    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 62.5k Views 28 Watching
      jmmad
      Thxs Matt works great with Key shortcuts
      Get Upa !
        RickW
        Matt,
        Nice work. My suggestion would be to use class variables (@@Matt_Model_Toolid, @@Matt_Model_Toolid2) or instance variables (@Matt_Model_Toolid, @Matt_Model_Toolid2) rather than global variables. Note that class variables must be declared right after the class is declared:
        	class Matt_Observer < Sketchup;;ToolsObserver
        		@@Matt_Model_Toolid = nil
        		@@Matt_Model_Toolid2 = nil
        		def onActiveToolChanged (tools_object, toolname, toolid)
        			# ETC...
        but instance variables can be delcared anywhere in the class methods.
        RickW
        www.smustard.com
          Matt666
          Hi Rick!
          Thank you for the comment, I've updated the code... ๐Ÿ˜‰
          Frenglish at its best !
          My scripts
          • EarthMoverE Offline
            EarthMover
            Hey Matt - You are eternally my friend! Thanks for listening to my request. I'm sure it will be useful to many!
            Content Creator at Skapeup
              Matt666
              ๐Ÿ˜‰
              My scripts
                Astucieux! ๐Ÿ˜Ž
                  Matt666
                  Merci Pilou ๐Ÿ˜‰
                  My scripts
                  • EdsonE Offline
                    Edson
                    matt,
                    here we go again. unless i do not know how to use your new script, it is not working on mac! sorry...
                    edson mahfuz, architect| porto alegre โ€ข brasil
                    http://www.mahfuz.arq.br
                      Matt666
                      Hi Edson... I hope you do not know!! I'm cursed...
                      So : Draw a . Draw a . Press space bar for .
                      Go to Plugins/Recall last tool. Rectangle tool is now recalled.
                      If it does not work, can you open your ruby console, and try again, please?
                      And, at last, can you call rectangle tool, and try to copy this code in the ruby console ?
                      Sketchup.send_action(21022)
                      This code calls selection tool.
                      Thank you Edson. And sorry for the inconvenience.
                      My scripts
                      • EdsonE Offline
                        Edson
                        matt,
                        it did not work. i had done it that way before. below is the ruby console reading.
                        glad to help you. keep your requests coming.
                        • BurkhardB Offline
                          Burkhard
                          I read a lot /users/mahfuz... ๐Ÿ˜‰
                          http://www.ia-plus.de
                            pecan
                            On differenct OS's, even the same OS with different menus, that magic number will have changed.
                            What's wrong with Sketchup.send_action(selectSelectionTool:);
                            When the menu structure is updated, then the call will still work even tho the menu id has changed.
                            • simon le bonS Offline
                              simon le bon
                              Bravo Matt !!
                              at the very beginning of my learning SketchUp, I was surprised not to have this feature at disposal. And then I was accustomed to always recall my tools. And Here comes your ruby. It is as if suddenly we had won a great lightness. (F2 is great)
                              it already belongs to my toolbox. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„simon
                                Matt666
                                Merci Simon ! ๐Ÿ˜‰
                                @pecan said:
                                On different OS's, even the same OS with different menus, that magic number will have changed.
                                Hi pecan! Are you sure of that? I use only two different numbers in my code. The rest is a recall of the last number used.
                                But there's a biiig problem with Mac... On Mac, function "send_action" does not accept integers. Only strings! ๐Ÿ˜ž
                                @edson said:
                                It did not work. i had done it that way before. below is the ruby console reading.
                                Thank you Edson!
                                Ouch. I will try to find a solution. Can you test this code below, please?
                                Sketchup.send_action("21022")
                                My scripts
                                • EdsonE Offline
                                  Edson
                                  it looks good!
                                    Matt666
                                    Ok. But if you have rectangle tool called, when you copy and validate the code, is the selection tool activated?
                                    My scripts
                                    • EdsonE Offline
                                      Edson
                                      i drew a rectangle, then pressed the space bar, then used the script from the menu. the result is in the picture.
                                        Matt666
                                        Sorry Edson, and all mac users. But I can't do anything with this bug. ๐Ÿ˜ž Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
                                        My scripts
                                          pecan
                                          Result from SU ruby console
                                          (eval)
                                          result = Sketchup.send_action "selectSelectionTool:"
                                          true
                                          I was in error suggesting it was a num.
                                            pecan
                                            Using the tool name should work:
                                                    print tools_object, toolname, toolid
                                            		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
                                            		#@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid)
                                            		@@Matt_Model_Toolid2 = "select#{toolname};";
                                            		puts "1; #{@@Matt_Model_Toolid} 2; #{@@Matt_Model_Toolid2}"
                                            • 1 / 3
