    [Plugin] Lines to tubes
    131 Posts 61 Posters 297.0k Views 61 Watching
    • josephkim626J Offline
      josephkim626
      As I am often giving precision 4 to give a rectangular look, im just wondering if there would be a way to rotate the profile 45 degrees. Effectively, having a rectangular tubes.
      • sdmitchS Offline
        sdmitch
        Yes, but this particular plugin is scrambled so only the creator can make that change.
        In the mean time, maybe this will help. You can copy and paste into the Ruby Console to try it out.
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        unless sel.empty?
          vars=UI.inputbox(["Number of Sides;"," Length of a Side;","Angle of Rotation;"],[4,1,45],"Tube Specifications")
          if vars
            n,l,d=vars
            a=180/n
            r=l/Math.sin(a.degrees)/2
            edgs=sel.grep(Sketchup;;Edge)
            edgs.each{|e|
              p,v=e.line
              grp=ent.add_group;ge=grp.entities
              tube=ge.add_ngon(p,v,r,n)
              face=ge.add_face(tube)
              ent.transform_entities(Geom;;Transformation.rotation(p,v,d.degrees),face)
              face.followme e
              grp.explode
        else
          UI.messagebox "Select Edges"
        http://sdmitch.blogspot.com/
        • ntxdaveN Offline
          ntxdave
          While I like the plugin and seem some valuable uses, I am having a problem with it.
          Here is a screen capture of the problem I am having:
          I tried to be very careful when connecting the three segments (made sure the arch that connected the two straight lines was tangent) but I have many occasions where I will need to draw some pipes with multiple curves.
          I will assume I am doing something wrong. I have also attached the skp file (I moved the resulting tube so that the original line can be seen).
          Lines2Pipes.skp
          Press F1...thank me later
            driven
            @nxtdave,
            download tig_weld and weld your 3 lines first...
            john
            • ntxdaveN Offline
              ntxdave
              @driven said:
              @nxtdave,
              john
              Already had weld installed. Just did not use it. When I welded the lines, it worked perfect. Even tried a freehand line and it worked fine as well.
              πŸ‘
              Thanks..........I should have thought of that 😳
              Might be something that should be explored for a future release though. Just out of curiosity, I also have the free version of Profile Builder and it worked fine on the original lines though without using the Weld tool.
              Just a thought..........
                josephkim626
                > sel = mod.selection
                > unless sel.empty?
                >   if vars
                >     n,l,d=vars
                >     a=180/n
                >     edgs.each{|e|
                >       p,v=e.line
                >       face.followme e
                >       grp.explode
                >   end
                > else
                > end
                Thank you so much, this helped for me at least this time.
                I had to remove "grp.explode" line as I wanted them to be a grouped members.
                who is the creator of this plugin? I know it has been tossed around couple times.
                (I will still need an option to use "mm" units, follow welded edges as solid)
                • sdmitchS Offline
                  sdmitch
                  Didier Bur is the creator of the "Lines2Tubes" plugin.
                  • G Offline
                    Guilherme Bera
                    I'd like to thank you by this plugin.
                    But it doesn't have a toolbar, and once that the plugin "Toolbar Editor" from Aerilius, induced me to make the workspace more visual. I decided to modify a bunch of scripts just enough to support toolbar, but your script is scrambled, so I can't do it by myself. So I'd be glad if you could modify your plugin just enough to support toolbar.
                    Then a simple way to add the toolbar support is like TIG commented in another topic (bit.ly/29PAk6T😞
                    An example of the menu making command is:
                    unless file_loaded?(__FILE__)
                    >    cmd = UI;;Command.new("SomeCommandName"){ SomeCommand.new() }
                    >    UI.menu("Plugins").add_item(cmd)
                    > ### START - ADD TOOLBAR HERE...
                    > ### END -   ADD TOOLBAR HERE
                    >    file_loaded(__FILE__)
                    > end
                    If it's a 'Tool' the CMD setup is slightly different...
                    An example to use that within a toolbar is this additional code added between the ### markers:
                    cmd.tooltip = "SomeCommandName"
                    > cmd.status_bar_text = "SomeText"
                    > cmd.small_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-24.png')
                    > cmd.large_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-32.png')
                    > toolbar = UI;;Toolbar.new("SomeCommandName")
                    > toolbar.add_item(cmd)
                    > toolbar.show if toolbar.get_last_state.abs == 1 # TB_VISIBLE/NEVER
                    Note how addition properties are needed for the cmd to be used in a toolbar.
                    The path to the button icons and their names is up to you...
                    PS: If it could be helpful, I attached icons created for the toolbar.
                      Does it possible to modify the plugin
                      for have a rotation input?
                      Now we have this!
                      As you remark there is an Up Orientation!
                      Wanted! πŸ€“
                        josephkim626
                        Now we have this!
                        [attachment=1:1rui9dug]<!-- ia1 -->GIF_tube.gif<!-- ia1 -->[/attachment:1rui9dug]
                        Wanted! πŸ€“
                        [attachment=0:1rui9dug]<!-- ia0 -->squares_w.jpg<!-- ia0 -->[/attachment:1rui9dug]
                        Sdmitch has his own plugin that does what you are describing.
                        http://sdmitch.blogspot.co.uk/
                        find "Edge To Tube"
                          josephkim626
                          @pilou said:
                          Seems bugged! πŸ˜‰
                          Or works only for curves ?
                          Seems working only from polys of 5 segments! πŸ˜‰
                          [attachment=1:17is50ip]<!-- ia1 -->GIF_bugged.gif<!-- ia1 -->[/attachment:17is50ip]
                          Indeed it behaves funny when it is run on rectangles.
                          But it seems fine for some others.
                          [attachment=0:17is50ip]<!-- ia0 -->tube.gif<!-- ia0 -->[/attachment:17is50ip]
                            Seems bugged! πŸ˜‰
                              The "Do curve" is somptuous! πŸ‘
                              (not my video πŸ’š
                              (currioussly don't works for the rectangles! 😲
                              Bravo to Sdmitch! 😎
                              Ps Will be very fine for any "section" πŸ˜‰
                              • ntxdaveN Offline
                                ntxdave
                                One thing that does not work correctly for me is the Materials parameter. It will only allow me to select a material that has already been used in the model.
                                Maybe I am doing something wrong................
                                  To give you access to the potentially thousands of material SKM files that are not currently used in the model could be unbelievably complex, even it it were easy to do in the API - which unfortunately it is not...
                                  To be frank having any material choice seems overkill, as it is really a a geometry creator ?
                                  • sdmitchS Offline
                                    sdmitch
                                    Fixed the problem with rectangles in my Edge_to_Tube plugin. Normal rectangles are bounded by 4 edges and not a 'curve' as polygons and circles are.
                                      Excellent! πŸ‘
                                      And can we imagine the same with any section ?
                                        rv1974
                                        My $0.02:
                                        1. Fredo's Make curves (weld)
                                        2. S4u 'Make Frame'
                                          Yes but quid of differents number of segments of sections ? πŸ˜‰
                                          @Sdmitch
                                          Seems the "Do Curve" don't works in the new version!
                                          Edit: Sorry I don't draw a polygon but a rectangle! 😳
                                          The trick is draw a poly with 4 edges then resize with FredoScale! πŸ˜„
                                          • fionmacoolF Offline
                                            fionmacool
                                            Merci pour le Plugin. : )
                                            Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                            • 6
                                            • 7
                                            • 6 / 7
