    [Plugin] Toggle Units
    159 Posts 47 Posters 142.7k Views 47 Watching
    • CadFatherC Offline
      CadFather
      some icons - not great, will work more..
      16 GIF.rar
      24 GIF.rar
        cornel
        Many thanks, Matt!
        For me it’s a considerable tool – I work very often w/ different unit formats on the same dwgs.
        Best regards,
        Cornel
        • Didier BurD Offline
          Didier Bur
          Matt,
          STP remplace "unity" par "unit" dans le script. Unity veut dire à peu près "unification". 😉
          DB
            Matt666
            @CadFather, Thank you ! Could you post them in png format, please ?
            😳 🤣 Vive mon anglais désastreux !
            You're welcome Cornel !! 😉
            Frenglish at its best !
            My scripts
              CadFather
              ..they do need touching up, but here they are
              16&24 PNG.rar
                Matt666
                The 9 icons script has been updated with new icons on the script post. Please try it Edson !
                Thank you CadFather !!
                My scripts
                • EdsonE Offline
                  Edson
                  no change, matt. still not working on mac. i click on the icons and nothing changes; it keeps the unit set through model info-->units.
                  http://www.mahfuz.arq.br
                    Matt666
                    Aaaargh ! I don't understand 😮 😮 😮 😞 😞
                    I need some help... I will ask others french scripters 😉 ! THERE IS A SOLUTION !!
                    My scripts
                      CadFather
                      anyone else on mac having the same problem?
                        jiegou
                        very good!thanks.
                          Matt666
                          Can someone test this last one on Mac, please ?
                          My scripts
                          • EdsonE Offline
                            Edson
                            still not working on my mac. nothing changes after i click on any icon. and btw, the meter icon is not showing.
                              CadFather
                              ..on pc that happens only if fractional or engineering is selected - once i click on decimal (from the toggle units icons) all icons become selectable and everything works..
                              i think we really need some 'certified mac testers'.. (or they may be left behind) 😉
                                Matt666
                                +1 for certified mac testers!
                                Sorry Edson for that and thank you so much to loose some time for script testing ! 😄
                                My scripts
                                • EdsonE Offline
                                  Edson
                                  no problem, matt. it is a pleasure to be of help. could you be more specific as to which is the build to be tested? i looked at the first post of this thread and saw nothing different there.
                                    Matt666
                                    Yep! On Fedo6 advices, I changed the way that script called preferences units...
                                    So we have to try some things...
                                    Open your ruby console, copy and paste code below and can you show me the result please ?
                                    toggle_units(1)
                                    And
                                    Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                                    And
                                    var = Sketchup.active_model.options["UnitsOptions"];var["LengthUnit"]= 4
                                    And this one (can you replace "VAR" by result of the last code entered, please ?
                                    toggle_units_validation_proc(<VAR>)
                                    Another thing : When does error message appears? While start of SU? After clicking on an icon?
                                    Sorry for all these tests, but it's necessary if I want to find the problem!
                                    Thank you Edson!
                                    My scripts
                                    • EdsonE Offline
                                      Edson
                                      matt,
                                      do no be sorry. just keep the tests coming.
                                      see the results in the attached picture. i do not get any error messages. it just does not change units.
                                      cheers.
                                        Matt666
                                        😲 toggle_units(1) works!! Try toggle_units(1), toggle_units(2), toggle_units(3) etc... And take a look in the units window (Windows->Model info->Units), normally drawing unit changes...
                                        So I will post an update soon with toolbar code changed! Thank you Edson !
                                        My scripts
                                          Matt666
                                          Hi !
                                          I go back on this plugin, with another attempt for Mac users. Edson, Can you try please? 😉
                                          EDIT1 : One other (And I hope the last !) update!
                                          toggle_units.zip
                                          My scripts
                                            Matt666
                                            Ok, I've finished this update! Can you try it, Edson, please? Thank you!
                                            My scripts
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
