    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.0k Views 135 Watching
      About the perpendicular tool of Chris Fullmer (thx Jeff) โ˜€
      Ahhhhhhhh! Never thought (or remembered)to click on the segment ๐Ÿ˜ฎ ๐Ÿ‘
      That was not explicit due this alert message! ๐Ÿ’š
      http://forums.sketchucation.com/download/file.php?id=55372
      • brookefoxB
        brookefox
        Label endpoints; by default you will be given the coordinates of same.
        ~ Brooke
        • TK0001T
          TK0001
          The day I discovered SHIFT + pressing the scroll wheel = pan was a good day.
          • D
            d12dozr
            It might be a better day when you discover LMB + scroll wheel = Pan as well ๐Ÿ˜‰
            http://goo.gl/f7ooYh
            • TK0001T
              TK0001
              I just tried it. Didn't work.
              ETA: Whoops, yes it does.
              This is the greatest day of my life.
              • DavidBoulderD
                DavidBoulder
                Just stumbled across this. Take a 10' cube, use the scale tool to vertically stretch the cube, and just type a distance. This become the new height for your selected object. You don't need to give it a positive or negative number to say home much smaller or bigger you want it. Just type the size you want it to be. If it happens to be smaller than the existing size, then it will get smaller. This seems more useful on a single axis stretch, but it also works when scaling x,y & z at the same time.
                Don't know how many times I had to divide 10'6 3/4" by 9'3" to figure out the proper scale for something. Actually a long time ago I realized I can snap the stretch to a guide or other geometry so I typically drew a dummy line to snap to, but now I don't even need to do that.
                (update), so I guess it was right there in the online help, but I haven't read that in 5 years
                http://sketchup.google.com/support/bin/answer.py?hl=en&answer=94906
                Other nice tidbits. you can type a negative distance to mirror the object, and if you do a non,uniform 2d or 3d scale, you can type multiple distances, to for example make whatever shape you have drawn, fit in a 20',30',50' bounding box.
                David Goldwasser
                OpenStudio Developer
                  @ DavidB
                  that works also for Move and Rotate ๐Ÿ˜‰
                  • S
                    SketchUpNoobie
                    I used to think you had to click and drag whenever you push/pull, move, rectangle, circle, etc. I just found out a couple of months ago that you could just click, get it where you want it, and click again to finish. I was like, "Oh." ๐Ÿ˜ณ
                    SketchUpNoobie: the complete noob in all things SketchUp.
                    • thomthomT
                      And double-clicking will repeat last operation.
                      • S
                        SketchUpNoobie
                        I know that. ๐Ÿ˜‰ Dunno' when I figured it out though. Probably while watching a tutorial or something. That's why I like watching tutorials even if they are on things I already know.
                        • R
                          Roger
                          It seems that my Duh! moment was taking this long to find this discussion. I have always felt I was the lone idiot, but now I feel much better and much more informed.
                          Thanks DUHsters.
                          http://www.azcreative.com
                          • Chris FullmerC
                            That is the point of the thread - we all feel like the lone idiot...until you post your stupidity publicly and find that many many other people had done, or are doing, the exact same thing. It's very cathartic ๐Ÿ˜„
                            All my Plugins I've written
                            • david_hD
                              david_h
                              Idiots are never alone.
                              They travel in herds. . . .most frequently seen on the great American Freeway system.
                              • TIGT
                                You should suffer fools gladly... one day you will be one of them!
                                I once invented my great new tool for the context-menu that would select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... ๐Ÿ˜ณ
                                  Mine of the day ๐Ÿ’š (thx Regis)
                                  I have found that was a good idea ๐Ÿ’ญ
                                  Draw first the line then use
                                  but... ๐Ÿ’š
                                  you can also with only just enter in the VCB
                                  (whatever unities in activity)
                                  3.14cm
                                  31.4mm
                                  0.0314m
                                  ... (i am not very familiar with inch ๐Ÿ’š
                                  ๐Ÿ˜’
                                    Add to the previous thread ๐Ÿ˜„
                                    I reread the doc (that was written in small that you can enter measure in VCB with the Scale tool! ๐Ÿ˜ณ
                                    And also a cool one (in the same doc)! ๐Ÿ’š
                                    You can Press in the SAME TIME SHIFT AND CTRL with the Scale tool ! ๐Ÿ˜ฎ ๐Ÿ˜ณ ๐Ÿ˜ณ
                                    For have a super scaling result! ๐Ÿ’š
                                    • ToboboT
                                      Tobobo
                                      One this week was more of a remembering than a Duh moment.
                                      Using the Entity Ifon box you can increase the length of a line and No. of sides of a circle.
                                      Toby
                                      Philippians 4:13
                                      • GaieusG
                                        @tobobo said:
                                        ...No. of sides of a circle.
                                        And a polygon and an arc...
                                          In what side? Good or false? ๐Ÿ˜„
                                          • spenceS
                                            spence
                                            One of my many many "Duh" moments came when I found out that while using the Paint Bucket Tool you could hold down Shift to paint all that match or hold Ctrl to paint all connected. I use this often.
                                            Boy I have learned a lot of new stuff from this thread ๐Ÿ˜„
                                            Spence
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 34
                                            • 35
                                            • 13 / 35
