    New API doc - typos and questions
    370 Posts 35 Posters 310.7k Views 35 Watching
      UI.menu lists the valid menus titles, one is 'Create' isn't it 'Draw' ?
      • RunnerPackR Offline
        RunnerPack
        Point3d.offset (http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#offset) Description of the length parameter:
        (optional) the distance to offset. If not provided, the offset is my a distance equal to the vector length.
        Suggestion:
        The (optional) offset distance. If not provided, the point is offset a distance equal to the vector's length.
        You might have noticed... I'm a bit of a ferpectionist.
          Face.mesh
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
          The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
          Valid flags are:
          * 0: Include PolygonMeshPoints,
          * 1: Include PolygonMeshUVQFront,
          * 2: Include PolygonMeshUVQBack,
          * 4: Include PolygonMeshNormals.
          Add these numbers together to combine flags. A value of 5 will include all flags, for example.
          The example uses 7. Typo or undocumented feature?
            avariant
            You can bit-wise OR the options together. 7 means 4 + 2 + 1, so normals, front UV, and back UV.
              remus
              For acolor it's always = 255 [100% opaque]... there is a color.alpha= method but it's never ever worked, you must set alpha [transparency] for a material itself not material.color e.g. material.alpha=0.4 for 40% opacity will work but the material.color.alpha still reports 255 [100%], if you try to change it, it just does nothing !
              So to recap - the fourth item in a SUp material.color array is its alpha [r,g,b,a] but it's not used ! The alpha of the material itself works as a 0 to 1.0, equivalent to % setting of opacity...
              http://code.google.com/apis/sketchup/do ... color.html
                UI.inputbox
                http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#inputbox
                Returns false, not nil when user cancels.
                  WebDialog.new
                  http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#new
                  Two last parameters isn't explained.
                    remus
                    BoundingBox.min
                    returns: a Point3d object representing the point where x, y, and z are the maximum in the bounding box.
                    Im guessing it should say minimum.
                      WebDialog.get_element_value
                      http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#get_element_value
                      The example hasn't escaped the HTML tags - so the HTML sample text is instead interpreted by the browser..
                        Curve.move_vertices
                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/curve.html#move_vertices
                        Description says:
                        The vertices method retrieves a collection of all vertices in a curve.
                          Tool.enableVCB?
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html#enableVCB?
                          The enableVCB? method is used to tell SketchUp whether to allow the user to enter text into the VCB (value control box, aka the "measurements" panel). If you do not implement this method, then the vcb is disabled by default.
                          I've never used this method for my Tools. But the VCB has still worked.
                            Image.size=
                            http://code.google.com/apis/sketchup/docs/ourdoc/image.html#size=
                            It appears that the second argument is optional.
                              Entity.entityID
                              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#entityID
                              The entityID method is used to retrieve a unique ID assigned to an entity.
                              The entityID is not persistent between sessions.
                              Is it persistent within a session? Can it be relied on for the length of one session?
                                ComponentDefinition.guid
                                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/componentdefinition.html#guid
                                Is this value persistent between sessions?
                                  Jim
                                  Sketchup::Color.new
                                  new can accept a hex value (not string) as the parameter: for example 0xFF0000 (undocumented)
                                  But, it reverses the red and blue values. Here is a Console session. (bug)
                                  Sketchup;;Color.new 0xFF0000
                                  Color(  0,   0, 255, 255)
                                  Sketchup;;Color.new 0x0000FF
                                  Color(255,   0,   0, 255)
                                  • scottliningerS Offline
                                    scottlininger
                                    I've got some catching up to do. Thanks for all of the details, guys! 😉
                                    • Scott Lininger
                                      SketchUp Software Engineer
                                      Have you visited the Ruby API Docs?
                                      ModelObserver.onDeleteModel vs ModelObserver.onEraseAll
                                      http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onDeleteModel
                                      When does the onDeleteModel event trigger? I don't think I've ever seen it trigger. When I open an existing model or create a new model onEraseAll is triggered.
                                        Jim
                                        UI.start_timer
                                        This post on the API blog is showing start_timer with a fraction of a second resolution. In my experience, UI.start_timer has a whole second resolution and rounds partial seconds down to the nearest second.
                                            t1=Time.now; UI.start_timer(0.1) {p Time.now-t1} ==> 0.01
                                            t1=Time.now; UI.start_timer(0.999) {p Time.now-t1} ==> 0.01
                                            t1=Time.now; UI.start_timer(1) {p Time.now-t1} ==> 1.001
                                            t1=Time.now; UI.start_timer(1.9) {p Time.now-t1} ==> 1.002
                                          Jim
                                          Point3d.linear_combination
                                          Uses example from Geom.linear_combination.
                                          I would guess the Point3d.linear_combination would only take 2 arguments - the weight, and other point since the first point is the receiver of the method.
                                            MaterialsObserver
                                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/materialsobserver.html
                                            Observer events that doesn't trigger:
                                            Sketchup 6
                                            onMaterialChange*
                                            onMaterialRefChange
                                            Sketchup 7
                                            onMaterialChange*
                                            onMaterialRefChange
                                            onMaterialSetCurrent
                                            • Only triggers when the name changes. Not when any of the other properties changes.
                                            • 18
                                            • 19
                                            • 7 / 19
