    [Plugin] Polyreducer 0.1
    61 Posts 45 Posters 139.6k Views 45 Watching
    • david_hD
      david_h
      Understood. .. but it would be nice to see that it is doing something so I don't think . ..
      hmmm. .. I wonder if it's locked up or not. I better shut it down and restart.
      Just a thought.
      Thanx C.
      D
      • C
        cecilia
        Hi guys,
        thank you for the plugin! I am sure it works great...but I have not understood how to install it! πŸ˜„ I dropped the file into the plugins directory but when I right click on surfaces, no "Polyreduction" button appears in the menu. I am using Sketchup 7 on MAC. Am I missing something? Thank you for the support!
          sasasoso
          hi all
          thnx for this great plugin
          but i dont know why i cant install it
          i copy past at mu su plugins folder
          but unfortunately it doesnt appeare in the program
          i use su 8 and 6
          can any one help me undestand howto install this plugin ???
            dtrarch
            FYI ALL
            Works with basic triangulated obj in SU 8 PRO OK. πŸ‘
            dtr
            • P
              PickledZebra
              Hmmm... I'm fairly noobish when it comes to sketchUp.
              This plugin looks very useful to me, but I can't seem to
              get it to do anything in SU8 Pro.
              I select object, and ask it to reduce polys and it does nothing. Doesn't hang, just doesn't respond.
              Does the object need to be triangulated, and if so, how does one do that? Hopefully not by exporting and reimporting.
              thanks!
              • K
                Kvad
                This is awesome!
                • F
                  fdd921
                  why it doesn't work in SketchUp 8?
                  Also there are similar plugins so I can try them?
                    It works on SketchUp 8 for me but the one in Artisan is much better. You should use that.
                    • B
                      bernzgb
                      Thanks so much for the plugin! Maybe my frustations in rendering crashes will end now...
                      • I
                        inti11644
                        how do I use this in sketchup 2016
                        • bazB
                          baz
                          First post eh?
                            From the first post in this thread:
                            @whaat said:
                            Usage:
                            1. Select the faces that you want to perform the reduction on.
                            2. Right click and select 'Polyreduce' from the context menu.
                            3. Input the percentage reduction. For example, select 20 to reduce the number of vertices by 20%.
                            4. A recommended workflow is to perform several reductions using a smaller percentage (50% or less). Then, use the 'undo' and 'redo' commands to cycle through the reduction operations to choose the level of detail you are most satisfied with.
                              AppleBear
                              Thank you to share, to give it a try
                              • G
                                gaquandui
                                how to install Polyreducer in the sketchup 2017?
                                  Use the Sketchucation Extension Store. Download it, go to Window>Extension Manager and select Install Extension. Find the rbz file, select it, click Open and the affirmative answers to the next message boxes. From there, you can install any extensions from Sketchucation automatically.
                                  • ZackJordsZ
                                    ZackJords
                                    Thank you so much Dale
                                    • G
                                      Gerardus
                                      Hi guys,
                                      I installed this extension ( several times ), but can't find it back in SU 2017.
                                      Any tips please?
                                        @gerardus said:
                                        Hi guys,
                                        Any tips please?
                                        How did you install it? Where are you looking for it "back in SketchUp"?
                                          Assuming that all other installation issues are addressed and it's still compatible with v2017... [ it is almost a decade old ! ], then, as its simple instructions explain, you need to select some faces and right-click > context-menu... to run the tool.
                                          Remember that not every tool has a menu entry or a toolbar.
                                            Use of Polyreducer : RighClick on the object! πŸ˜‰
                                            http://s6.postimg.cc/ci4lzyqz5/GIF_polyreduce.gif
                                            • 3 / 4
