.
                      On a MAC all of SketchUp's dialogs use Safari.
                      This usage is quite separate from whatever you use for your day-to-day browsing.
                      Like everything else... the SketchUcation PluginStore uses those 'helper' applications for its dialogs...
                      So if you are on a MAC open Safari, then empty its cache...
                      Then restart SketchUp and see if that helps...
                      • M
                        maxosmedia
                        Thanks TIG! Cleaned. No effect, the same bug
                        • D
                          driven
                          when that fails to make a difference you can trash the SU WebKit cache, because it not really Safari...
                          Drag this to Trash...
                          ~/Library/Caches/com.sketchup.SketchUp.2015
                          or whatever version of SU your running [your profile says v8???]
                          • M
                            maxosmedia
                            Thanks driven!
                            SU cache is trashed, SU is restarted, No effect!
                            • D
                              driven
                              well unless your really still on v8, WebDialog seems to not be the issue...
                              I'll try and instal it...
                              john
                              • D
                                driven
                                works with v15, but it's sooo long since I fired up SU v8, SketchUcation Plugin Store shows a 404...
                                maybe later...
                                • D
                                  driven
                                  but it did instal using Preferences >> Instal Extension...
                                  • P
                                    Poot
                                    I installed the joint push pull by rubyscript. And i'm trying to install the lib fredo..... by plugin store.
                                    What am i doing wrong here? I push install in the plugin store then this comes out.
                                    When i restart sketchup he says this?
                                    • fredo6F
                                      fredo6
                                      A priori, you need to install LibFredo6 6.9. Did you do it (if so, you should see a submenu "LibFredo6 Settings..." in the Window menu of Sketchup.
                                      Fredo
                                      • TIGT
                                        The clue is in the message.
                                        First load the latest LibFredo, then whatever Fredo's tools you use.
                                        [Because the Lib has changed you need the latest tools too]
                                        Finally restart SketchUp to complete the installations...
                                        • P
                                          Poot
                                          Hi guys,
                                          Thanks for the fast reply's but i think that it's going wrong on the first pic.
                                          Pc says as you see on the pic:
                                          You can write to main plugins folder, and...
                                          You have a costum plugins folder.
                                          then he give's the two folders but i can not pick one,
                                          I have pressed enter and every button on my keyboard so i don't undestand how i properly can instal the fredo 6.3 tools. Ore choose the correct folder what is going wrong here?
                                          Thanks in advance,
                                          Sam
                                          • P
                                            Poot
                                            Fixed it, i made the most obvious mistake ever. (schame shame shame πŸ˜• )
                                            I just needed to make the window bigger and choose the correct map.
                                            Thanks again guys!!
