    [Plugin] Toggle Units
    159 Posts 47 Posters 141.7k Views 47 Watching
    • EdsonE Offline
      Edson
      sure. no changes, ie, nothing happened. i have attached a screen grab for you to see that the error message is still showing and the toolbar shows a blank square (it does not change if i click on it).
      should you need me to test future changes on mac, just let me know.toggleunits.png
      http://www.mahfuz.arq.br
      • CadFatherC Offline
        CadFather
        ..phew - didn't know i was going to give you so much work Matt!
        i can draw some icons later today - can i suggest one further change to the scripts: if we have the icons in png formats they are much better quality..Thanks
          Matt666
          No problem CadFather 😉
          Edson : Thank you !
          Have you unzipped ain the plugin folder, and keep icons in the folder "toggle_units_icons" ?
          If yes, Can you open ruby console, type this line please :
          Sketchup.find_support_file("tuin.gif", "Plugins/toggle_units_icons")
          and show me what it returns ?
          Thank you !
          Frenglish at its best !
          My scripts
          • EdsonE Offline
            Edson
            it returns this:
            /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/toggle_units_icons/tuin.gif
            cheers.
              CadFather
              some icons - not great, will work more..
              16 GIF.rar
              24 GIF.rar
                cornel
                Many thanks, Matt!
                For me it’s a considerable tool – I work very often w/ different unit formats on the same dwgs.
                Best regards,
                Cornel
                • Didier BurD Offline
                  Didier Bur
                  Matt,
                  STP remplace "unity" par "unit" dans le script. Unity veut dire à peu près "unification". 😉
                  DB
                    Matt666
                    @CadFather, Thank you ! Could you post them in png format, please ?
                    😳 🤣 Vive mon anglais désastreux !
                    You're welcome Cornel !! 😉
                    My scripts
                      CadFather
                      ..they do need touching up, but here they are
                      16&24 PNG.rar
                        Matt666
                        The 9 icons script has been updated with new icons on the script post. Please try it Edson !
                        Thank you CadFather !!
                        My scripts
                        • EdsonE Offline
                          Edson
                          no change, matt. still not working on mac. i click on the icons and nothing changes; it keeps the unit set through model info-->units.
                            Matt666
                            Aaaargh ! I don't understand 😮 😮 😮 😞 😞
                            I need some help... I will ask others french scripters 😉 ! THERE IS A SOLUTION !!
                            My scripts
                              CadFather
                              anyone else on mac having the same problem?
                                jiegou
                                very good!thanks.
                                  Matt666
                                  Can someone test this last one on Mac, please ?
                                  My scripts
                                  • EdsonE Offline
                                    Edson
                                    still not working on my mac. nothing changes after i click on any icon. and btw, the meter icon is not showing.
                                      CadFather
                                      ..on pc that happens only if fractional or engineering is selected - once i click on decimal (from the toggle units icons) all icons become selectable and everything works..
                                      i think we really need some 'certified mac testers'.. (or they may be left behind) 😉
                                        Matt666
                                        +1 for certified mac testers!
                                        Sorry Edson for that and thank you so much to loose some time for script testing ! 😄
                                        My scripts
                                        • EdsonE Offline
                                          Edson
                                          no problem, matt. it is a pleasure to be of help. could you be more specific as to which is the build to be tested? i looked at the first post of this thread and saw nothing different there.
                                            Matt666
                                            Yep! On Fedo6 advices, I changed the way that script called preferences units...
                                            So we have to try some things...
                                            Open your ruby console, copy and paste code below and can you show me the result please ?
                                            toggle_units(1)
                                            And
                                            Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                                            And
                                            var = Sketchup.active_model.options["UnitsOptions"];var["LengthUnit"]= 4
                                            And this one (can you replace "VAR" by result of the last code entered, please ?
                                            toggle_units_validation_proc(<VAR>)
                                            Another thing : When does error message appears? While start of SU? After clicking on an icon?
                                            Sorry for all these tests, but it's necessary if I want to find the problem!
                                            Thank you Edson!
                                            My scripts
                                            • 2 / 8
