    [Plugin] Double line
    91 Posts 38 Posters 57.5k Views 38 Watching
    • P Offline
      photon2
      This seems such an important plugin, but there seems to be a problem with intersecting lines not being split as normal, and faces not being split as normal by the double line. SU8 on Mac. Mostly trying to use in 2D, with or without grouping, on top of an existing face.
      • GMthompsonG Offline
        GMthompson
        is this plugin out of date, after i click on double line, i dont get a dialog box
        you can learn something everyday by paying attention
          GMthompson
          tab key brings up dialog box with doubleline2.rb sorry
            boilingsnow
            Hi Didier Bur, this plugin is very useful for drawing walls.
            But now I have one problem with it. The dialog window only displays for the first time I used the plugin. Now it doest show at all and I cant change any parameters...
            Can anyone tell me how I can fix it?
            • BoxB Offline
              The post above yours might be a clue.
              TAB key.
              • DSorensenD Offline
                DSorensen
                Hello,
                I have the same problem: the tab key does not bring up the dialog box for the tool.
                I am on a MAC. Any suggestions would be appreciated.
                  This is one of Didier's tools that slipped through the net.
                  I was charged with updating them to be compatible with the newer versions of SketchUp...
                  This tool has never properly called its Options on TAB on MAC.
                  It uses TAB-press... but TAB+keyDown is not recognized by MACs.
                  Its code can be changed to TAB+keyUp, for PC & MAC compatibility.
                  BUT I'm sure it's full of other issues too πŸ˜’
                  I'll look at it asap...
                    DSorensen
                    Hello TIG
                    Thank you for responding & looking into this. Much appreciated.
                      Here's v6x http://sketchucation.com/pluginstore?pln=dline2
                      Usage:
                      Draw > Double Line
                      [Tab] for options dialog
                      [Double-click] to close loop and draw
                      [Enter] to draw
                      [Esc] to quit
                      Draws Double-Lines / Walls - like Autocad's Autolisp "dline.lsp".
                      It is now compatible with PC & MAC, and suitable for v8 to >=v2015 .
                      Its lines are now forced 'flat' - constrained to initial point's Z.
                      If grouped it is uniquely named ["DLINE#n"].
                      General coding overhaul and update...
                      Now uses TAB+keyUP for Options to be compatible with MAC & PC.
                        DSorensen
                        Thank you TIG. Really helpful.
                        All best,
                        David
                          DSorensen
                          Hello Tig,
                          ".......there seems to be a problem with intersecting lines not being split as normal, and faces not being split as normal by the double line".
                          Would it be possible to break up the lines as suggested by this comment quoted above....?
                          If possible---and with our thanks.
                          David
                          • EdsonE Offline
                            Edson
                            I have installed the latest version from the Extension Warehouse but it does not work.
                            I am on Mac OS X 10.10 and the latest version of SU 2015.
                            http://www.mahfuz.arq.br
                              driven
                              Edson, it's working with Yosemite on my mac...
                              is it appearing in the Draw menu?
                              is it drawing anything?
                              john
                              • EdsonE Offline
                                Edson
                                hi john,
                                yes, it appears on the Draw menu and the toolbar is ok. at first it seemed not to be working because I was drawing at too small a scale.
                                after making sure it is working I ran a few tests and the only thing I could not do is to close a set of walls upon itself. in general it does not close and when it does the corner is not healed (see image attached). perhaps I am doing something wrong.
                                on the other hand, drawing from a selection works fine.
                                thanks.
                                  driven
                                  it's it's click >> click >> double click for self closure...
                                  self closure
                                  john
                                  • EdsonE Offline
                                    Edson
                                    this is what I cannot achieve. when I double-click there appears a third line on the ground and I have to press return for the wall to appear. the corner remains unhealed as in the attached image.
                                    • mariochaM Offline
                                      mariocha
                                      Negative height: This happens when you draw a wall on an existing face. this is normal, the workaround is to ask for making a group in the dialog box, or create a group with the existing face you want to draw on.
                                      Well, sorry to say it happens even if the face is in a group. Quite annoying.
                                      %(#008000)[Mario C.
                                      • mariochaM Offline
                                        mariocha
                                        Just for info. Here, on 10.10.5, double-clicking closes and heals alright.
                                        Hum... if a third line appears, it means a third single point has been clicked, I'd say.
                                        To make a closed triangular wall, the process is : click = start, click = 1st line, double-click = walls.
                                        As you probably figured out by now.
                                        %(#008000)[Mario C.
                                        • EdsonE Offline
                                          Edson
                                          mario,
                                          double-click does not work for me. the walls only appear after I press return. and then not completely healed (see attached image). very odd.
                                          the only way to get healed walls is to use the double line from selection option.
                                          • mariochaM Offline
                                            mariocha
                                            @edson said:
                                            mario,
                                            Very odd indeed.
                                            Huh... btw, I do not see that double line from selection option. 😳
                                            %(#008000)[Mario C.
                                            • 4 / 5
