    Needed badly: perforated steel sheet images
    15 Posts 8 Posters 5.3k Views 8 Watching
    • EdsonE Offline
      Edson
      i am testing a solution for a sun screen using perforated steel sheets but do not have any images that i could use as texture in my design.
      would any of you out there be kind enough to provided me with some images?
      thanks.
      http://www.mahfuz.arq.br
        sketchy
        What shape perforation are you looking for? Have you tried scaling some of the fencing materials since they have a mixture of translucent and opaque?
        I'm not sure if you are trying this but it doesn't look like a texture can cast a broken shadow.
        • EdsonE Offline
          Edson
          sketchy,
          the shape doesn't really matter as this is going to be seen from afar. what i need is something that would look metal-ish and would allow some light to filter through.
          no, i have not tried to scale fencing materials. where could i find them?
            alpro
            Edson, sepo posted a perforated steel texture on the Podium forum that might be helpful. http://www.websitetoolbox.com/tool/post/supodiumforum/vpost?id=2093378
            Scroll to the bottom of the page.
            Mike
              Charlie__V
              Edson,
              Like any of these?
              http://www.jamesgilbertandson.com/perforated.html
              Charlie
              • EdsonE Offline
                Edson
                thanks, charlie and alpro. your tips will surely help.
                  sketchy
                  I think these come with the materials bonus pack:
                  Error 404 (Not Found)!!1
                  (sketchup.google.com)
                  I tried to upload but for some reason the forum doesn't allow .skm file extension. Seems odd since this is a sketchup forum. Could any moderators explain why this is?
                  I think you will need to create actual geometry with holes in it to cast a broken shadow. The translucent materials cast no shadow. And a mixture of translucent and opaque casts full shadow.
                  Perhaps try a regular metal texture on a surface with many holes. I think this may be the only way to get the effect you want. But I could be wrong.screen.jpg
                  • jujuJ Offline
                    juju
                    Sketchy, you could always include the SKM file in a ZIP archive - the forum supports that file extension at this time.
                      SKM is in fact a zipped format sou you can even rename it zip and post it like that.
                      But I'll take care of this and add the extension. Thanks for reporting the issue.
                        sketchy
                        Well looks like that worked Gai. I suppose you need to put these in your materials folder (I also have a subfolder named fencing) and changed the .zip to .skm
                        thanks for working on the file extension change Gai
                        Fencing_Iron.zip
                        Fencing_Iron2.zip
                        Fencing_Diamond_Mesh2.zip
                        • EdsonE Offline
                          Edson
                          thanks, sketchy. it is very kind of you.
                          the attached image shows what is included in one of those folders.
                          should i change any of them to .skm or the actual zipped file?
                            bellwells
                            Edson, I may be too late but this might work. It's a metal perf. material I have that is a little transparent. It gives the illusion of being able to see through it. This is a SU5 file.
                            http://www.sketchucation.com/forums/scf/sas/ProUser/Perf%20Metal.skp
                            Ron
                            • EdsonE Offline
                              Edson
                              thanks, ron, still on time, yeah. i am working on a competition and intend to use these sheets for sun shading.
                                jwbrockman
                                Here are a couple I have. The round punched texture was found on the old sketchup forums, but I can't remember who posted it. The wire mesh is one that I made for a project last year. Both of these have transparency in the surface but will cast a solid shadow. The only way around that as far as I can tell is to actually model all of the perforations in your surface. Hope this helps anyhow.
                                perforated metal.skp
                                  sketchy
                                  I think you just want to change .zip to .skm
                                  But I have never done this before so give that a try. Or just download the entire material bonus pack. There are some goodies in there.
