    [Plugin] UVTools v0.1
    180 Posts 71 Posters 159.6k Views 71 Watching
    • W
      Whaat
      This plugin is a work in progress. There is much functionality yet to be added but it is still quite useful in it's current state so I am releasing it.
      Installation:
      1. Copy to SketchUp/Plugins folder
      Usage:
      1. The plugin will create a context menu called 'UVTools'
      2. Select the faces that you want to project. The faces should all have the same texture applied to them.
      3. Select 'Spherical' or 'Cylindrical' from the context menu. The axis of the sphere or cylinder will be parallel to the SketchUp Z-axis and will be located at the center of the all the selected faces. There is currently no option to change this.
      4. After performing the projection, you can change the amount of tiling by changing the texture size in the SU Paint Bucket.
      Known Issues:
      1. Texture position is messed up at the 'poles' of the spherical projection.
      2. The plugin may fail due to certain types of faces. No error message will be displayed to the user. (I'll try to fix this, soon.)
      Enjoy!
      Whaat
      Version 0.1
      • D
        Dan
        Very nice - very useful - very promising !
        Thanks for sharing those gems, Whaat!
        • CadFatherC
          CadFather
          Whaat Thank You!
          lately i'm not even sure what program i'm working on! πŸ˜„
          • jujuJ
            juju
            β˜€ fanks man! β˜€
            • StinkieS
              Stinkie
              Much obliged. πŸ‘
              • R
                remus
                Cheers, i look forward to trying this plugin out.
                • jenujacobJ
                  jenujacob
                  all hail the whaat machine! πŸ˜„ 😍
                  • D
                    dylan
                    Cool, I shall go and play with this now - Thanks πŸ‘
                    http://dmdarchitecture.co.uk/
                    • ibonI
                      ibon
                      Thanks, Whaat. It's perfect! πŸ‘
                      • K
                        kwistenbiebel
                        Yeah πŸ˜„....Thank god you didn't leave for Basecamp and stuck with us to deliver some goodies.
                        Better news over here than @Boulder ?..... πŸ˜„
                        Thank you very much Whaat! πŸ‘
                        • FrederikF
                          Frederik
                          Thank you so much..!! 😍
                          I read somewhere that people are calling you WhaatUp... πŸ˜„ No wonder why..!! πŸ˜‰
                          Cheers
                          Kim Frederik
                          • J
                            Jon
                            Whaat, you ROCK! 😍 😍 😍
                            Jon
                            KT Team member
                            • K
                              kwistenbiebel
                              I thought it was Whaat'sUp πŸ˜„
                              • FrederikF
                                Frederik
                                You're right, Chris... 😳
                                Of course it's Whaat'sUp... πŸ˜„
                                (I actually wrote that to begin with, but got unsure... πŸ˜† )
                                Cheers
                                Kim Frederik
                                • boofredlayB
                                  boofredlay
                                  No you are both wrong... it's:
                                  WhaatzzzUp!
                                  With your tongue sticking out...
                                  http://www.bouncyfuncastles.com/Smiley_Tounge.gif
                                  Thanks again for another nice plugin!
                                  • StinkieS
                                    Stinkie
                                    Tip: trying this plugin on an untextured object causes the fastest splat you've ever seen. Zappp - and SU's gone. πŸ’š
                                    • W
                                      Whaat
                                      Thanks for the comment. This is an easy fix.
                                      • StinkieS
                                        Stinkie
                                        Cool. Been fiddling with this baby - works pretty well! Well-integrated too. πŸ‘
                                        • W
                                          watkins
                                          Dear Dale,
                                          I have very little experience of rendering and I tend not to texture my models, so I am not too sure how to use a UV tool. By the way, what does UV stand for? If I understand your post correctly, the tool 'wraps' a texture around a curved object by projecting the texture from a plane positioned over and/or under the object. Further, the plane should be positioned so that its normal is along the centreline of the curved object which is itself aligned with the z-axis. Is this correct?
                                          Can one project/wrap textures from a plane over and a plane under an object by dividing the surface area of the object into two along an x-y plane? I imagine a vase with different designs on the upper and lower halves.
                                          Sorry for being so dense.
                                          Kind regards,
                                          Bob
                                          • R
                                            remus
                                            http://en.wikipedia.org/wiki/UV_mapping
                                            Theres a good illustration of spherical UV mapping there.
                                            And i tihnk UV is just he coordinaet system thats used when applying textures in this way, so thats where the name comes from.
                                            • 8
                                            • 9
                                            • 1 / 9
