    [Plugin] Lines to tubes
    131 Posts 61 Posters 297.0k Views 61 Watching
    • H Offline
      huajiet
      @sdmitch said:
      Yes, but this particular plugin is scrambled so only the creator can make that change.
      I'm hoping to set the default 'Precision' input at 20. looked into the .rb file but it's all scrambled. anyone can help?
      sdmitch, where can I download your Edge_to_Tube plugin?
        Munene
        How do you download the extension
        • Didier BurD Offline
          Didier Bur
          Go to the Resources tab and select the PluginStore option.
          Regards
          DB
            samodelkin_77
            @huajiet said:
            look at this plugin:
            https://transfiles.ru/lwtkd
              samodelkin_77
              and how to insert images when responding? I didn't find where to click.press. I had to upload it to a file sharing service..
                You didn't find the part of the Reply page shown in the red box, below?
                Click on Choose File, select the file on your computer, click Add the file.
                  samodelkin_77
                  And I was looking at the top and side)) and it wasn't even visible below... it didn't fit into the screen)) thanks.
                  And I threw this picture on the file sharing site, maybe this plugin (1001) will help with pipes...
                  • massimoM massimo referenced this topic on
                    Mahasamaritan Newcomers @Chris Fullmer
                    @Chris-Fullmer said in [Plugin] Lines to tubes:
                    It was listed just fine for me on Vista 64bit in the tools menu. Great plugin!
                    Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture πŸ˜„
                    Chris
                    How can you make Lines to Tubes work in Sketchup 2014?
                      Dave R @Mahasamaritan
                      @Mahasamaritan said in [Plugin] Lines to tubes:
                      Just install it using the Sketchucation ExtensionStore tool, select the edges and then run it. It works just fine in older SketchUps.
                        mleslieperez Newcomers
                        Mine is saying "unsigned" so it isn't able to install on my sketchup... can you help me fix this?
                          Being 'unsigned' need not be a problem.
                          Edit your native Extension Manager settings - Loading Policy > Unrestricted
                          Restart SketchUp and version-compatible, but 'unsigned', extensions [i.e. usually older] will then load OK.
                          Only install extensions from trustworthy sources - like SketchUcation, the Extension-Warehouse and a few developers' sites which offer direct downloads...
                          • 6
                          • 7
                          • 7 / 7
