    [Plugin] Selection Toys
    594 Posts 121 Posters 495.5k Views 121 Watching
    • tt_suT Offline
      tt_su
      What about Select Curve? http://sketchucation.com/forums/viewtopic.php?p=273423#p273423
      • renderizaR Offline
        renderiza
        There is another plugin installed on my SketchUp that might be conflicting with Selection Toys. It is not letting me add more icons to the toolbar using UI Settings dialog. When I hit save it doesn't close the dialog.
        I tested Selection Toys Plugin without other plugins and it works fine... ๐Ÿ˜•
        There is also other plugins affected by this..."Plugin Store"!...When I try to disable a plugin for it doesn't do nothing.
        Going through all the plugins to find the one responsible for this will be hard work but will let you know if I find it.
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          renderiza
          Ok this is weird... I went to my Plugin Folder and moved all of my other plugins except Selection Toys and it still is not working!
          The other test I did that made it work was the following...
          I copied my SketchUp Folder from Programs Files and pasted a new one to my Desktop. Doing this will make the plugin work.
          Any ideas what can this be...This means what is causing this is not another plugin but something else.
          IMPORTANT!
          I uninstalled & reinstalled SketchUp to see if it will fix it and it didn't so something is wrong with the SketchUp folder being on my Programs Folder!?... Not sure but this is definitely weird. ๐Ÿ˜•
          Maybe I need to restore my machine factory settings to see if it solves it. ๐Ÿ˜ฎ ๐Ÿ˜ข
            Have you checked your Plugins folder Properties > Security > Edit = FULL for all listed users/groups ?
            The OS defaults will limit it settings - even for Admins...
            Messing on with reinstalls etc can screw things up...
              renderiza
              TIG you are right there is something wrong with my folder permission. I made new topic here to take this discussion there instead... http://sketchucation.com/forums/viewtopic.php?p=489984#p489984
              • Dan RathbunD Offline
                Dan Rathbun
                FYI: On MS Windows, DO NOT assign a special (or custom) icon to the "Plugins" folder (or any of SketchUp's subfolders.) It causes folder permission errors.
                I'm not here much anymore.
                  renderiza
                  Already did without even wanting to I think. ๐Ÿ˜ข
                  Hope to find a way to undo it. ๐Ÿ˜•
                    Dan Rathbun
                    Easy.
                    1. Exit all SketchUp processes.
                    2. Navigate to the SketchUp program folder.
                    3. Rename the bad "Plugins" folder "Plugins_old" or whatever.
                    4. Create a NEW folder named "Plugins"
                    5. Copy the files and subfolders from the "old" folder.
                    6. Delete the old folder.
                    7. Restart SketchUp.
                      renderiza
                      Thanks Dan Rathbun!
                        danielfagerberg
                        Hi Thomas,
                        I am so grateful for your work!
                        Is there a way to select components that have been scaled?
                        Select the components that have been scaled to a certain scale so that i later can "make unique"
                        reason is, i have 1 component that i have scaled in 6 different scales and the copied all over the shop in hundreds...
                        I cant really find the ones with the same scale....
                        Using TIG's Descaler gives me hundreds of components... it sort of make the model a bit slow ๐Ÿ˜„
                        Again thank you for your wonderful work!
                        BTW, the bowler hat that i see both on you and TIG, is that a special Sketchucation feature? i will sure run down the street to get one in emotional support for you guys! ๐Ÿ˜„
                        • tt_suT Offline
                          tt_su
                          Hi Danel.
                          There is no function in Selection Toys that selects based on size I'm afraid.
                          The hat spread across the forum after last Basecamp in 2012 ๐Ÿ˜„
                            danielfagerberg
                            Ok, thank you!
                            About the hat... im heading for the shop... will add a mustache as well ๐Ÿ˜„
                            @tt_su said:
                            Hi Danel.
                            • gonashviliG Offline
                              gonashvili
                              So umm pardon my lack of 'research' into these toys, but is there a function to recall previous selection? Sort of an 'Undo' / 'Redo' in the selection's 'universe'..
                              No? Sheeeet ๐Ÿ˜„
                              Cause ummm.... I don't know like you guys, but there's a lot of Homer-style D'OH's goin on when I .... select stuff ๐Ÿ˜„
                              • cottyC Offline
                                cotty
                                Not here, but there are others like Selection memory or Selection Manager...
                                my SketchUp gallery
                                  gonashvili
                                  Ah, thank you very much!!
                                    txusic
                                    is there a version in .rb instead of .rbz..
                                    i canยดt find it to work on SU7 on an old PPC Mac
                                    cheers
                                    • massimoM Offline
                                      massimo Moderator
                                      cheers
                                      Just rename the folder as .zip and then unzip it.
                                      • tt_suT Offline
                                        tt_su
                                        Check out this article: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-old-fashioned-manual-way
                                          txusic
                                          thanks ever so much!!!
                                          oh my.. iยดve discarded so many other stuff i couldnt work what was going on.. cheers
                                            There's already a native tool to do that.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 25 / 30
