    KT
    49 Posts 9 Posters 7.0k Views 9 Watching
    • david57D Offline
      david57
      Here,s another render.
      • david57D Offline
        david57
        Model in the background was not made by me.
        Model can be found at
        http://archidom.net/ddd/model_S.htm
        • david57D Offline
          david57
          Needs Pillars or Columns under the radius.
          • david57D Offline
            david57
            Trying to figure this one out, before a render. Need to remove the door ways
            on the first floor, they look like men and women restrooms.
            • david57D Offline
              david57
              • david57D Offline
                david57
                Here's a Progressive Path Tracing. I could'nt get rid of the arched door ways. I didnt
                have the guts.
                  Never mind. Toilets/bathrooms are always needed.
                  But how come that tree is growing from the pavement? 😲
                  Nice render BTW
                  • david57D Offline
                    david57
                    Here's a test render with lots of mistakes.
                    • david57D Offline
                      david57
                      Another test render.
                      • jenujacobJ Offline
                        jenujacob
                        by misstakes u mean the plants rite??? u just need a png image and turn on the alpha map in the clipping option! πŸ˜‰
                        • david57D Offline
                          david57
                          • david57D Offline
                            david57
                            Well, I'm just trying to keep up with Jone's and the Smiths.
                            • david57D Offline
                              david57
                              Another render of Blenders Lsystem Trees.
                              • david57D Offline
                                david57
                                • david57D Offline
                                  david57
                                  Two more renders. Imported trees into SketchUp and separated some twigs
                                  from the branches and trunk.
                                  Populated the twigs with the same leafs i used for the hedges.
                                  • david57D Offline
                                    david57
                                    and a another...
                                    • david57D Offline
                                      david57
                                      Here's an 11,000 polygon tree. Small enough to work with SketchUp.
                                      Using a small laptop, 797 MHz, 512 MB of RAM.
                                      • david57D Offline
                                        david57
                                        Here's the output.
                                        • FrederikF Offline
                                          Frederik
                                          It looks really good, David..!! πŸ˜„
                                          Are you planning to make some of these trees into model libraries..??
                                          Cheers
                                          Kim Frederik
                                          • david57D Offline
                                            david57
                                            Frederik,
                                            I don't know yet if im going make any model library's, it's to early to say.
                                            Ive only have 9 normal looking trees.
                                            and here's another, i added some toes to the base of the tree with blenders
                                            sculpt mode tools.
                                            • 2 / 3
