    [Plugin] Polyreducer 0.1
    61 Posts 45 Posters 136.5k Views 45 Watching
    • CadFatherC Offline
      CadFather
      Thanks Whaat - i have the feeling you will come back to it again if only as a module for something else.. very interesting!
      • V Offline
        vampa
        This is wonderful, im a noobie and have been trying to reduce polygones to a sphere until i found this, you made my day ๐Ÿ˜„
        • F Offline
          farukahmet
          @ely862me said:
          i don t know how this should woork but for me it doesn t
          first i create a shape and when i clicked polyreduce it cuted half of the polys
          then i take a hood of a car and i clicked polyreduce and it start counting something and doing nothing it says like that : colapsed (i wait until)2 milion from 98 edges
          Same here ๐Ÿ˜
            mpowell1234567890
            Think I found a bug. Polyreducer 0.1 freezes sketchup. Whenever I try to click on the model, nothing happens..
              Not me. My comp starts choking at 1.2 million only. ๐Ÿ‘Š
              I could hardly get along with this model...
              ๐Ÿ˜’ ๐Ÿ˜’ ๐Ÿ˜’
              Sorry for keeping the thread OT, Dale- thanks for this gem again! ๐Ÿ‘
                remus
                Mpowell, i think it freezes sketchup because it needs to do a lot of calculations. Its not really a bug, just a feature of the plugin.
                • H Offline
                  human
                  here is the sphere before polyreduce:
                  http://farm3.static.flickr.com/2230/2519275834_f0d4a92872.jpg?v=0
                  After:
                  http://farm3.static.flickr.com/2053/2519264374_cda07d315e.jpg?v=0
                  But when i try to paint the sphere:
                  http://farm4.static.flickr.com/3069/2518465569_6e66c9023b.jpg?v=0
                  • W Offline
                    Whaat
                    ok, I understand what your question is. When the plugin reduces the polygons, it creates new polygons with hard edges. If you want to be able to select all the faces with one click:
                    1)triple click to select all connected faces
                    2) go to window->soften edges
                    3) drag the slider to the right until all of the edges are softened.
                    I think you may have edge display turned off (it's in your 'styles' window). Otherwise, you probably would have noticed the hard edges and figured out the problem.
                    • I Offline
                      ilay7k
                      How do think Dale, can you make like this http://www.donyalabs.com/files/Polypen_donya_mesh_reduction.wmv ?
                      It will be nice feature - backtracking reducer
                      • plot-parisP Offline
                        plot-paris
                        another great feature would be to adjust poly density throughout the model.
                        for example if you use follow me on a rather complicated curve with a varying radius, the resulting shape will have different polygon density. or if you create a difficult model in seperate pieces that are combined later, they might be different in detail.
                        now it would be very comfortable to tell the polyreducer to adjust the poly amount to a common level. ๐Ÿ˜†
                          blugarero
                          awesome plug-in. very useful for building physical models of more organic forms(using the triangles as stencils)
                            linea
                            thanks whaat!
                            • X Offline
                              xrok1
                              this would be a great option to add to sub&smooth ruby!
                              โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                              • honoluludesktopH Offline
                                honoluludesktop
                                Having problems with this model. Any help?
                                Test01.skp
                                Before / After polyreducer
                                • soloS Offline
                                  solo
                                  try these.
                                  test hon1.skp
                                  test hon2.skp
                                  http://www.solos-art.com
                                    You could check the edge state of the faces before replacement. Normal, hidden, smoothed, soft etc and then for each new face make it's edges to match...
                                      honoluludesktop
                                      I get it. I think? The first polyreduce makes the triangular faces, then the follow up polyreduce combine the faces. I was expecting to maintain the 4 sided polygons, but guess that can't be helped.
                                      Thanks.
                                      If I didn't get it, what did you do?
                                      • david_hD Offline
                                        david_h
                                        Is there any chance of adding a "timer" or a "ticker" to the Ruby so we can tell that something is going on rather than it just sitting there? I have tried to use it and think its great, but on large polys it seems that it just "locks up".
                                        Thanks,
                                        D
                                        • Chris FullmerC Offline
                                          Unfortunately when it locks up like that, that means it will also lock up the ticker. But genereally with the plugins, they are still working strong until there is a plat. So if it is just locked, the plugin is still doing its work.
                                          The only thing that a display could do, like Todd's progressbar does, is it at least tried to guess how long it will take. So when it does freeze, at least it shows it best guess for what time it will complete processing at. That can be fairly reliable or completely un reliable depending on how it is implemented and what type of processes are being run by the script,
                                          Chris
                                          All my Plugins I've written
                                          • david_hD Offline
                                            david_h
                                            Understood. .. but it would be nice to see that it is doing something so I don't think . ..
                                            hmmm. .. I wonder if it's locked up or not. I better shut it down and restart.
                                            Just a thought.
                                            Thanx C.
                                            D
                                            • 2 / 4
