    [Plugin] Lines to tubes
    131 Posts 61 Posters 312.2k Views 61 Watching
    • C
      chris87
      Great plugin !
      Thank you !
        Please get the latest v2014/2015 compatible version from the PluginStore http://sketchucation.com/pluginstore?pln=lines2tubes
        • C
          chauhuyphan
          Great plugin! Thanks you !
          • josephkim626J
            josephkim626
            As I am often giving precision 4 to give a rectangular look, im just wondering if there would be a way to rotate the profile 45 degrees. Effectively, having a rectangular tubes.
            • sdmitchS
              sdmitch
              Yes, but this particular plugin is scrambled so only the creator can make that change.
              In the mean time, maybe this will help. You can copy and paste into the Ruby Console to try it out.
              mod = Sketchup.active_model
              ent = mod.active_entities
              sel = mod.selection
              unless sel.empty?
                vars=UI.inputbox(["Number of Sides;"," Length of a Side;","Angle of Rotation;"],[4,1,45],"Tube Specifications")
                if vars
                  n,l,d=vars
                  a=180/n
                  r=l/Math.sin(a.degrees)/2
                  edgs=sel.grep(Sketchup;;Edge)
                  edgs.each{|e|
                    p,v=e.line
                    grp=ent.add_group;ge=grp.entities
                    tube=ge.add_ngon(p,v,r,n)
                    face=ge.add_face(tube)
                    ent.transform_entities(Geom;;Transformation.rotation(p,v,d.degrees),face)
                    face.followme e
                    grp.explode
              else
                UI.messagebox "Select Edges"
              http://sdmitch.blogspot.com/
              • ntxdaveN
                ntxdave
                While I like the plugin and seem some valuable uses, I am having a problem with it.
                Here is a screen capture of the problem I am having:
                I tried to be very careful when connecting the three segments (made sure the arch that connected the two straight lines was tangent) but I have many occasions where I will need to draw some pipes with multiple curves.
                I will assume I am doing something wrong. I have also attached the skp file (I moved the resulting tube so that the original line can be seen).
                Lines2Pipes.skp
                Press F1...thank me later
                  driven
                  @nxtdave,
                  download tig_weld and weld your 3 lines first...
                  • ntxdaveN
                    ntxdave
                    @driven said:
                    @nxtdave,
                    Already had weld installed. Just did not use it. When I welded the lines, it worked perfect. Even tried a freehand line and it worked fine as well.
                    πŸ‘
                    Thanks..........I should have thought of that 😳
                    Might be something that should be explored for a future release though. Just out of curiosity, I also have the free version of Profile Builder and it worked fine on the original lines though without using the Weld tool.
                    Just a thought..........
                    • josephkim626J
                      josephkim626
                      > sel = mod.selection
                      > unless sel.empty?
                      >   if vars
                      >     n,l,d=vars
                      >     a=180/n
                      >     edgs.each{|e|
                      >       p,v=e.line
                      >       face.followme e
                      >       grp.explode
                      >   end
                      > else
                      > end
                      Thank you so much, this helped for me at least this time.
                      I had to remove "grp.explode" line as I wanted them to be a grouped members.
                      who is the creator of this plugin? I know it has been tossed around couple times.
                      (I will still need an option to use "mm" units, follow welded edges as solid)
                      • sdmitchS
                        sdmitch
                        Didier Bur is the creator of the "Lines2Tubes" plugin.
                        • G
                          Guilherme Bera
                          I'd like to thank you by this plugin.
                          But it doesn't have a toolbar, and once that the plugin "Toolbar Editor" from Aerilius, induced me to make the workspace more visual. I decided to modify a bunch of scripts just enough to support toolbar, but your script is scrambled, so I can't do it by myself. So I'd be glad if you could modify your plugin just enough to support toolbar.
                          Then a simple way to add the toolbar support is like TIG commented in another topic (bit.ly/29PAk6T😞
                          An example of the menu making command is:
                          unless file_loaded?(__FILE__)
                          >    cmd = UI;;Command.new("SomeCommandName"){ SomeCommand.new() }
                          >    UI.menu("Plugins").add_item(cmd)
                          > ### START - ADD TOOLBAR HERE...
                          > ### END -   ADD TOOLBAR HERE
                          >    file_loaded(__FILE__)
                          > end
                          If it's a 'Tool' the CMD setup is slightly different...
                          An example to use that within a toolbar is this additional code added between the ### markers:
                          cmd.tooltip = "SomeCommandName"
                          > cmd.status_bar_text = "SomeText"
                          > cmd.small_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-24.png')
                          > cmd.large_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-32.png')
                          > toolbar = UI;;Toolbar.new("SomeCommandName")
                          > toolbar.add_item(cmd)
                          > toolbar.show if toolbar.get_last_state.abs == 1 # TB_VISIBLE/NEVER
                          Note how addition properties are needed for the cmd to be used in a toolbar.
                          The path to the button icons and their names is up to you...
                          PS: If it could be helpful, I attached icons created for the toolbar.
                            Does it possible to modify the plugin
                            for have a rotation input?
                            Now we have this!
                            As you remark there is an Up Orientation!
                            Wanted! πŸ€“
                            • josephkim626J
                              josephkim626
                              Now we have this!
                              [attachment=1:1rui9dug]<!-- ia1 -->GIF_tube.gif<!-- ia1 -->[/attachment:1rui9dug]
                              Wanted! πŸ€“
                              [attachment=0:1rui9dug]<!-- ia0 -->squares_w.jpg<!-- ia0 -->[/attachment:1rui9dug]
                              Sdmitch has his own plugin that does what you are describing.
                              http://sdmitch.blogspot.co.uk/
                              find "Edge To Tube"
                              • josephkim626J
                                josephkim626
                                @pilou said:
                                Seems bugged! πŸ˜‰
                                Or works only for curves ?
                                Seems working only from polys of 5 segments! πŸ˜‰
                                [attachment=1:17is50ip]<!-- ia1 -->GIF_bugged.gif<!-- ia1 -->[/attachment:17is50ip]
                                Indeed it behaves funny when it is run on rectangles.
                                But it seems fine for some others.
                                [attachment=0:17is50ip]<!-- ia0 -->tube.gif<!-- ia0 -->[/attachment:17is50ip]
                                  Seems bugged! πŸ˜‰
                                    The "Do curve" is somptuous! πŸ‘
                                    (not my video πŸ’š
                                    (currioussly don't works for the rectangles! 😲
                                    Bravo to Sdmitch! 😎
                                    Ps Will be very fine for any "section" πŸ˜‰
                                    • ntxdaveN
                                      ntxdave
                                      One thing that does not work correctly for me is the Materials parameter. It will only allow me to select a material that has already been used in the model.
                                      Maybe I am doing something wrong................
                                        To give you access to the potentially thousands of material SKM files that are not currently used in the model could be unbelievably complex, even it it were easy to do in the API - which unfortunately it is not...
                                        To be frank having any material choice seems overkill, as it is really a a geometry creator ?
                                        • sdmitchS
                                          sdmitch
                                          Fixed the problem with rectangles in my Edge_to_Tube plugin. Normal rectangles are bounded by 4 edges and not a 'curve' as polygons and circles are.
                                            Excellent! πŸ‘
                                            And can we imagine the same with any section ?
                                            • 6 / 7
