    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 61.5k Views 28 Watching
      Matt666
      Hi all!
      This plugin can recall last tool used. Based on this request.
      You can use native Sketchup Shortcut function to add a new shortcut. I use F2!
      πŸ˜‰
      All suggestions are welcomed!!
      [EDIT1] This plugin is not compatible with Mac. Sorry. See below if you want to know why. A SU bug for Mac users.
      [EDIT2] v1.2 -> 09/04/2009 : Observer was not always activated before using tool. Thank you Simon Le Bon!
      Plugins/Recall last tool
      Frenglish at its best !
      My scripts
        jmmad
        Thxs Matt works great with Key shortcuts
        Get Upa !
          RickW
          Matt,
          Nice work. My suggestion would be to use class variables (@@Matt_Model_Toolid, @@Matt_Model_Toolid2) or instance variables (@Matt_Model_Toolid, @Matt_Model_Toolid2) rather than global variables. Note that class variables must be declared right after the class is declared:
          	class Matt_Observer < Sketchup;;ToolsObserver
          		@@Matt_Model_Toolid = nil
          		@@Matt_Model_Toolid2 = nil
          		def onActiveToolChanged (tools_object, toolname, toolid)
          			# ETC...
          but instance variables can be delcared anywhere in the class methods.
          RickW
          www.smustard.com
            Matt666
            Hi Rick!
            Thank you for the comment, I've updated the code... πŸ˜‰
            My scripts
            • EarthMoverE Offline
              EarthMover
              Hey Matt - You are eternally my friend! Thanks for listening to my request. I'm sure it will be useful to many!
              Content Creator at Skapeup
                Matt666
                πŸ˜‰
                My scripts
                  Astucieux! 😎
                    Matt666
                    Merci Pilou πŸ˜‰
                    My scripts
                    • EdsonE Offline
                      Edson
                      matt,
                      here we go again. unless i do not know how to use your new script, it is not working on mac! sorry...
                      http://www.mahfuz.arq.br
                        Matt666
                        Hi Edson... I hope you do not know!! I'm cursed...
                        So : Draw a . Draw a . Press space bar for .
                        Go to Plugins/Recall last tool. Rectangle tool is now recalled.
                        If it does not work, can you open your ruby console, and try again, please?
                        And, at last, can you call rectangle tool, and try to copy this code in the ruby console ?
                        Sketchup.send_action(21022)
                        This code calls selection tool.
                        Thank you Edson. And sorry for the inconvenience.
                        My scripts
                        • EdsonE Offline
                          Edson
                          matt,
                          it did not work. i had done it that way before. below is the ruby console reading.
                          glad to help you. keep your requests coming.
                          • BurkhardB Offline
                            Burkhard
                            I read a lot /users/mahfuz... πŸ˜‰
                            http://www.ia-plus.de
                            • P Offline
                              pecan
                              On differenct OS's, even the same OS with different menus, that magic number will have changed.
                              What's wrong with Sketchup.send_action(selectSelectionTool:);
                              When the menu structure is updated, then the call will still work even tho the menu id has changed.
                              • simon le bonS Offline
                                simon le bon
                                Bravo Matt !!
                                at the very beginning of my learning SketchUp, I was surprised not to have this feature at disposal. And then I was accustomed to always recall my tools. And Here comes your ruby. It is as if suddenly we had won a great lightness. (F2 is great)
                                it already belongs to my toolbox. πŸ‘ πŸ‘ πŸ˜„simon
                                  Matt666
                                  Merci Simon ! πŸ˜‰
                                  @pecan said:
                                  On different OS's, even the same OS with different menus, that magic number will have changed.
                                  Hi pecan! Are you sure of that? I use only two different numbers in my code. The rest is a recall of the last number used.
                                  But there's a biiig problem with Mac... On Mac, function "send_action" does not accept integers. Only strings! 😞
                                  @edson said:
                                  It did not work. i had done it that way before. below is the ruby console reading.
                                  Thank you Edson!
                                  Ouch. I will try to find a solution. Can you test this code below, please?
                                  Sketchup.send_action("21022")
                                  My scripts
                                  • EdsonE Offline
                                    Edson
                                    it looks good!
                                      Matt666
                                      Ok. But if you have rectangle tool called, when you copy and validate the code, is the selection tool activated?
                                      My scripts
                                      • EdsonE Offline
                                        Edson
                                        i drew a rectangle, then pressed the space bar, then used the script from the menu. the result is in the picture.
                                          Matt666
                                          Sorry Edson, and all mac users. But I can't do anything with this bug. 😞 Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
                                          My scripts
                                          • P Offline
                                            pecan
                                            Result from SU ruby console
                                            (eval)
                                            result = Sketchup.send_action "selectSelectionTool:"
                                            true
                                            I was in error suggesting it was a num.
                                            • 1 / 3
