    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 440.0k Views 153 Watching
      Davi Melo
      This plugin is not working in Sketchup 8
      Davi Melo
      http://dm2projetos.blogspot.com/
      SKP8 - Vray 1.48
      WIN 7 ULTIMATE 64x
      INTEL CORE 2 QUAD 2.33GHz
      RAM 8GB
      NVIDIA GEFORCE 9600 GT
        Are you getting errors?
          Try this...
          http://forums.sketchucation.com/viewtopic.php?t=25801
          It works for me on v8
            Davi Melo
            Sorry, yesterday was not working, but today it is! 😳 πŸ‘Ž
            Davi Melo
            SKP8 - Vray 1.48
            WIN 7 ULTIMATE 64x
            RAM 8GB
              Davi Melo
              Try this...
              I downloaded this file
              hmmmmm...
              Stopped working again
              I do not understand, it works when it want!
              Davi Melo
              SKP8 - Vray 1.48
              WIN 7 ULTIMATE 64x
              RAM 8GB
                Works fine for me?
                [flash=800,600:2vx1cdem]http://www.youtube.com/v/HMWLepzpwds[/flash:2vx1cdem]
                  Davi Melo
                  I do not understand, sometimes works, sometimes does not work
                  Davi Melo
                  SKP8 - Vray 1.48
                  WIN 7 ULTIMATE 64x
                  RAM 8GB
                    andeciuala
                    Works fine for me?
                    [flash=800,600:1qd2nqzo]http://www.youtube.com/v/HMWLepzpwds[/flash:1qd2nqzo]
                    You need a subdivided mesh man.
                      Not neccessarily. On undivided meshes it works like the standard move tool shifting vertices. Or if you divide an edge it'll also work.
                      It's a cool plugin but I understand what you mean. It works best on subdivision.
                      • P Offline
                        pairpc
                        Thank you πŸ˜„
                          Here is an updated version http://forums.sketchucation.com/viewtopic.php?p=36127#p36127
                          Some issues with it not being in a module, use of $ variables and a flaky observer have been fixed [I hope]... πŸ€“
                            sosegon
                            I'd like to know if anyone has information about the algorithm used in this plugin.
                            Cheers.
                              @sosegon said:
                              Hi, I'd like to know if anyone has information about the algorithm used in this plugin. Cheers.
                              Get it and read it - it's a .rb file...
                                sosegon
                                @tig said:
                                Get it and read it - it a .rb file...
                                Thanks, I tried that, but since I don't speak ruby, it's been very hard to understand what the plugin is doing. That's why I asked for info about the algorithm used in the plugin. I don't necessarily need a piece of code, a brief explanation would be enough.
                                  You make a series of grouped 'control-points' [guide-points] in a 3d grid around the selected group's bounding box, these are given special attributes so they can be 'observed' later.
                                  Now later on when you change any of them [e.g. you might edit the group that contains them and 'move' some] an 'observer' kicks in, and it runs code that adjusts the geometry within the group by distorting all of the vertices relative to the 'control-points' current locations. Thus you can distort a grouped form by changing the 3d grid of 'control-points'.
                                  The rules for determining the amount of the adjustment for each vertex is done by finding the changes in the vectors between the vertices and the 'control-points' and transforming each of the vertices accordingly...
                                    sosegon
                                    That part is the most important for what I need. Now I have a better idea, thanks. If you have any link to other resources about the algorithm, it would be great.
                                    • charly2008C Offline
                                      charly2008
                                      I installed the latest Ruby in the plugins folder in Sketchup 8. I do not get it to work. In the context menu the functions are all grayed out.
                                      Charly
                                        Charly
                                        Not a tool specific issue...
                                        The context-menu gray-out is a known Sketchup issue.
                                        There is a finite number of 'commands' that can be added to the context-menu/toolbars.
                                        If you exceed this some items become 'disabled'.
                                        This was discovered a while ago as more and more scripts were added.
                                        Some scripts were found to add multiple entries, these were quickly found and fixed [e.g. all Fredo's tools latest versions are no longer implicated].
                                        I didn't write the original version of this tool but I can't see it makes more that it has too...
                                        However, having a lot of scripts loading - even if they are optimized - you can still eventually reach the limit in any case... and get the 'graying'.
                                        I suggest you decide which scripts you don't often need and disable them by renaming the with .TXT on the end. They won't then auto-load and you should thereby avoid the 'graying' issue. If you want to change them to auto-load again simply remove the .TXT from the tool's name so the .rb file auto-loads. If you want to occasionally load a .TXT file just load it from the Ruby Console with load "xxxx.rb.TXT" - where 'xxxx' is the original scripts name... it's then loaded for that session only.
                                        There is also an 'optimizer' you could try [ http://forums.sketchucation.com/viewtopic.php?p=252413#p252413 ] - but it will still fail if you clog up the 'auto-loading set' too much... It also has further reading on this whole issue πŸ˜’
                                          @TIG That's explain why this arrives with my numerous collections of plugins 😳
                                          Thx for for this enlighting explanation πŸ‘
                                            charly2008
                                            Dear TIG,
                                            You have given me and many others, again very helpful tips with your expert explanations.
                                            That was a good time to cleanup my plugin directory. I had so many plugins that I have never used or very rarely. With many more I knew not what function they have. I've promised myself that from now I install plugins only when I need it really.
                                            In my context menu, all functions are now active again and SketchyFFD works fine now and Sketchup boots faster.
                                            Many Thanks again TIG.
                                            Charly
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 20
                                            • 21
                                            • 14 / 21
