    [Plugin] Toggle Units
    159 Posts 47 Posters 144.8k Views 47 Watching
    • Didier BurD Offline
      Didier Bur
      Matt,
      STP remplace "unity" par "unit" dans le script. Unity veut dire à peu près "unification". 😉
      DB
        Matt666
        @CadFather, Thank you ! Could you post them in png format, please ?
        😳 🤣 Vive mon anglais désastreux !
        You're welcome Cornel !! 😉
        Frenglish at its best !
        My scripts
        • CadFatherC Offline
          CadFather
          ..they do need touching up, but here they are
          16&24 PNG.rar
            Matt666
            The 9 icons script has been updated with new icons on the script post. Please try it Edson !
            Thank you CadFather !!
            My scripts
            • EdsonE Offline
              Edson
              no change, matt. still not working on mac. i click on the icons and nothing changes; it keeps the unit set through model info-->units.
              http://www.mahfuz.arq.br
                Matt666
                Aaaargh ! I don't understand 😮 😮 😮 😞 😞
                I need some help... I will ask others french scripters 😉 ! THERE IS A SOLUTION !!
                My scripts
                  CadFather
                  anyone else on mac having the same problem?
                    jiegou
                    very good!thanks.
                      Matt666
                      Can someone test this last one on Mac, please ?
                      My scripts
                      • EdsonE Offline
                        Edson
                        still not working on my mac. nothing changes after i click on any icon. and btw, the meter icon is not showing.
                          CadFather
                          ..on pc that happens only if fractional or engineering is selected - once i click on decimal (from the toggle units icons) all icons become selectable and everything works..
                          i think we really need some 'certified mac testers'.. (or they may be left behind) 😉
                            Matt666
                            +1 for certified mac testers!
                            Sorry Edson for that and thank you so much to loose some time for script testing ! 😄
                            My scripts
                            • EdsonE Offline
                              Edson
                              no problem, matt. it is a pleasure to be of help. could you be more specific as to which is the build to be tested? i looked at the first post of this thread and saw nothing different there.
                                Matt666
                                Yep! On Fedo6 advices, I changed the way that script called preferences units...
                                So we have to try some things...
                                Open your ruby console, copy and paste code below and can you show me the result please ?
                                toggle_units(1)
                                And
                                Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                                And
                                var = Sketchup.active_model.options["UnitsOptions"];var["LengthUnit"]= 4
                                And this one (can you replace "VAR" by result of the last code entered, please ?
                                toggle_units_validation_proc(<VAR>)
                                Another thing : When does error message appears? While start of SU? After clicking on an icon?
                                Sorry for all these tests, but it's necessary if I want to find the problem!
                                Thank you Edson!
                                My scripts
                                • EdsonE Offline
                                  Edson
                                  matt,
                                  do no be sorry. just keep the tests coming.
                                  see the results in the attached picture. i do not get any error messages. it just does not change units.
                                  cheers.
                                    Matt666
                                    😲 toggle_units(1) works!! Try toggle_units(1), toggle_units(2), toggle_units(3) etc... And take a look in the units window (Windows->Model info->Units), normally drawing unit changes...
                                    So I will post an update soon with toolbar code changed! Thank you Edson !
                                    My scripts
                                      Matt666
                                      Hi !
                                      I go back on this plugin, with another attempt for Mac users. Edson, Can you try please? 😉
                                      EDIT1 : One other (And I hope the last !) update!
                                      toggle_units.zip
                                      My scripts
                                        Matt666
                                        Ok, I've finished this update! Can you try it, Edson, please? Thank you!
                                        My scripts
                                        • EdsonE Offline
                                          Edson
                                          matt,
                                          good news from the mac side of life. it works. however, in order to see the change in the info panel i must close it and open it again (not a big problem).
                                          what could be improved is the fact that the icon bar does not reflect the present units chosen. see the picture: i have decimal and centimeters on it but the icon bar is not reflecting it. sometimes it is all gray, others white. the buttons seem to "stick".
                                          but we made some progress.
                                            Matt666
                                            Wow... Strange!
                                            Thank you Edson! We will slowly succeed! 😄
                                            Another request, please... A daunting request...
                                            Can you open your ruby console and your units window (in model info), please?
                                            Copy and paste code below in the ruby console
                                            Sketchup.active_model.options["UnitsOptions"]["LengthFormat"]
                                            Change unit format, paste the code in the ruby console and give me the result like that :
                                            Unit format (decimal, Architectural) -> result of the code
                                            Can You do that for all SU unit Format please? 😛
                                            The same thing for units length... With this code :
                                            Here is units options in SU/Windows :
                                            Unit Format
                                            • Architectural -> 1
                                            • Decimal -> 0
                                            • Engineering -> 2
                                            • Fractionnal -> 3
                                            Unit Length
                                            • Inches -> 0
                                            • Feet -> 1
                                            • Millimeters -> 2
                                            • Centimeters -> 3
                                            • Meters -> 4
                                            Thank you Edson!
                                            My scripts
                                            • 2 / 8
