    [Plugin] Toggle Units
    159 Posts 47 Posters 142.5k Views 47 Watching
      Matt666
      The 9 icons script has been updated with new icons on the script post. Please try it Edson !
      Thank you CadFather !!
      Frenglish at its best !
      My scripts
      • EdsonE Offline
        Edson
        no change, matt. still not working on mac. i click on the icons and nothing changes; it keeps the unit set through model info-->units.
        edson mahfuz, architect| porto alegre โ€ข brasil
        http://www.mahfuz.arq.br
          Matt666
          Aaaargh ! I don't understand ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ž ๐Ÿ˜ž
          I need some help... I will ask others french scripters ๐Ÿ˜‰ ! THERE IS A SOLUTION !!
          My scripts
          • CadFatherC Offline
            CadFather
            anyone else on mac having the same problem?
              jiegou
              very good!thanks.
                Matt666
                Can someone test this last one on Mac, please ?
                My scripts
                • EdsonE Offline
                  Edson
                  still not working on my mac. nothing changes after i click on any icon. and btw, the meter icon is not showing.
                    CadFather
                    ..on pc that happens only if fractional or engineering is selected - once i click on decimal (from the toggle units icons) all icons become selectable and everything works..
                    i think we really need some 'certified mac testers'.. (or they may be left behind) ๐Ÿ˜‰
                      Matt666
                      +1 for certified mac testers!
                      Sorry Edson for that and thank you so much to loose some time for script testing ! ๐Ÿ˜„
                      My scripts
                      • EdsonE Offline
                        Edson
                        no problem, matt. it is a pleasure to be of help. could you be more specific as to which is the build to be tested? i looked at the first post of this thread and saw nothing different there.
                          Matt666
                          Yep! On Fedo6 advices, I changed the way that script called preferences units...
                          So we have to try some things...
                          Open your ruby console, copy and paste code below and can you show me the result please ?
                          toggle_units(1)
                          And
                          Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                          And
                          var = Sketchup.active_model.options["UnitsOptions"];var["LengthUnit"]= 4
                          And this one (can you replace "VAR" by result of the last code entered, please ?
                          toggle_units_validation_proc(<VAR>)
                          Another thing : When does error message appears? While start of SU? After clicking on an icon?
                          Sorry for all these tests, but it's necessary if I want to find the problem!
                          Thank you Edson!
                          My scripts
                          • EdsonE Offline
                            Edson
                            matt,
                            do no be sorry. just keep the tests coming.
                            see the results in the attached picture. i do not get any error messages. it just does not change units.
                            cheers.
                              Matt666
                              ๐Ÿ˜ฒ toggle_units(1) works!! Try toggle_units(1), toggle_units(2), toggle_units(3) etc... And take a look in the units window (Windows->Model info->Units), normally drawing unit changes...
                              So I will post an update soon with toolbar code changed! Thank you Edson !
                              My scripts
                                Matt666
                                Hi !
                                I go back on this plugin, with another attempt for Mac users. Edson, Can you try please? ๐Ÿ˜‰
                                EDIT1 : One other (And I hope the last !) update!
                                toggle_units.zip
                                My scripts
                                  Matt666
                                  Ok, I've finished this update! Can you try it, Edson, please? Thank you!
                                  My scripts
                                  • EdsonE Offline
                                    Edson
                                    matt,
                                    good news from the mac side of life. it works. however, in order to see the change in the info panel i must close it and open it again (not a big problem).
                                    what could be improved is the fact that the icon bar does not reflect the present units chosen. see the picture: i have decimal and centimeters on it but the icon bar is not reflecting it. sometimes it is all gray, others white. the buttons seem to "stick".
                                    but we made some progress.
                                      Matt666
                                      Wow... Strange!
                                      Thank you Edson! We will slowly succeed! ๐Ÿ˜„
                                      Another request, please... A daunting request...
                                      Can you open your ruby console and your units window (in model info), please?
                                      Copy and paste code below in the ruby console
                                      Sketchup.active_model.options["UnitsOptions"]["LengthFormat"]
                                      Change unit format, paste the code in the ruby console and give me the result like that :
                                      Unit format (decimal, Architectural) -> result of the code
                                      Can You do that for all SU unit Format please? ๐Ÿ˜›
                                      The same thing for units length... With this code :
                                      Here is units options in SU/Windows :
                                      Unit Format
                                      • Architectural -> 1
                                      • Decimal -> 0
                                      • Engineering -> 2
                                      • Fractionnal -> 3
                                      Unit Length
                                      • Inches -> 0
                                      • Feet -> 1
                                      • Millimeters -> 2
                                      • Centimeters -> 3
                                      • Meters -> 4
                                      Thank you Edson!
                                      My scripts
                                      • EdsonE Offline
                                        Edson
                                        sorry, max. it may seem clear to you but i am not getting what i am supposed to do. lead me through it, ok?
                                        after i paste Sketchup.active_model.options["UnitsOptions"]["LengthFormat"] what do i do? where do decimal and meters go? with or without quotation marks, etc? and where do i insert the unit options?
                                        write down one of the options and i will figure out the others.
                                        cheers.
                                          Matt666
                                          Sorry ๐Ÿ˜ณ !
                                          Procedure :
                                          For all units format (decimal, architectural, engineering, Fractional) -> Nยฐ1 on the picture
                                          1. Change the format in the unit SU window (Nยฐ1)
                                          2. Copy, paste and excecute the code in the ruby console (Nยฐ3)
                                          1. Show me the result of the code in the ruby console Like my last post.
                                          For all units length (Inch, feet, millimeters, centimeters, meters) -> Nยฐ2 on the picture
                                          1. Change the length in the unit SU window (Nยฐ2)
                                          If it's too constraining for you, don't hesitate to tell, I understand ๐Ÿ˜„
                                          Sorry again, Edson!
                                          My scripts
                                          • EdsonE Offline
                                            Edson
                                            gotcha! is this it?
                                            • 2 / 8
