    [TUTORIAL]: texturing organic form (subsmooth)
    36 Posts 17 Posters 21.1k Views 17 Watching
    • K Offline
      kwistenbiebel
      Hi friends,
      Someone at the Vray forum asked me to make a small tutorial on how to texture a subsmooth organic surface.
      I though it would be appropriate to post it here.
      Before:
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/test1-1.jpg
      After:
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/test5.jpg
      Here is how I did it. Actually it's quite a common method of projecting textures:
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/tut1.jpg
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/tut2.jpg
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/tut-3.jpg
      I hope this tut is of use to some of you.
      The method is 'view dependant' (texture looks a bit distorted at some angles) but it's the best I could do within the Sketchup limits.
      Regards,
      Kwistenbiebel
        Enlighting tuto! ๐Ÿ˜Ž
        http://www.brunssum.net/~emaille/collectie/images/ripolin.jpg
        • K Offline
          kwistenbiebel
          Thanks ๐Ÿ˜„
          Frederick, as you seem to have trouble viewing photobucket images, I'll attach them internally here:
          • FrederikF Offline
            Frederik
            Although I can't see the images you've posted here at my office (something to do with a web-blocker.. ๐Ÿ˜’ ), I'm sure your tut is useful to many, Chris..! ๐Ÿ˜‰
            UV-mapping is difficult in SU because of the limitations, so I'm sure many will find a tut on this subject very useful... ๐Ÿ˜‰
            Cheers
            Kim Frederik
            • FrederikF Offline
              Frederik
              Thanks, Chris..!! ๐Ÿ˜„
              Slightly different from how I project textures, but a very neat way of doing it... ๐Ÿ˜‰
              Cheers
              Kim Frederik
              • K Offline
                kwistenbiebel
                Thanks.
                I wish Whaats UV-tools would do a better job at texturing things like this , but unfortunately the plugin is unresponsive when trying 'spherical' mapping....
                I am sharing the object on 3Dwarehouse, so people can try to texture it.
                Maybe someone comes up with a method for a non-view-dependant method?
                Here's the link:
                http://sketchup.google.com/3dwarehouse/details?mid=1cfa3f825fd2fcfb4083c414ed3a6752
                  Easy method indeed ๐Ÿ˜‰
                  This wheel has a lot facets (like your subsmooth) for dark reasons because it should be exported to Zbrush ๐Ÿ˜’
                  (post subdivide in Zb seems problematic so subdivided is made in SU ๐Ÿ˜’
                  Here podium bump maxi, render with "biebel_settings.xml" who is this guy? ๐Ÿ’š
                  Model by Orgelf
                    Julius
                    http://img379.imageshack.us/img379/6339/13474370hn5.jpg
                    did i do something wrong?
                    and how do you porject them? ๐Ÿ’š
                    also, is it possible to make such stunning bump maps in KT, like the second image kwist posted?
                    • FrederikF Offline
                      Frederik
                      I import the JPG and once you explode the JPG, it will be available in your "In model" materials as a Projected material ready to be applied on a surface... ๐Ÿ˜‰
                      To me it doesn't look like Bump mapping... ๐Ÿ˜
                      I assume that Kwistenbiebel have used Displacement mapping, which isn't availeble in KT2008...
                      Cheers
                      Kim Frederik
                        Daniel Bouchard
                        Thanks for this tutorial Kwistenbiebel.
                        Very useful for me.
                        Daniel
                        • K Offline
                          kwistenbiebel
                          @frederik said:
                          I assume that Kwistenbiebel have used Displacement mapping...
                          Indeed, I used displacement maps on the object.
                          It works just like adding a bump map ( a Black@White image defining depth).
                          The only difference is that displacement will actually deform the geometry by subdividing it to show depth, while a bump map is only mimicing it.
                          Curently displacement is supported by Vray, Fry, Maxwell and Indigo.
                          For architectural scenes, bump maps most of the times are sufficient, as displacement tends to increase render time considerably. But the results can be convincing.
                          This is an example of displacement on that same form using (SK)indigo:
                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/displ-2a.jpg
                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/displ1c.jpg
                            Macro photography ๐Ÿ˜‰
                            • david_hD Offline
                              david_h
                              Biebel . . .you just amaze me. . .. ๐Ÿ‘
                                Click Draw
                                I love this forum. I've learned so much more since I joined. Thx to everyone! Great tutorial. I got the material distributing evenly, I just have to learn to texture properly....
                                Jeff
                                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                • pbacotP Offline
                                  This is amazing. I never saw displacement like this before. Not that I have experience rendering. But I can use the texturing technique right away. Thanks for posting so people like me can get "edicated"! B
                                    Click Draw
                                    Hi Kwistenbiebel,
                                    Any chance of you doing a Tut on the technique of bump mapping or the way you put or change the actual surface texture? Or, is this something done in another program? I got the understanding of evenly patterning a material but you have pics showing that the surface is not smooth. Thanks in advance....
                                    Jeff
                                      Hi Jeff,
                                      SU doesn't support either bupmapping or displacement. That part was done in a 3rd party renderer.
                                        Click Draw
                                        Thanks Gaieus,
                                        Appreciate that. So that would be one like Podium or Vray?
                                        Jeff
                                          Yes exactly. Even some of those do not do displacement (like Kerkythea at the moment)
                                            Click Draw
                                            What is your preferrance for a rendering program. I'd like to get as much feedback and opinions as possible before I layout the money.
                                            Jeff
                                            • 1 / 2
