    KT
    49 Posts 9 Posters 8.9k Views 9 Watching
    • jenujacobJ
      jenujacob
      by misstakes u mean the plants rite??? u just need a png image and turn on the alpha map in the clipping option! πŸ˜‰
      • david57D
        david57
        • david57D
          david57
          Well, I'm just trying to keep up with Jone's and the Smiths.
          • david57D
            david57
            Another render of Blenders Lsystem Trees.
            • david57D
              david57
              • david57D
                david57
                Two more renders. Imported trees into SketchUp and separated some twigs
                from the branches and trunk.
                Populated the twigs with the same leafs i used for the hedges.
                • david57D
                  david57
                  and a another...
                  • david57D
                    david57
                    Here's an 11,000 polygon tree. Small enough to work with SketchUp.
                    Using a small laptop, 797 MHz, 512 MB of RAM.
                    • david57D
                      david57
                      Here's the output.
                      • FrederikF
                        Frederik
                        It looks really good, David..!! πŸ˜„
                        Are you planning to make some of these trees into model libraries..??
                        Cheers
                        Kim Frederik
                        • david57D
                          david57
                          Frederik,
                          I don't know yet if im going make any model library's, it's to early to say.
                          Ive only have 9 normal looking trees.
                          and here's another, i added some toes to the base of the tree with blenders
                          sculpt mode tools.
                          • david57D
                            david57
                            ...and here's the result. Nothings perfect, UV's are not setup correctly on any of
                            the trees.
                            • david57D
                              david57
                              This is one of my best settings of been using. Just press Generate many times
                              for random trees. If any body can find better settings let us know.
                              • david57D
                                david57
                                another.
                                • david57D
                                  david57
                                  • david57D
                                    david57
                                    Starting up another.
                                    • david57D
                                      david57
                                      Download the 3DS file from here.
                                      (www.mediamax.com)
                                      • 3 / 3
