    New API doc - typos and questions
    370 Posts 35 Posters 290.9k Views 35 Watching
      remus
      For acolor it's always = 255 [100% opaque]... there is a color.alpha= method but it's never ever worked, you must set alpha [transparency] for a material itself not material.color e.g. material.alpha=0.4 for 40% opacity will work but the material.color.alpha still reports 255 [100%], if you try to change it, it just does nothing !
      So to recap - the fourth item in a SUp material.color array is its alpha [r,g,b,a] but it's not used ! The alpha of the material itself works as a 0 to 1.0, equivalent to % setting of opacity...
      http://code.google.com/apis/sketchup/do ... color.html
        UI.inputbox
        http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#inputbox
        Returns false, not nil when user cancels.
          WebDialog.new
          http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#new
          Two last parameters isn't explained.
            remus
            BoundingBox.min
            returns: a Point3d object representing the point where x, y, and z are the maximum in the bounding box.
            Im guessing it should say minimum.
              WebDialog.get_element_value
              http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#get_element_value
              The example hasn't escaped the HTML tags - so the HTML sample text is instead interpreted by the browser..
                Curve.move_vertices
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/curve.html#move_vertices
                Description says:
                The vertices method retrieves a collection of all vertices in a curve.
                  Tool.enableVCB?
                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html#enableVCB?
                  The enableVCB? method is used to tell SketchUp whether to allow the user to enter text into the VCB (value control box, aka the "measurements" panel). If you do not implement this method, then the vcb is disabled by default.
                  I've never used this method for my Tools. But the VCB has still worked.
                    Image.size=
                    http://code.google.com/apis/sketchup/docs/ourdoc/image.html#size=
                    It appears that the second argument is optional.
                      Entity.entityID
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#entityID
                      The entityID method is used to retrieve a unique ID assigned to an entity.
                      The entityID is not persistent between sessions.
                      Is it persistent within a session? Can it be relied on for the length of one session?
                        ComponentDefinition.guid
                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/componentdefinition.html#guid
                        Is this value persistent between sessions?
                          Jim
                          Sketchup::Color.new
                          new can accept a hex value (not string) as the parameter: for example 0xFF0000 (undocumented)
                          But, it reverses the red and blue values. Here is a Console session. (bug)
                          Sketchup;;Color.new 0xFF0000
                          Color(  0,   0, 255, 255)
                          Sketchup;;Color.new 0x0000FF
                          Color(255,   0,   0, 255)
                          • scottliningerS Offline
                            scottlininger
                            I've got some catching up to do. Thanks for all of the details, guys! 😉
                            • Scott Lininger
                              SketchUp Software Engineer
                              Have you visited the Ruby API Docs?
                              ModelObserver.onDeleteModel vs ModelObserver.onEraseAll
                              http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onDeleteModel
                              When does the onDeleteModel event trigger? I don't think I've ever seen it trigger. When I open an existing model or create a new model onEraseAll is triggered.
                                Jim
                                UI.start_timer
                                This post on the API blog is showing start_timer with a fraction of a second resolution. In my experience, UI.start_timer has a whole second resolution and rounds partial seconds down to the nearest second.
                                    t1=Time.now; UI.start_timer(0.1) {p Time.now-t1} ==> 0.01
                                    t1=Time.now; UI.start_timer(0.999) {p Time.now-t1} ==> 0.01
                                    t1=Time.now; UI.start_timer(1) {p Time.now-t1} ==> 1.001
                                    t1=Time.now; UI.start_timer(1.9) {p Time.now-t1} ==> 1.002
                                  Jim
                                  Point3d.linear_combination
                                  Uses example from Geom.linear_combination.
                                  I would guess the Point3d.linear_combination would only take 2 arguments - the weight, and other point since the first point is the receiver of the method.
                                    MaterialsObserver
                                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/materialsobserver.html
                                    Observer events that doesn't trigger:
                                    Sketchup 6
                                    onMaterialChange*
                                    onMaterialRefChange
                                    Sketchup 7
                                    onMaterialChange*
                                    onMaterialRefChange
                                    onMaterialSetCurrent
                                    • Only triggers when the name changes. Not when any of the other properties changes.
                                      Jim
                                      Group.move!
                                      This method is the same as the transform! method except that it does not record the move in an undo operation. This method is useful for transparently moving things during an animation.
                                      .move! resets the rotational and scaling components of the receiver's transformation, and does not result in the same final translation as using .transform!
                                        Layer.page_behavior vs Layer.page_behavior=
                                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                                        The flag values seems to contradict between descriptions of the two methods.
                                          Pages.add_frame_change_observer
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/pages.html#add_frame_change_observer
                                          I don't find any more info on this FrameChange observer. Missing documentation?
                                          The argument is an object that implements a method frameChange with the following form:
                                          But then there's no example. And no FrameChange observer is listed in the Observer list.
                                            Transformation.to_a
                                            http://code.google.com/apis/sketchup/docs/ourdoc/transformation.html#to_a
                                            It would be every helpful if this listed the many items in this array and explained which each of them represents
                                            e.g. tra[14]= Z value
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 18
                                            • 19
                                            • 7 / 19
