    [Plugin] Polyreducer 0.1
    61 Posts 45 Posters 136.5k Views 45 Watching
      cecilia
      Hi guys,
      thank you for the plugin! I am sure it works great...but I have not understood how to install it! πŸ˜„ I dropped the file into the plugins directory but when I right click on surfaces, no "Polyreduction" button appears in the menu. I am using Sketchup 7 on MAC. Am I missing something? Thank you for the support!
        sasasoso
        hi all
        thnx for this great plugin
        but i dont know why i cant install it
        i copy past at mu su plugins folder
        but unfortunately it doesnt appeare in the program
        i use su 8 and 6
        can any one help me undestand howto install this plugin ???
          dtrarch
          FYI ALL
          Works with basic triangulated obj in SU 8 PRO OK. πŸ‘
          dtr
          • P Offline
            PickledZebra
            Hmmm... I'm fairly noobish when it comes to sketchUp.
            This plugin looks very useful to me, but I can't seem to
            get it to do anything in SU8 Pro.
            I select object, and ask it to reduce polys and it does nothing. Doesn't hang, just doesn't respond.
            Does the object need to be triangulated, and if so, how does one do that? Hopefully not by exporting and reimporting.
            thanks!
            • K Offline
              Kvad
              This is awesome!
              Thanks!
              • F Offline
                fdd921
                why it doesn't work in SketchUp 8?
                Also there are similar plugins so I can try them?
                  It works on SketchUp 8 for me but the one in Artisan is much better. You should use that.
                    bernzgb
                    Thanks so much for the plugin! Maybe my frustations in rendering crashes will end now...
                    • I Offline
                      inti11644
                      how do I use this in sketchup 2016
                      • bazB Offline
                        baz
                        First post eh?
                          From the first post in this thread:
                          @whaat said:
                          Usage:
                          1. Select the faces that you want to perform the reduction on.
                          2. Right click and select 'Polyreduce' from the context menu.
                          3. Input the percentage reduction. For example, select 20 to reduce the number of vertices by 20%.
                          4. A recommended workflow is to perform several reductions using a smaller percentage (50% or less). Then, use the 'undo' and 'redo' commands to cycle through the reduction operations to choose the level of detail you are most satisfied with.
                            AppleBear
                            Thank you to share, to give it a try
                            • G Offline
                              gaquandui
                              how to install Polyreducer in the sketchup 2017?
                                Use the Sketchucation Extension Store. Download it, go to Window>Extension Manager and select Install Extension. Find the rbz file, select it, click Open and the affirmative answers to the next message boxes. From there, you can install any extensions from Sketchucation automatically.
                                • ZackJordsZ Offline
                                  ZackJords
                                  Thank you so much Dale
                                  • G Offline
                                    Gerardus
                                    Hi guys,
                                    I installed this extension ( several times ), but can't find it back in SU 2017.
                                    Any tips please?
                                      @gerardus said:
                                      Hi guys,
                                      Any tips please?
                                      How did you install it? Where are you looking for it "back in SketchUp"?
                                        Assuming that all other installation issues are addressed and it's still compatible with v2017... [ it is almost a decade old ! ], then, as its simple instructions explain, you need to select some faces and right-click > context-menu... to run the tool.
                                        Remember that not every tool has a menu entry or a toolbar.
                                          Use of Polyreducer : RighClick on the object! πŸ˜‰
                                          http://s6.postimg.cc/ci4lzyqz5/GIF_polyreduce.gif
                                          • I Offline
                                            ISAWHIM
                                            Any chance to "fix" this so that it works in 2018+
                                            The drop-down list has the option to select values that don't work, due to a text-issue?
                                            ("10
                                            20
                                            30
                                            40
                                            50
                                            60
                                            70
                                            80
                                            90")
                                            10 and 90 don't work, but they are "doing something", which can be undone. However, if you don't "undo", it can break the model.
                                            Seems like it is just a simple format issue for the list. (Apparently reading the value from the list, instead of reading the values from an INDEX of a LIST. So, the odd text in the first and last values sort-of break the script.)
                                            Personally... I would like to see a slider with 1%, 2% or 5% increments. Maybe also an option to just do a triangulation first, as 0%... Something that would yield some "corrective action", before reducing polygons, if needed. (I don't always agree with the way it triangulates some surfaces, as it doesn't favor neat reductions. Being able to see the way it is going to divide it, before reducing it, allows for some manual triangulation of those potential troubled parts.)
                                            Another option would be to subdivide first... (Creating a smoother potential which to begin a more accurate reduction that may retain those micro-details more, without harming large flat surfaces as much.)
                                            • 3 / 4
