    Windowizer
    86 Posts 36 Posters 8.6k Views 36 Watching
    • F Offline
      Fletch
      @fletch said:
      really looking forward to this one...
      Fletch
      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
        RickW
        Message received. 😄
        Okay, here's the update:
        1. added in the front-only option
        2. added in the group/non-group option
        3. added zero-width outside frame handling
          (with those two items, setting to front-only and non-group will create things just like Windowizer3 did, just with more capability [generally speaking]).
          My short-list for things remaining to do:
        4. Add "Edit" capability, like in W3
        5. Add "Inherit properties" capability, like in W3
        6. Add "Delete" capability, like in W3 (this may be difficult, since W4 will cut openings in "walls" now)
        7. Handle zero-width mullions for butt-glazing
        8. Investigate using components
          If there's anything on the list you don't care about, I could put it off 'til the first update. If there's capabilities you want to see, let me know - I'll see what I can do.
        RickW
        [www.smustard.com](http://www.smustard.com)
        • ToboboT Offline
          Tobobo
          You are a legend!!!
          Toby
          Philippians 4:13
            Awesome. SketchUp meets Revit.
              Any chance for arched, Gothic windows with tracery and such? 😄
              (JK)
              • F Offline
                Fletch
                ok, put them off... go ahead and lay it on us! 😄
                Fletch
                  bellwells
                  Rick, I'm with Fletch.
                  Ron
                    RickW
                    (JK)
                    It's designed for storefront or curtainwall types of windows like Kawneer and so on. That said, it has been used for all kinds of things I did not expect (and which I have tried to maintain as best I could).
                    RickW
                      RickW
                      Would everyone who volunteered to translate please PM me your email address? It will be easier for me to handle things that way.
                      Thanks,
                      RickW
                      • bagateloB Offline
                        bagatelo
                        Forgive me for my horrible English.
                        I love this Script, I find it him very important.
                        Like you doesn't rest, you could consider those ideas:
                        1 Configuration interface with previuw in the side.
                        2 Glaze and aluminum could come in separate objects and groups.
                        3 Incorporate technology BIM for future modifications in the window?
                        4 Open hole automatically in the walls, maybe an integration with the Plugin multi-layers Wall?
                        5 Choose profiles for the metallic part?
                        6 Save configurations with names for other sessions of use of Sketchup, with hidden file?
                        Thanks anyway.
                          RickW
                          Several of those requested items are already included in version 4. 😄
                          RickW
                            su30
                            I am keeping my eyes on this wonderful plugin,
                            and I don't know if this can be used in building windows freely on curve faces?
                            su30
                              alpmeadow
                              Thanks Rick for your V4 upgrade on windowizer. I have used windowizer for independently and ocsssionally with the housebuilder ruby and it works well, if you size the rough openings correctly.
                              Just a suggestion to check if V4 will continue to work with housebuilder. Are there many out there still using housebuilder.rb? or has it fallen from grace? Do you need any help translating US English to Canadian eh?
                              Cheers
                              alpmeadow
                                RickW
                                While I haven't checked for compatibility, I can't think of any reason why it wouldn't work with housebuilder.rb (but I could be surprised, I suppose).
                                Progress update: I learned of a serious bug that requires a fix before release. If I can get done with my day-job deadlines, I'll fix it this weekend.
                                RickW
                                • utilerU Offline
                                  utiler
                                  You bet Thomas, the only thing holding me back from going SU solo.....
                                  Actually, how 'bout a 'doorizer'?
                                    spirp
                                    doorizer .. that's a good idea!
                                    +1
                                    // Olle
                                    • utilerU Offline
                                      utiler
                                      I know there is a 'doormaker' ruby but if SU develops in time by way of talented scripter, then I believe protocol should be an important issue.
                                      Eg: functions like windowizer and say 'doorizer' [for want of a better term] would be ideally located in the same drop down menus and adjacent to each other [IMO]. Standard CAD application protocol.....
                                      @RickW - when it comes to ruby, I don't know my @%#$ from my elbow, but I assume a door script would be written a similar way to the windowizer ruby....?
                                      BTW, If I haven't thanked you for your tireless work and generosity, please accept my many thanks!!!
                                      • F Offline
                                        fakircho
                                        I vote for "doorizer" too, it would be great to have some parametric functionality as well
                                        • TIGT Online
                                          What's the difference between an external window and a glass door ? If you want to put a door into a curtainwall/shopfront that's been made with Windowizer you just Windowize a glazed panel [perhaps with a bit of tweaking to suit] within what you've just done and then set the dialog variables so it's 'door' - some manual adjustments might be needed - BUT remember that you are the designer... not Rick or his Windowizer !
                                          There is already a 'door maker' script that makes 'solid' internal doors. It's really not that difficult to place 'standard' doors as components after you've made them. Making shopfronts etc is more specialised and Windowizer fills that gap...
                                          • utilerU Offline
                                            utiler
                                            Hi TIG, I guess the difference is that a door wouldn't have a sill. I appreciated that there would be some tweaking to convert to a door.....
                                            @RickW - a few queries re: Version 4:
                                            1. do you see value in converting the window to a component at execution as well as groups as you have noted? I think the advantages should be obviousto all...
                                            2. By the looks of your screen shot earlier in this thread the glass inset will be separate from the depth of frame, it that the case? At the moment I assume that the glass inset sets the depth of the frame.....
                                            Looking forward to your reply and impending release!!!
                                            • 4 / 5
