    [Plugin] Double line
    91 Posts 38 Posters 62.5k Views 38 Watching
      Here's v6x http://sketchucation.com/pluginstore?pln=dline2
      Usage:
      Draw > Double Line
      [Tab] for options dialog
      [Double-click] to close loop and draw
      [Enter] to draw
      [Esc] to quit
      Draws Double-Lines / Walls - like Autocad's Autolisp "dline.lsp".
      It is now compatible with PC & MAC, and suitable for v8 to >=v2015 .
      Its lines are now forced 'flat' - constrained to initial point's Z.
      If grouped it is uniquely named ["DLINE#n"].
      General coding overhaul and update...
      Now uses TAB+keyUP for Options to be compatible with MAC & PC.
      • DSorensenD Offline
        DSorensen
        Thank you TIG. Really helpful.
        All best,
        David
          DSorensen
          Hello Tig,
          ".......there seems to be a problem with intersecting lines not being split as normal, and faces not being split as normal by the double line".
          Would it be possible to break up the lines as suggested by this comment quoted above....?
          If possible---and with our thanks.
          David
          • EdsonE Offline
            Edson
            I have installed the latest version from the Extension Warehouse but it does not work.
            I am on Mac OS X 10.10 and the latest version of SU 2015.
            http://www.mahfuz.arq.br
              driven
              Edson, it's working with Yosemite on my mac...
              is it appearing in the Draw menu?
              is it drawing anything?
              • EdsonE Offline
                Edson
                hi john,
                yes, it appears on the Draw menu and the toolbar is ok. at first it seemed not to be working because I was drawing at too small a scale.
                after making sure it is working I ran a few tests and the only thing I could not do is to close a set of walls upon itself. in general it does not close and when it does the corner is not healed (see image attached). perhaps I am doing something wrong.
                on the other hand, drawing from a selection works fine.
                thanks.
                  driven
                  it's it's click >> click >> double click for self closure...
                  self closure
                  • EdsonE Offline
                    Edson
                    this is what I cannot achieve. when I double-click there appears a third line on the ground and I have to press return for the wall to appear. the corner remains unhealed as in the attached image.
                    • mariochaM Offline
                      mariocha
                      Negative height: This happens when you draw a wall on an existing face. this is normal, the workaround is to ask for making a group in the dialog box, or create a group with the existing face you want to draw on.
                      Well, sorry to say it happens even if the face is in a group. Quite annoying.
                      %(#008000)[Mario C.
                      • mariochaM Offline
                        mariocha
                        Just for info. Here, on 10.10.5, double-clicking closes and heals alright.
                        Hum... if a third line appears, it means a third single point has been clicked, I'd say.
                        To make a closed triangular wall, the process is : click = start, click = 1st line, double-click = walls.
                        As you probably figured out by now.
                        %(#008000)[Mario C.
                        • EdsonE Offline
                          Edson
                          mario,
                          double-click does not work for me. the walls only appear after I press return. and then not completely healed (see attached image). very odd.
                          the only way to get healed walls is to use the double line from selection option.
                          • mariochaM Offline
                            mariocha
                            @edson said:
                            mario,
                            Very odd indeed.
                            Huh... btw, I do not see that double line from selection option. 😳
                            %(#008000)[Mario C.
                            • EdsonE Offline
                              Edson
                              you can find it at Draw>Double Line>Double Line from selection or in the toolbar at View>Toolbar Palettes>Double Line (third icon down).
                              • mariochaM Offline
                                mariocha
                                Well, as you said, odd it is. There is no Double Line from selection sub/option under Draw. AND no toolbar
                                Do we have the same version of it ?
                                Mine is from a fresh download from Sketchucation Store, D.Bur, Double Line v6X
                                %(#008000)[Mario C.
                                • Bob JamesB Offline
                                  Bob James
                                  Works fine from Draw menu (except it's "Draw>Double Line" not "Draw>Double Line>Double Line", but there is no toolbar called "Paletts" (or "Double Line" as could be expected).
                                  I note that it says "third icon down". This seems to imply that "Paletts" is a master toolbar perhaps loaded by another extension?
                                    driven
                                    Bob.
                                    View>Toolbar Palettes is a mac thing...
                                    that's where we find our toolbars...
                                    • EdsonE Offline
                                      Edson
                                      there you have it Bob: the Double Line toolbar and the menu item View>Tool Palettes. as already mentioned, "a Mac thing."
                                        driven
                                        Edson, I just realised we are using different versions...
                                        mine is from here [without the toolbar] but works...
                                        yours is from Extension Warehouse , so I just installed it and it fails to close the wall as you describe...
                                        • EdsonE Offline
                                          Edson
                                          I wonder if we could get some help from Didier, the author, or from TIG.
                                            driven
                                            the one with the toolbar is scrambled, so you'll need to PM Didier...
                                            Tig's update to the old one works fine,but is lacking some features...
                                            • 4 / 5
