    [Plugin] angle between planes
    12 Posts 11 Posters 13.0k Views 11 Watching
    • daikuD Offline
      daiku
      A simple little plugin that tells you the angle between two planes. Just right click on an edge that joins two faces. If there is exactly one edge selected, and that edge bounds exactly two faces, then a menu item will appear to calculate the angle between the two face planes. The intended use is for woodworkers dealing with compound joinery: this is the angle you set your saw bevel to. But there might be some general appeal as well, so I'm posting it. CB.
      Update 3/7/09:
      Got a great suggestion to simply display the angle right in the context menu, and skip the message box entirely. Also added the supplement of the angle when over 90 degrees.
      plane_angle.rb
      Clark Bremer
      http://www.northernlightstimberframing.com
      • E Offline
        Ecuadorian
        Arigatou Gozaimasu, Bremer-san.
        Already tested it, and works good. Trying to measure such angles with the protractor is awkward.
        -Miguel Lescano
          Thank you for that Clark.
          • boofredlayB Offline
            boofredlay
            Handy, thanks.
              linea
              Very useful. Thanks
                mfseeker
                Many thanks. I was trying to set up a compound saw cut. I had succeeded only after spending a great deal of time drawing various perpendicular lines and extra planes. Your plugin gave me an immediate answer (the same one, thankfully) in a moment.
                  amarkanda
                  I've installed the plugin but I can't seem to find it in google sketchup
                  where would i find it?
                  • massimoM Offline
                    massimo Moderator
                    Have you read the first post Amy? See the picture below. 😄
                      robigoekru Newcomers
                      Ist diese Erweiterung nicht mehr gültig?
                        Trnaslated by Google:
                        @robigoekru said:
                        Is this extension no longer valid?
                        I just tried it in SketchUp 2023 and it works fine. No reason to think it won't work in SketchUp 2017 Make.
                          stephen2850s Newcomers
                          As an architect who uses SU everyday, this is the best plugin since profile builder. speeds up modelling big time. just wish I had found it sooner. thanks Clark
                          Didier BurD 1 Reply Last reply Reply Quote 1
                          • Didier BurD Offline
                            Didier Bur @stephen2850s
                            @stephen2850s :
                            FYI, you can try my Query+ plugin:
                            [https://sketchucation.com/plugin/2654-queryplus](link url)
                            It can give you lots of informations (angles, volumes, distances...) about various objects of your model, not only edges 😉
                            Regards
                            DB
