    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 484.9k Views 153 Watching
      @davi melo said:
      This plugin is not working in Sketchup 8
      Are you getting errors?
        Try this...
        http://forums.sketchucation.com/viewtopic.php?t=25801
        It works for me on v8
          Davi Melo
          Sorry, yesterday was not working, but today it is! 😳 πŸ‘Ž
          Davi Melo
          http://dm2projetos.blogspot.com/
          SKP8 - Vray 1.48
          WIN 7 ULTIMATE 64x
          INTEL CORE 2 QUAD 2.33GHz
          RAM 8GB
          NVIDIA GEFORCE 9600 GT
            Davi Melo
            Try this...
            I downloaded this file
            hmmmmm...
            Stopped working again
            I do not understand, it works when it want!
            Davi Melo
            SKP8 - Vray 1.48
            WIN 7 ULTIMATE 64x
            RAM 8GB
              Works fine for me?
              [flash=800,600:2vx1cdem]http://www.youtube.com/v/HMWLepzpwds[/flash:2vx1cdem]
                Davi Melo
                I do not understand, sometimes works, sometimes does not work
                Davi Melo
                SKP8 - Vray 1.48
                WIN 7 ULTIMATE 64x
                RAM 8GB
                  andeciuala
                  Works fine for me?
                  [flash=800,600:1qd2nqzo]http://www.youtube.com/v/HMWLepzpwds[/flash:1qd2nqzo]
                  You need a subdivided mesh man.
                    Not neccessarily. On undivided meshes it works like the standard move tool shifting vertices. Or if you divide an edge it'll also work.
                    It's a cool plugin but I understand what you mean. It works best on subdivision.
                      pairpc
                      Thank you πŸ˜„
                        Here is an updated version http://forums.sketchucation.com/viewtopic.php?p=36127#p36127
                        Some issues with it not being in a module, use of $ variables and a flaky observer have been fixed [I hope]... πŸ€“
                          sosegon
                          I'd like to know if anyone has information about the algorithm used in this plugin.
                          Cheers.
                            @sosegon said:
                            Hi, I'd like to know if anyone has information about the algorithm used in this plugin. Cheers.
                            Get it and read it - it's a .rb file...
                              sosegon
                              @tig said:
                              Get it and read it - it a .rb file...
                              Thanks, I tried that, but since I don't speak ruby, it's been very hard to understand what the plugin is doing. That's why I asked for info about the algorithm used in the plugin. I don't necessarily need a piece of code, a brief explanation would be enough.
                                You make a series of grouped 'control-points' [guide-points] in a 3d grid around the selected group's bounding box, these are given special attributes so they can be 'observed' later.
                                Now later on when you change any of them [e.g. you might edit the group that contains them and 'move' some] an 'observer' kicks in, and it runs code that adjusts the geometry within the group by distorting all of the vertices relative to the 'control-points' current locations. Thus you can distort a grouped form by changing the 3d grid of 'control-points'.
                                The rules for determining the amount of the adjustment for each vertex is done by finding the changes in the vectors between the vertices and the 'control-points' and transforming each of the vertices accordingly...
                                  sosegon
                                  That part is the most important for what I need. Now I have a better idea, thanks. If you have any link to other resources about the algorithm, it would be great.
                                  • charly2008C Offline
                                    charly2008
                                    I installed the latest Ruby in the plugins folder in Sketchup 8. I do not get it to work. In the context menu the functions are all grayed out.
                                    Charly
                                      Charly
                                      Not a tool specific issue...
                                      The context-menu gray-out is a known Sketchup issue.
                                      There is a finite number of 'commands' that can be added to the context-menu/toolbars.
                                      If you exceed this some items become 'disabled'.
                                      This was discovered a while ago as more and more scripts were added.
                                      Some scripts were found to add multiple entries, these were quickly found and fixed [e.g. all Fredo's tools latest versions are no longer implicated].
                                      I didn't write the original version of this tool but I can't see it makes more that it has too...
                                      However, having a lot of scripts loading - even if they are optimized - you can still eventually reach the limit in any case... and get the 'graying'.
                                      I suggest you decide which scripts you don't often need and disable them by renaming the with .TXT on the end. They won't then auto-load and you should thereby avoid the 'graying' issue. If you want to change them to auto-load again simply remove the .TXT from the tool's name so the .rb file auto-loads. If you want to occasionally load a .TXT file just load it from the Ruby Console with load "xxxx.rb.TXT" - where 'xxxx' is the original scripts name... it's then loaded for that session only.
                                      There is also an 'optimizer' you could try [ http://forums.sketchucation.com/viewtopic.php?p=252413#p252413 ] - but it will still fail if you clog up the 'auto-loading set' too much... It also has further reading on this whole issue πŸ˜’
                                        @TIG That's explain why this arrives with my numerous collections of plugins 😳
                                        Thx for for this enlighting explanation πŸ‘
                                          charly2008
                                          Dear TIG,
                                          You have given me and many others, again very helpful tips with your expert explanations.
                                          That was a good time to cleanup my plugin directory. I had so many plugins that I have never used or very rarely. With many more I knew not what function they have. I've promised myself that from now I install plugins only when I need it really.
                                          In my context menu, all functions are now active again and SketchyFFD works fine now and Sketchup boots faster.
                                          Many Thanks again TIG.
                                          Charly
                                            Charly
                                            Please be aware that there are some helper files that are 'required' by other files - e.g. 'progressbar.rb' is needed by Chris Fullmer's 'ShapeBender' and others, and 'deBabelizer.rb' by several of my own 'toolsets'.
                                            So if you remove/rename_with_.TXT any of those and there are other files that need them, then you will get error messages, either at startup or more rarely when the tool activates.
                                            If that happens the error-message is usually quite clear - telling you the missing file's name so it can readily find it and it can be reverted to as it was...
                                            However, so far it sounds like your 'tidy-up' has been problem free... but just in case of future oddities please bear in mind what I've just said above... πŸ˜‰
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 20
                                            • 21
                                            • 14 / 21
