    "Use maximum texture size" option and exporting
    13 Posts 8 Posters 2.3k Views 8 Watching
    • E Offline
      ezdmanx
      In Sketchup 7, when I tick "use maximum texture size" under Preferences > OpenGL -the resolution of a large Aerial photo I have imported onto terrain in my model increases onscreen to the same resolution as the imported Jpeg.
      This is great! as previously Sketchup downgraded imported images which made them look more blurred than the original.
      The problem is when I go to export a Jpeg of the new high resolution model. Sketchup blurs the exported image like before.
      Is there a way of exporting the display with maximum texture?
      Even print screen copies maximum texture resolution.
      Thanks for your help in advance
      • AnssiA Offline
        Anssi
        When I last used it (with version 6), a Photo matched screen would be exported with high resolution, in opposotion to Watermarks that were resized.
        Anssi
          You used it for the background then, didn't you, Anssi?
          • AnssiA Offline
            Anssi
            Yes, I had a moderately high-resolution aerial photo as a photomatch background,
            Anssi
              TriciaS
              Hello,
              Unfortunately, the behavior you are describing, Ezdmanx, is a known limitation of textures/images on the PC. Ansii, background photos, as you noticed, are processed differently, so this limitation does not apply to them.
              For SU7, on the PC, the "Use Maximum texture size" option affects only the display of textures/images on the screen. On the Mac, however, the option affects both the display as well as export/printing. My understanding of the PC limitation is that Microsoft's OpenGL version does not support larger textures and we need to use their limited renderer for printing/exporting as many PC graphics cards don't support off-screen rendering, or don't support it robustly.
              I did check our Help documents and I don't think this is very well documented. I'll request that the documents be updated. Coming up with a solution to this OS related issue is also a feature request that we hope to address in the future.
              Sorry I don't have better news at this point...
              Best regards,
              Tricia
              Google QA
                remus
                Thanks for explaining that tricia, always good to hear it from the horses mouth, as it were.
                  So now you are calling Tricia a horse... πŸ˜’
                  • plot-parisP Offline
                    plot-paris
                      remus
                      Tut tut gai. I considered that but thought youd be mature enough to not pick up on it shakes head in a disapproving manner
                        Never mind - she'll love it! πŸ˜‰
                          TriciaS
                          Easy now. (pulling in on the reigns)
                          Thanks for the laugh!
                          Tricia
                          • V Offline
                            valerostudio
                            Any new developments with this? I saw that there was a new Pro 7 release last week but was disappointed to see that this issue was not addressed. I use large textures as base plans all the time and the biggest complaint I get is that they look "muddy" and the quality is too pixilated. Is there no quick fix for this problem with OpenGL?
                              As Tricia mentioned earlier, it's a limitation in the OpenGL implementation under Windows. So a fix for this would rely on Microsoft...
