    Needed badly: perforated steel sheet images
    15 Posts 8 Posters 5.6k Views 8 Watching
    • C
      Charlie__V
      Edson,
      Like any of these?
      http://www.jamesgilbertandson.com/perforated.html
      Charlie
      • EdsonE
        Edson
        thanks, charlie and alpro. your tips will surely help.
        http://www.mahfuz.arq.br
          sketchy
          I think these come with the materials bonus pack:
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          I tried to upload but for some reason the forum doesn't allow .skm file extension. Seems odd since this is a sketchup forum. Could any moderators explain why this is?
          I think you will need to create actual geometry with holes in it to cast a broken shadow. The translucent materials cast no shadow. And a mixture of translucent and opaque casts full shadow.
          Perhaps try a regular metal texture on a surface with many holes. I think this may be the only way to get the effect you want. But I could be wrong.screen.jpg
          • jujuJ
            juju
            Sketchy, you could always include the SKM file in a ZIP archive - the forum supports that file extension at this time.
            • GaieusG
              SKM is in fact a zipped format sou you can even rename it zip and post it like that.
              But I'll take care of this and add the extension. Thanks for reporting the issue.
                sketchy
                Well looks like that worked Gai. I suppose you need to put these in your materials folder (I also have a subfolder named fencing) and changed the .zip to .skm
                thanks for working on the file extension change Gai
                Fencing_Iron.zip
                Fencing_Iron2.zip
                Fencing_Diamond_Mesh2.zip
                • EdsonE
                  Edson
                  thanks, sketchy. it is very kind of you.
                  the attached image shows what is included in one of those folders.
                  should i change any of them to .skm or the actual zipped file?
                  • B
                    bellwells
                    Edson, I may be too late but this might work. It's a metal perf. material I have that is a little transparent. It gives the illusion of being able to see through it. This is a SU5 file.
                    http://www.sketchucation.com/forums/scf/sas/ProUser/Perf%20Metal.skp
                    Ron
                    • EdsonE
                      Edson
                      thanks, ron, still on time, yeah. i am working on a competition and intend to use these sheets for sun shading.
                        jwbrockman
                        Here are a couple I have. The round punched texture was found on the old sketchup forums, but I can't remember who posted it. The wire mesh is one that I made for a project last year. Both of these have transparency in the surface but will cast a solid shadow. The only way around that as far as I can tell is to actually model all of the perforations in your surface. Hope this helps anyhow.
                        perforated metal.skp
                          sketchy
                          I think you just want to change .zip to .skm
                          But I have never done this before so give that a try. Or just download the entire material bonus pack. There are some goodies in there.
