    [Plugin] Polyreducer 0.1
    61 Posts 45 Posters 136.7k Views 45 Watching
      remus
      File size isnt really very important unless your creating absolutely monstorous files. What does matter however is face count. You can have a 100mb file open easily if its got 50,000 faces, but if its got more than 200,000 faces your in for a hard time.
      So basically face count is more important than file size pretty much all the time.
      • I Offline
        ilay7k
        ehhh...can you(Whaat) add real-time trigger as at standard smoothing tool?
        • ely862meE Offline
          ely862me
          i don t know how this should woork but for me it doesn t
          first i create a shape and when i clicked polyreduce it cuted half of the polys
          then i take a hood of a car and i clicked polyreduce and it start counting something and doing nothing it says like that : colapsed (i wait until)2 milion from 98 edges
          Elisei (sketchupper)
          Come and See EliseiDesign
            remus
            No need to boast coen ๐Ÿ˜›
            • W Offline
              Whaat
              @solo said:
              We gonna have to start naming this software 'Whaats-up' soon.
              ๐Ÿ˜† ๐Ÿ˜†
              • H Offline
                human
                Wow, nice plugin. ๐Ÿ‘ compliments Subdivide and Smooth perfectly. Strange thing is...
                Say i create a sphere. i right click and choose polyreduce. and it works, but i cant select all the faces with one click. now there are lots of faces that make up the poly-reduced sphere. ๐Ÿ˜ž Hmmmmmm...
                • W Offline
                  Whaat
                  What do you mean by 'can't select all the faces with one click' ๐Ÿ˜•
                  Maybe you can post a screenshot of the reduced sphere??
                  • CadFatherC Offline
                    CadFather
                    Thanks Whaat - i have the feeling you will come back to it again if only as a module for something else.. very interesting!
                    • V Offline
                      vampa
                      This is wonderful, im a noobie and have been trying to reduce polygones to a sphere until i found this, you made my day ๐Ÿ˜„
                      • F Offline
                        farukahmet
                        Same here ๐Ÿ˜
                          mpowell1234567890
                          Think I found a bug. Polyreducer 0.1 freezes sketchup. Whenever I try to click on the model, nothing happens..
                            Not me. My comp starts choking at 1.2 million only. ๐Ÿ‘Š
                            I could hardly get along with this model...
                            ๐Ÿ˜’ ๐Ÿ˜’ ๐Ÿ˜’
                            Sorry for keeping the thread OT, Dale- thanks for this gem again! ๐Ÿ‘
                              remus
                              Mpowell, i think it freezes sketchup because it needs to do a lot of calculations. Its not really a bug, just a feature of the plugin.
                              • H Offline
                                human
                                here is the sphere before polyreduce:
                                http://farm3.static.flickr.com/2230/2519275834_f0d4a92872.jpg?v=0
                                After:
                                http://farm3.static.flickr.com/2053/2519264374_cda07d315e.jpg?v=0
                                But when i try to paint the sphere:
                                http://farm4.static.flickr.com/3069/2518465569_6e66c9023b.jpg?v=0
                                • W Offline
                                  Whaat
                                  ok, I understand what your question is. When the plugin reduces the polygons, it creates new polygons with hard edges. If you want to be able to select all the faces with one click:
                                  1)triple click to select all connected faces
                                  2) go to window->soften edges
                                  3) drag the slider to the right until all of the edges are softened.
                                  I think you may have edge display turned off (it's in your 'styles' window). Otherwise, you probably would have noticed the hard edges and figured out the problem.
                                  • I Offline
                                    ilay7k
                                    How do think Dale, can you make like this http://www.donyalabs.com/files/Polypen_donya_mesh_reduction.wmv ?
                                    It will be nice feature - backtracking reducer
                                    • plot-parisP Offline
                                      plot-paris
                                      another great feature would be to adjust poly density throughout the model.
                                      for example if you use follow me on a rather complicated curve with a varying radius, the resulting shape will have different polygon density. or if you create a difficult model in seperate pieces that are combined later, they might be different in detail.
                                      now it would be very comfortable to tell the polyreducer to adjust the poly amount to a common level. ๐Ÿ˜†
                                        blugarero
                                        awesome plug-in. very useful for building physical models of more organic forms(using the triangles as stencils)
                                          linea
                                          thanks whaat!
                                          • X Offline
                                            xrok1
                                            this would be a great option to add to sub&smooth ruby!
                                            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                            • 2 / 4
