    [Plugin] Polyreducer 0.1
    61 Posts 45 Posters 136.7k Views 45 Watching
      Not me. My comp starts choking at 1.2 million only. ๐Ÿ‘Š
      I could hardly get along with this model...
      ๐Ÿ˜’ ๐Ÿ˜’ ๐Ÿ˜’
      Sorry for keeping the thread OT, Dale- thanks for this gem again! ๐Ÿ‘
        remus
        Mpowell, i think it freezes sketchup because it needs to do a lot of calculations. Its not really a bug, just a feature of the plugin.
        • H Offline
          human
          here is the sphere before polyreduce:
          http://farm3.static.flickr.com/2230/2519275834_f0d4a92872.jpg?v=0
          After:
          http://farm3.static.flickr.com/2053/2519264374_cda07d315e.jpg?v=0
          But when i try to paint the sphere:
          http://farm4.static.flickr.com/3069/2518465569_6e66c9023b.jpg?v=0
          • W Offline
            Whaat
            ok, I understand what your question is. When the plugin reduces the polygons, it creates new polygons with hard edges. If you want to be able to select all the faces with one click:
            1)triple click to select all connected faces
            2) go to window->soften edges
            3) drag the slider to the right until all of the edges are softened.
            I think you may have edge display turned off (it's in your 'styles' window). Otherwise, you probably would have noticed the hard edges and figured out the problem.
            • I Offline
              ilay7k
              How do think Dale, can you make like this http://www.donyalabs.com/files/Polypen_donya_mesh_reduction.wmv ?
              It will be nice feature - backtracking reducer
              • plot-parisP Offline
                plot-paris
                another great feature would be to adjust poly density throughout the model.
                for example if you use follow me on a rather complicated curve with a varying radius, the resulting shape will have different polygon density. or if you create a difficult model in seperate pieces that are combined later, they might be different in detail.
                now it would be very comfortable to tell the polyreducer to adjust the poly amount to a common level. ๐Ÿ˜†
                  blugarero
                  awesome plug-in. very useful for building physical models of more organic forms(using the triangles as stencils)
                    linea
                    thanks whaat!
                    • X Offline
                      xrok1
                      this would be a great option to add to sub&smooth ruby!
                      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                      • honoluludesktopH Offline
                        honoluludesktop
                        Having problems with this model. Any help?
                        Test01.skp
                        Before / After polyreducer
                        • soloS Offline
                          try these.
                          test hon1.skp
                          test hon2.skp
                            You could check the edge state of the faces before replacement. Normal, hidden, smoothed, soft etc and then for each new face make it's edges to match...
                              honoluludesktop
                              I get it. I think? The first polyreduce makes the triangular faces, then the follow up polyreduce combine the faces. I was expecting to maintain the 4 sided polygons, but guess that can't be helped.
                              Thanks.
                              If I didn't get it, what did you do?
                              • david_hD Offline
                                david_h
                                Is there any chance of adding a "timer" or a "ticker" to the Ruby so we can tell that something is going on rather than it just sitting there? I have tried to use it and think its great, but on large polys it seems that it just "locks up".
                                Thanks,
                                D
                                • Chris FullmerC Offline
                                  Unfortunately when it locks up like that, that means it will also lock up the ticker. But genereally with the plugins, they are still working strong until there is a plat. So if it is just locked, the plugin is still doing its work.
                                  The only thing that a display could do, like Todd's progressbar does, is it at least tried to guess how long it will take. So when it does freeze, at least it shows it best guess for what time it will complete processing at. That can be fairly reliable or completely un reliable depending on how it is implemented and what type of processes are being run by the script,
                                  • david_hD Offline
                                    david_h
                                    Understood. .. but it would be nice to see that it is doing something so I don't think . ..
                                    hmmm. .. I wonder if it's locked up or not. I better shut it down and restart.
                                    Just a thought.
                                    Thanx C.
                                    D
                                      cecilia
                                      Hi guys,
                                      thank you for the plugin! I am sure it works great...but I have not understood how to install it! ๐Ÿ˜„ I dropped the file into the plugins directory but when I right click on surfaces, no "Polyreduction" button appears in the menu. I am using Sketchup 7 on MAC. Am I missing something? Thank you for the support!
                                        sasasoso
                                        hi all
                                        thnx for this great plugin
                                        but i dont know why i cant install it
                                        i copy past at mu su plugins folder
                                        but unfortunately it doesnt appeare in the program
                                        i use su 8 and 6
                                        can any one help me undestand howto install this plugin ???
                                          dtrarch
                                          FYI ALL
                                          Works with basic triangulated obj in SU 8 PRO OK. ๐Ÿ‘
                                          dtr
                                            PickledZebra
                                            Hmmm... I'm fairly noobish when it comes to sketchUp.
                                            This plugin looks very useful to me, but I can't seem to
                                            get it to do anything in SU8 Pro.
                                            I select object, and ask it to reduce polys and it does nothing. Doesn't hang, just doesn't respond.
                                            Does the object need to be triangulated, and if so, how does one do that? Hopefully not by exporting and reimporting.
                                            thanks!
                                            • 2 / 4
