    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • G Offline
      galinette
      Well, I deleted all plugins, re-downloaded all, everything works...
      Sorry for the mess
      Etienne
        Weird! 😲
        But at least it's fixed.
        Although we don't know how exactly... πŸ˜•
          Perhaps the problem has to do with the order of events? I've assisted several users who have Win7 and had problems getting plugins to work. They tried installing the plugin prior to setting the admin privileges for the Plugins folder correctly. Removing the .rb file from the folder and installing it anew allowed it to work.
          • sicksickisckS Offline
            sicksickisck
            great plugin 😍 but I need more shapes maybe shape editor [in commercial version ]
              Drape or intersect?
                No. Intersect isn't difficult and it is a fundamental thing to know how to use in SketchUp.
                  sicksickisck
                  Intersect 😎 [difficult ?].
                  edit : ...or both... I like how "tools on surface" works πŸ˜‰
                    metagamer
                    I've been playing around with this tool for a day, and I really like its potential. But I'm having a really hard time getting the shapes I draw to turn into surfaces to use with the Joint Push Pull tool. For example, I extrude a simple cylinder (using built-in tools), and then draw a rect, a circle and a hexagon on the side using ToS. Sometimes it creates a face that I can use with JPP, sometimes it doesn't, and I can't figure out why. Any clues?
                      It works for me. How large is the cylinder?
                      Or are you getting a result something like this?
                      In this case the left edge of the rectangle falls on one of the natural softened edges of the cylinder. You can see that edge if you turn on Hidden Geometry under the View menu. You'll have to unsoften that edge to separate the rectangle from the rest of the surface. You can do that with the native Line tool or the Line tool in ToS and just connect the ends of the adjacent edges of the rectangle. Or you can display Hidden Geometry, select that edge and unsoften it.
                      • jgbJ Offline
                        jgb
                        Faster; easier ..... Shift+Ctrl Erase (tool) Just click on the soft "missing" line segment.
                        jgb
                          dakenyon27
                          I can't seem to get this fantastic plugin working on sketchup 2013. Can anyone help?
                          David.
                            Sure. But we need some useful information. What do you mean you can't get it working? What happens when you start SketchUp? Do you get an error message related to the plugin?
                            Did you install the required LibFredo6 files as spelled out in the first post in the thread? How did you install the files? Do you have Administrative privileges for the Plugins folder?
                              Can you please describe the problem?
                              Installation problems? Operation problems? Errors?
                                martosurf
                                FRedo thanks a lot for all good plugins
                                You a great thanks a lot
                                  alek_mc
                                  hi... I have a problem with this plugin... I installed the sketchup pro 2013 and when I started the program, one message said that the plugin can't been uploaded... what can I do?
                                    Reread this plugin's main-page instructions.
                                    Is it installed exactly like that page says ?
                                    Have you also installed the very latest version of 'LibFredo...' from the link that is given [or the SCF PluginStore listing] ?
                                    • I Offline
                                      ibrahim zambak
                                      tools on surface v1.8a plugin, sketchup 8 does not work. windows 8 operating system
                                        Ibrahim,
                                        More info is needed here. I have SU 8 on Windows 8 and the tool works fine on my computer so a "general doesn't work" is not enough.
                                          sasrabirawa
                                          works fine on SKP 8 but doesn't work on SKP 2013. The libfred doesn't compatible w/ SKP 2013. even if I use the latest one... can anybody tell me how to fix ??
                                          Just an ordinary Sketchup user
                                            The latest LibFredo... and several related tools were remade to be compatible with all previous versions and v2013.
                                            We must assume you are using the latest versions available from the SCF PluginStore...
                                            So you must be doing something wrong ?
                                            Are you properly installing things ?
                                            Since you haven't told us your OS I must guess at PC.
                                            If it's a new v2013 installation into the usual 'Program Files' folder, then Windows will have given the new SketchUp folder [and all of its subfolders] Read-only permissions. Then you can't Write new files into the Plugins folder; but to confuse you Windows might make it look like you have, but it has a actually put the files into a VirtualStore to protect you from yourself, so they don't auto-load as SketchUp starts! A link/button in the top-bars of the Plugins folder's Windows Explorer window is an indication of such limitations...
                                            If you use an RBZ archive and then 'install' button under Preferences > Extensions, or use the SCF Plugin Store dialog's AutoInstall feature from within SketchUp then it might still install properly, despite your own limited permissions; but that depends on several other things though...
                                            It is always best to have your Plugins folder set to have FULL read/write permissions for every entry in the 'users' uder the Security list: to do this...
                                            right-click > context-menu > Properties > Security > Edit ... tick FULL for each and Apply & OK...
                                            [you will need admin rights to do this].
                                            Note that even if you are setup in the Users Control Panel to have full 'admin' rights, that will not change the initial permissions the OS sets to the SketchUp folder and its contents, even admins are limited.
                                            Note that it is also advisable to always install apps as as admin... AND for SketchUp.exe I'd also set its Properties > Compatibility, with the 'Run this program as an administrator' box ticked...
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 31
                                            • 32
                                            • 22 / 32
