    KT
    49 Posts 9 Posters 6.3k Views 9 Watching
    • david57D Offline
      david57
      Another render of Blenders Lsystem Trees.
      • david57D Offline
        david57
        • david57D Offline
          david57
          Two more renders. Imported trees into SketchUp and separated some twigs
          from the branches and trunk.
          Populated the twigs with the same leafs i used for the hedges.
          • david57D Offline
            david57
            and a another...
            • david57D Offline
              david57
              Here's an 11,000 polygon tree. Small enough to work with SketchUp.
              Using a small laptop, 797 MHz, 512 MB of RAM.
              • david57D Offline
                david57
                Here's the output.
                • FrederikF Offline
                  Frederik
                  It looks really good, David..!! πŸ˜„
                  Are you planning to make some of these trees into model libraries..??
                  Cheers
                  Kim Frederik
                  • david57D Offline
                    david57
                    Frederik,
                    I don't know yet if im going make any model library's, it's to early to say.
                    Ive only have 9 normal looking trees.
                    and here's another, i added some toes to the base of the tree with blenders
                    sculpt mode tools.
                    • david57D Offline
                      david57
                      ...and here's the result. Nothings perfect, UV's are not setup correctly on any of
                      the trees.
                      • david57D Offline
                        david57
                        This is one of my best settings of been using. Just press Generate many times
                        for random trees. If any body can find better settings let us know.
                        • david57D Offline
                          david57
                          another.
                          • david57D Offline
                            david57
                            • david57D Offline
                              david57
                              Starting up another.
                              • david57D Offline
                                david57
                                Download the 3DS file from here.
                                (www.mediamax.com)
                                • 3 / 3
