    [Plugin] angle between planes
    12 Posts 11 Posters 13.5k Views 11 Watching
      Thank you for that Clark.
      • boofredlayB Offline
        boofredlay
        Handy, thanks.
          linea
          Very useful. Thanks
            mfseeker
            Many thanks. I was trying to set up a compound saw cut. I had succeeded only after spending a great deal of time drawing various perpendicular lines and extra planes. Your plugin gave me an immediate answer (the same one, thankfully) in a moment.
              amarkanda
              I've installed the plugin but I can't seem to find it in google sketchup
              where would i find it?
              • massimoM Offline
                massimo Moderator
                Have you read the first post Amy? See the picture below. 😄
                  robigoekru Newcomers
                  Ist diese Erweiterung nicht mehr gültig?
                    Trnaslated by Google:
                    @robigoekru said:
                    Is this extension no longer valid?
                    I just tried it in SketchUp 2023 and it works fine. No reason to think it won't work in SketchUp 2017 Make.
                      stephen2850s Newcomers
                      As an architect who uses SU everyday, this is the best plugin since profile builder. speeds up modelling big time. just wish I had found it sooner. thanks Clark
                      Didier BurD 1 Reply Last reply Reply Quote 1
                      • Didier BurD Offline
                        Didier Bur @stephen2850s
                        @stephen2850s :
                        FYI, you can try my Query+ plugin:
                        [https://sketchucation.com/plugin/2654-queryplus](link url)
                        It can give you lots of informations (angles, volumes, distances...) about various objects of your model, not only edges 😉
                        Regards
                        DB
