    KT
    49 Posts 9 Posters 8.9k Views 9 Watching
    • david57D
      david57
      • david57D
        david57
        Well, I'm just trying to keep up with Jone's and the Smiths.
        • david57D
          david57
          Another render of Blenders Lsystem Trees.
          • david57D
            david57
            • david57D
              david57
              Two more renders. Imported trees into SketchUp and separated some twigs
              from the branches and trunk.
              Populated the twigs with the same leafs i used for the hedges.
              • david57D
                david57
                and a another...
                • david57D
                  david57
                  Here's an 11,000 polygon tree. Small enough to work with SketchUp.
                  Using a small laptop, 797 MHz, 512 MB of RAM.
                  • david57D
                    david57
                    Here's the output.
                    • FrederikF
                      Frederik
                      It looks really good, David..!! πŸ˜„
                      Are you planning to make some of these trees into model libraries..??
                      Cheers
                      Kim Frederik
                      • david57D
                        david57
                        Frederik,
                        I don't know yet if im going make any model library's, it's to early to say.
                        Ive only have 9 normal looking trees.
                        and here's another, i added some toes to the base of the tree with blenders
                        sculpt mode tools.
                        • david57D
                          david57
                          ...and here's the result. Nothings perfect, UV's are not setup correctly on any of
                          the trees.
                          • david57D
                            david57
                            This is one of my best settings of been using. Just press Generate many times
                            for random trees. If any body can find better settings let us know.
                            • david57D
                              david57
                              another.
                              • david57D
                                david57
                                • david57D
                                  david57
                                  Starting up another.
                                  • david57D
                                    david57
                                    Download the 3DS file from here.
                                    (www.mediamax.com)
                                    • 3 / 3
