    [Plugin] Polyreducer 0.1
    61 Posts 45 Posters 138.4k Views 45 Watching
      You could check the edge state of the faces before replacement. Normal, hidden, smoothed, soft etc and then for each new face make it's edges to match...
      • honoluludesktopH Offline
        honoluludesktop
        I get it. I think? The first polyreduce makes the triangular faces, then the follow up polyreduce combine the faces. I was expecting to maintain the 4 sided polygons, but guess that can't be helped.
        Thanks.
        If I didn't get it, what did you do?
        • david_hD Offline
          david_h
          Is there any chance of adding a "timer" or a "ticker" to the Ruby so we can tell that something is going on rather than it just sitting there? I have tried to use it and think its great, but on large polys it seems that it just "locks up".
          Thanks,
          D
          • Chris FullmerC Offline
            Unfortunately when it locks up like that, that means it will also lock up the ticker. But genereally with the plugins, they are still working strong until there is a plat. So if it is just locked, the plugin is still doing its work.
            The only thing that a display could do, like Todd's progressbar does, is it at least tried to guess how long it will take. So when it does freeze, at least it shows it best guess for what time it will complete processing at. That can be fairly reliable or completely un reliable depending on how it is implemented and what type of processes are being run by the script,
            • david_hD Offline
              david_h
              Understood. .. but it would be nice to see that it is doing something so I don't think . ..
              hmmm. .. I wonder if it's locked up or not. I better shut it down and restart.
              Just a thought.
              Thanx C.
              D
                cecilia
                Hi guys,
                thank you for the plugin! I am sure it works great...but I have not understood how to install it! πŸ˜„ I dropped the file into the plugins directory but when I right click on surfaces, no "Polyreduction" button appears in the menu. I am using Sketchup 7 on MAC. Am I missing something? Thank you for the support!
                  sasasoso
                  hi all
                  thnx for this great plugin
                  but i dont know why i cant install it
                  i copy past at mu su plugins folder
                  but unfortunately it doesnt appeare in the program
                  i use su 8 and 6
                  can any one help me undestand howto install this plugin ???
                    dtrarch
                    FYI ALL
                    Works with basic triangulated obj in SU 8 PRO OK. πŸ‘
                    dtr
                      PickledZebra
                      Hmmm... I'm fairly noobish when it comes to sketchUp.
                      This plugin looks very useful to me, but I can't seem to
                      get it to do anything in SU8 Pro.
                      I select object, and ask it to reduce polys and it does nothing. Doesn't hang, just doesn't respond.
                      Does the object need to be triangulated, and if so, how does one do that? Hopefully not by exporting and reimporting.
                      thanks!
                        Kvad
                        This is awesome!
                        • F Offline
                          fdd921
                          why it doesn't work in SketchUp 8?
                          Also there are similar plugins so I can try them?
                            It works on SketchUp 8 for me but the one in Artisan is much better. You should use that.
                              bernzgb
                              Thanks so much for the plugin! Maybe my frustations in rendering crashes will end now...
                              • I Offline
                                inti11644
                                how do I use this in sketchup 2016
                                • bazB Offline
                                  baz
                                  First post eh?
                                    From the first post in this thread:
                                    @whaat said:
                                    Usage:
                                    1. Select the faces that you want to perform the reduction on.
                                    2. Right click and select 'Polyreduce' from the context menu.
                                    3. Input the percentage reduction. For example, select 20 to reduce the number of vertices by 20%.
                                    4. A recommended workflow is to perform several reductions using a smaller percentage (50% or less). Then, use the 'undo' and 'redo' commands to cycle through the reduction operations to choose the level of detail you are most satisfied with.
                                      AppleBear
                                      Thank you to share, to give it a try
                                        gaquandui
                                        how to install Polyreducer in the sketchup 2017?
                                          Use the Sketchucation Extension Store. Download it, go to Window>Extension Manager and select Install Extension. Find the rbz file, select it, click Open and the affirmative answers to the next message boxes. From there, you can install any extensions from Sketchucation automatically.
                                          • ZackJordsZ Offline
                                            ZackJords
                                            Thank you so much Dale
                                            • 3 / 4
