    KT
    49 Posts 9 Posters 6.4k Views 9 Watching
    • david57D Offline
      david57
      Another test render.
      • jenujacobJ Offline
        jenujacob
        by misstakes u mean the plants rite??? u just need a png image and turn on the alpha map in the clipping option! πŸ˜‰
        • david57D Offline
          david57
          • david57D Offline
            david57
            Well, I'm just trying to keep up with Jone's and the Smiths.
            • david57D Offline
              david57
              Another render of Blenders Lsystem Trees.
              • david57D Offline
                david57
                • david57D Offline
                  david57
                  Two more renders. Imported trees into SketchUp and separated some twigs
                  from the branches and trunk.
                  Populated the twigs with the same leafs i used for the hedges.
                  • david57D Offline
                    david57
                    and a another...
                    • david57D Offline
                      david57
                      Here's an 11,000 polygon tree. Small enough to work with SketchUp.
                      Using a small laptop, 797 MHz, 512 MB of RAM.
                      • david57D Offline
                        david57
                        Here's the output.
                        • FrederikF Offline
                          Frederik
                          It looks really good, David..!! πŸ˜„
                          Are you planning to make some of these trees into model libraries..??
                          Cheers
                          Kim Frederik
                          • david57D Offline
                            david57
                            Frederik,
                            I don't know yet if im going make any model library's, it's to early to say.
                            Ive only have 9 normal looking trees.
                            and here's another, i added some toes to the base of the tree with blenders
                            sculpt mode tools.
                            • david57D Offline
                              david57
                              ...and here's the result. Nothings perfect, UV's are not setup correctly on any of
                              the trees.
                              • david57D Offline
                                david57
                                This is one of my best settings of been using. Just press Generate many times
                                for random trees. If any body can find better settings let us know.
                                • david57D Offline
                                  david57
                                  another.
                                  • david57D Offline
                                    david57
                                    • david57D Offline
                                      david57
                                      Starting up another.
                                      • david57D Offline
                                        david57
                                        Download the 3DS file from here.
                                        (www.mediamax.com)
                                        • 3 / 3
