    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 46.6k Views 32 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Following a request by Jorgensen, I just come up with this little utility to quickly draw lintels above doors when raising plans from 2D drawing.
      It detects incorrect door height, non-parallel wall sides, suspicious opening width, non-connectable wall side, obstructive object crossing the lintel.
      French version also available at the Ruby Depot (Architecture section).
      Enjoy,
      EDIT 1:
      Some quick usage notes:
      • Default door height: 2m
      • You don't have to enter it first if this is the height you want to use. Once a height is set, it will be used unless you change it.
      • select a wall side where you want the door-lintel to be (I don't know the right english word for it but I think this is "embrasure"). Select the option in the Plugins menu. That's all.
      I had first put the option in the context menu, but Jorgensen thought it will be better located in the pull-down menu. If you prefer a context menu option, it can be done of course.
      Oh, and the window option is a nice idea (why didn't I thought about it myself ??? 😆 )
      EDIT 2 (16 May):
      Updated for windows. Enter sill and window heights in the Plugins menu, usage is the same than for doors.
      EDIT 3 (18 May):
      Plugins menu option fixed.
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=door_lintel
      Version française. A mettre dans votre dossier Plugins.
      English version. Put it in your Plugins folder.
      DB
      • I Offline
        ilay7k
        Incredible work!!!
        very useful!
        Thanks a'lot...
        BTW...if chose incorrect height of door(wrong measure of walls) , put 0(nill) in dialog(and it doesn't to tire with request)
          Jorgensen
          And nice it is 😍
          Many thanks Didier
          sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
          • Mike LuceyM Offline
            Mike Lucey
            Didier, that must be the fastest Ruby resquest turnaround I've seen.
            Thanks, it will be a great time saver.
            Mike
            • erikBE Offline
              erikB
              Didier, thanks very much this is really a very handy ruby !!
              Now if there was an option for windows it would be fantastic. As far as I am concerned it also could be a 'standard' height for the distance of the floor and height of the lintel. This often changes during the design anyway and can easy be changed with push/pull afterwards.
              erikB
              • I Offline
                ilay7k
                ErikB, magic cutting_windows-script(by Didier...again 😉) will be useful for you!
                • JClementsJ Offline
                  JClements
                  It does nothing for me. I input a door height of 6', click OK, and that is it. The script ends.door_lentel error.jpg. The same thing happens whether the walls are preselected or not.
                  • david_hD Offline
                    david_h
                    I just gave this one a test drive. Works Great. huge Time saver.
                    Merci, Mon ami.
                    D
                      @jclements said:
                      It does nothing for me. I input a door height of 6', click OK, and that is it. The script ends.[attachment=0:3m6z38nq]<!-- ia0 -->door_lentel error.jpg<!-- ia0 -->[/attachment:3m6z38nq]. The same thing happens whether the walls are preselected or not.
                      What happens if you enter 72 for the height?
                      • majidM Offline
                        majid
                        it doesn't work for me too 😞 .nothing happens! i saw the swf , but i don't know where i am rong!!
                        • I Offline
                          ilay7k
                          "door.skp" example with description was included in package(From: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/door_lintel.zip)
                          • majidM Offline
                            majid
                            thanx .... it was so useful 👍 (none of the smilies shows my respect truely )
                              dylan
                              Excellent Didier, thankyou for this 👍
                              http://dmdarchitecture.co.uk/
                              • EdsonE Offline
                                Edson
                                i managed to install it but i do not know how to make it work.
                                what is the 1st thing to do? set the door height? and then what? could you take me through the steps?
                                http://www.mahfuz.arq.br
                                  dylan
                                  Edson check out ilay7k's post three up from yours. There is a link to a skp explaining.
                                  • EdsonE Offline
                                    Edson
                                    thanks, dylan. but that is not what i asked for.
                                      Edson, I set the door height, selected the side of the door opening and then chose the other option in the plugin's menu.
                                      • EdsonE Offline
                                        Edson
                                        this is what happens when i run the script. notice there is no lintel. the result was just the disapearance of a back face and the shortening of the wall on the side where i selected a face to start the lintel from.
                                        small room with a door before running the script
                                        small room with a door AFTER running the script:
                                          Edson, is that your back face color?. Try this. Before pulling the walls up, delete the floor so the walls pull up right side out.
                                          • EdsonE Offline
                                            Edson
                                            thanks, dave. i ran some tests and the problem seems to have been the fact that the faces were reversed for the script to work. leaving the floor on was no problem.
                                            • 1 / 4
