    KT
    49 Posts 9 Posters 6.7k Views 9 Watching
      Never mind. Toilets/bathrooms are always needed.
      But how come that tree is growing from the pavement? 😲
      Nice render BTW
      • david57D Offline
        david57
        Here's a test render with lots of mistakes.
        • david57D Offline
          david57
          Another test render.
          • jenujacobJ Offline
            jenujacob
            by misstakes u mean the plants rite??? u just need a png image and turn on the alpha map in the clipping option! πŸ˜‰
            • david57D Offline
              david57
              • david57D Offline
                david57
                Well, I'm just trying to keep up with Jone's and the Smiths.
                • david57D Offline
                  david57
                  Another render of Blenders Lsystem Trees.
                  • david57D Offline
                    david57
                    • david57D Offline
                      david57
                      Two more renders. Imported trees into SketchUp and separated some twigs
                      from the branches and trunk.
                      Populated the twigs with the same leafs i used for the hedges.
                      • david57D Offline
                        david57
                        and a another...
                        • david57D Offline
                          david57
                          Here's an 11,000 polygon tree. Small enough to work with SketchUp.
                          Using a small laptop, 797 MHz, 512 MB of RAM.
                          • david57D Offline
                            david57
                            Here's the output.
                            • FrederikF Offline
                              Frederik
                              It looks really good, David..!! πŸ˜„
                              Are you planning to make some of these trees into model libraries..??
                              Cheers
                              Kim Frederik
                              • david57D Offline
                                david57
                                Frederik,
                                I don't know yet if im going make any model library's, it's to early to say.
                                Ive only have 9 normal looking trees.
                                and here's another, i added some toes to the base of the tree with blenders
                                sculpt mode tools.
                                • david57D Offline
                                  david57
                                  ...and here's the result. Nothings perfect, UV's are not setup correctly on any of
                                  the trees.
                                  • david57D Offline
                                    david57
                                    This is one of my best settings of been using. Just press Generate many times
                                    for random trees. If any body can find better settings let us know.
                                    • david57D Offline
                                      david57
                                      another.
                                      • david57D Offline
                                        david57
                                        • david57D Offline
                                          david57
                                          Starting up another.
                                          • david57D Offline
                                            david57
                                            Download the 3DS file from here.
                                            (www.mediamax.com)
                                            • 2 / 3
